查看: 2533|回复: 0
ad7705转换器显示输入电压无变化 附单片机程序
ID:506839 发表于 2019-5-19 20:58 | 显示全部楼层 |阅读模式
求助,这个程序是将ad7705的输入电压显示到lcd上,用的单片机是stc89c52,可是我lcd上一直显示2.4999mV,没有变化,不知道哪里出问题了
  1. #include <intrins.h>
  2. #include<reg51.h>
  3. #define true 1
  4. #define false 0
  5. #define        uchar unsigned char
  6. #define        uint unsigned int
  7.
  8. #define lcddata 1
  9. #define instruction 0
  10. #define read 1
  11. #define write 0
  12. sbit AD_SCLK=P1^3;
  13. sbit AD_DIN=P1^2;
  14. sbit AD_OUT=P1^4;
  15. sbit AD_DRDY=P1^5;
  16. sbit CS=P1^0;
  17. sbit RST=P1^1;
  18. sbit L_DI=P2^6;
  19. sbit L_RW=P2^5;
  20. sbit L_EN=P2^7;
  21. void init_time(void);
  22. //void init_ad_7705(void);
  23. unsigned int read_ad7705(uchar channel);
  24. void ad_reset();
  25. void ad_write(unsigned char command_byte);
  26. unsigned int ad_read(unsigned char num);
  27. void Delayms(unsigned int no);
  28.
  29. unsigned long Temparature2,Temparature1;
  30. uchar CycleCheck=0;
  31. void Send_Data(        bit DI,
  32.                                 bit RW,
  33.                                 unsigned char LData);
  34. void init_LCD() ;
  35. void Send_NumberV(        unsigned char Row,
  36.                                         unsigned char Column,
  37.                                         unsigned long number,
  38.                                         unsigned char no,
  39.                                         unsigned char point
  40.                                         );
  41. void Send_TextV(unsigned char Row,
  42.                                 unsigned char Column,
  43.                                 unsigned char code *po,
  44.                                 unsigned char no
  45.                                 );
  46. void init_ad_7705(uchar channel);
  47. void ad_Calculator(uchar channel);
  48. void main(void)
  49. {
  50.         RED10        = 0;
  51.
  52.         init_time();
  53.         CS=0;
  54.         RST=1;
  55.
  56.         init_LCD() ;
  57.
  58.
  59.         Send_TextV(0,0,"CH0:      mV",12);
  60.     Send_TextV(1,0,"CH1:      mV",12);
  61.
  62.                 init_ad_7705(0);
  63.         Delayms(100);
  64.         init_ad_7705(1);
  65.
  66.
  67.         while(1)
  68.         {        if(CycleCheck>=20)
  69.                  {        CycleCheck=0;
  70.
  71.                         ad_Calculator(0);
  72.                         Temparature1=read_ad7705(0);
  73.                         Delayms(100);
  74.
  75.                         ad_Calculator(1);
  76.                         Temparature2=read_ad7705(1);
  77.
  78.
  79.                         Temparature1=Temparature1*25000/65536;
  80.                         Temparature2=Temparature2*25000/65536;
  81.
  82.
  83.
  84.
  85.                         Send_NumberV(0,4,Temparature1,5,1);
  86.                         Send_NumberV(1,4,Temparature2,5,1);
  87.                 }
  88.         }
  89. }
  90. void ad_Calculator(uchar channel)
  91. {
  92.         AD_SCLK=1;
  93.         AD_DIN=1;
  94.
  95.         if(channel==0)
  96.         {        ad_write(0x10);
  97.                 _nop_();_nop_();_nop_();
  98.                 ad_write(0x44);
  99.
  100.           }
  101.
  102.
  103.           if(channel==1)
  104.           {
  105.
  106.                 ad_write(0x11);
  107.                 _nop_();_nop_();_nop_();
  108.                 ad_write(0x44);
  109.           }
  110.
  111.         AD_SCLK=1;
  112.         AD_DIN=1;
  113. }
  114. void init_ad_7705(uchar channel)
  115. {
  116.         EA=0;
  117.         AD_SCLK=1;
  118.         AD_DIN=1;
  119.         ad_reset();
  120.
  121.         if(channel==0)
  122.         {
  123.                 ad_write(0x20);
  124.                 _nop_();_nop_();_nop_();
  125.                 ad_write(0x06);
  126.
  127.
  128.
  129.
  130.                 _nop_();_nop_();_nop_();
  131.                 ad_write(0x10);
  132.                 _nop_();_nop_();_nop_();
  133.                 ad_write(0x44);
  134.
  135.           }
  136.
  137.
  138.           if(channel==1)
  139.           {
  140.                 ad_write(0x21);
  141.                 _nop_();_nop_();_nop_();
  142.                 ad_write(0x06);
  143.
  144.
  145.
  146.                 _nop_();_nop_();_nop_();
  147.                 ad_write(0x11);
  148.                 _nop_();_nop_();_nop_();
  149.                 ad_write(0x44);
  150.           }
  151.
  152.         AD_SCLK=1;
  153.         AD_DIN=1;
  154.         EA=1;
  155.
  156. }
  157. void Send_Data(        bit DI,
  158.                                 bit RW,
  159.                                 unsigned char LData)
  160. {
  161.
  162.
  163.         _nop_();
  164.
  165.         Delayms(3);
  166.
  167.
  168.         _nop_();_nop_();_nop_();_nop_();
  169.         L_DI=DI;
  170.         L_RW=RW;
  171.         _nop_();
  172.         P0=0xff;
  173.         _nop_();_nop_();_nop_();_nop_();
  174.         L_EN=0;
  175.         P0=LData;
  176.         _nop_();_nop_();_nop_();_nop_();
  177.         _nop_();_nop_();_nop_();_nop_();
  178.         L_EN=1;
  179.         _nop_();_nop_();_nop_();_nop_();
  180.         _nop_();_nop_();_nop_();_nop_();
  181.         L_EN=0;
  182.         _nop_();_nop_();_nop_();_nop_();
  183.         P0=0xff;
  184.         _nop_();
  185.         L_DI=1;
  186.         L_RW=1;
  187.         P0=0xff;
  188.         _nop_();
  189.         return;
  190. }
  191. void clear_LCD(void)
  192. {
  193.         _nop_();
  194.         Send_Data(instruction,write,0x01);
  195.         Delayms(3);
  196. }
  197. void init_LCD(void)
  198. {        _nop_();
  199.         Send_Data(instruction,write,0x01);
  200.         Delayms(15);
  201.         _nop_();
  202.         Send_Data(instruction,write,0x3c);
  203.         Delayms(15);
  204.         _nop_();
  205.         Send_Data(instruction,write,0x0c);
  206.         _nop_();
  207.         _nop_();
  208.         clear_LCD();
  209.         return;
  210. }
  211. void Send_NumberV(        unsigned char Row,
  212.                                         unsigned char Column,
  213.                                         unsigned long number,
  214.                                         unsigned char no,
  215.                                         unsigned char point
  216.                                         )
  217. {
  218.         unsigned char address,temp,Digital,i,Clear;
  219.         unsigned long MoveBit;
  220.         Clear=true;
  221.         if(Column<16 && Row<4)
  222.         {        _nop_();
  223.                 switch(Row)
  224.                 {
  225.                         case 0:
  226.                                 address=0x80+Column;
  227.                                 break;
  228.                         case 1:
  229.                                 address=0xc0+Column;
  230.                                 break;
  231.                         case 2:
  232.                                 address=0x90+Column;
  233.                                 break;
  234.                         case 3:
  235.                                 address=0xd0+Column;
  236.                                 break;
  237.                         default:
  238.                                 _nop_();
  239.                                 break;
  240.                 }
  241.                 _nop_();
  242.                 Send_Data(instruction,write,address);
  243.                 _nop_();
  244.                 for(i=0,MoveBit=0x0001;i<(no-1);i++)
  245.                 {        MoveBit=MoveBit*10;
  246.                 }
  247.                 for(i=0;i<no;i++)
  248.                 {        Digital=(number/MoveBit)%10;
  249.                         if(Digital!=0)
  250.                         {        Clear=false;
  251.                         }
  252.                         if(Clear==true && (i==(no-point-1)))
  253.                         {        Clear=false;
  254.                         }
  255.                         MoveBit=MoveBit/10;
  256.                         temp=0x30+Digital;
  257.                         if(Clear==true)
  258.                         {        Send_Data(lcddata,write,0x20);
  259.                         }else
  260.                         {        Send_Data(lcddata,write,temp);
  261.                         }
  262.                         if((i==no-point-1) &  point!=0)
  263.                         {        Send_Data(lcddata,write,0x2E);
  264.                         }
  265.                 }
  266.                 _nop_();
  267.         }
  268.         _nop_();
  269.         return;
  270. }
  271. void Send_TextV(unsigned char Row,
  272.                                 unsigned char Column,
  273.                                 unsigned char code *po,
  274.                                 unsigned char no
  275.                                 )
  276. {
  277.         unsigned char address,i;
  278.         if(Column<16 && Row<4)
  279.         {        _nop_();
  280.                 switch(Row)
  281.                 {
  282.                         case 0:
  283.                                 address=0x80+Column;
  284.                                 break;
  285.                         case 1:
  286.                                 address=0xc0+Column;
  287.                                 break;
  288.                         case 2:
  289.                                 address=0x90+Column;
  290.                                 break;
  291.                         case 3:
  292.                                 address=0xd0+Column;
  293.                                 break;
  294.                         default:
  295.                                 _nop_();
  296.                                 break;
  297.                 }
  298.                 _nop_();
  299.                 Send_Data(instruction,write,address);
  300.                 _nop_();
  301.                 for(i=0;i<no;i++)
  302.                 {
  303.                         _nop_();
  304.                         Send_Data(lcddata,write,*po);
  305.                         _nop_();
  306.                         po++;
  307.                         _nop_();
  308.                 }
  309.                 _nop_();
  310.         }
  311.         _nop_();
  312.         return;
  313. }
  314. void Delayms(unsigned int no)
  315. {        unsigned char i;
  316.         for(;no>0;)
  317.         {        for(i=120;i>0;)
  318.                 {
  319.                          _nop_();
  320.                         i--;
  321.                         _nop_();
  322.                 }
  323.                 _nop_();
  324.
  325.                 no--;
  326.                 _nop_();
  327.         }
  328.         _nop_();
  329.         return;
  330. }
  331. void ad_reset()
  332. {
  333.         uchar i;
  334.         for(i=0;i<40;i++)
  335.         {        AD_SCLK=0;
  336.                 AD_DIN=1;
  337.                 AD_SCLK=1;
  338.         }
  339. }
  340. void ad_write(unsigned char command_byte)
  341. {
  342.         unsigned char i;
  343. //        AD_CS=0;
  344.         AD_SCLK=1;
  345.         AD_DIN=1;
  346.         for (i=0;i<32;i++)
  347.         {
  348.                 AD_SCLK=0;
  349.                 _nop_();_nop_();_nop_();
  350.                 if (command_byte&0x80)
  351.                 {
  352.                         AD_DIN=1;
  353.                 }
  354.                 else
  355.                 {
  356.                         AD_DIN=0;
  357.                 }
  358.                 _nop_();_nop_();_nop_();
  359.                 _nop_();_nop_();_nop_();
  360.                 AD_SCLK=1;
  361.                 command_byte=command_byte*2;
  362.                 _nop_();_nop_();_nop_();
  363.                 _nop_();_nop_();_nop_();
  364.         }
  365.         AD_SCLK=1;
  366.         AD_DIN=1;
  367. }
  368. unsigned int ad_read(unsigned char num)
  369. {
  370.         unsigned char i;
  371.         unsigned int ad_data;
  372.         ad_data=0;
  373.
  374.         AD_SCLK=1;
  375.         AD_DIN=1;
  376.         for (i=0;i<num;i++)
  377.         {        _nop_();_nop_();_nop_();
  378.                 AD_SCLK=0;
  379.                 ad_data*=2;
  380.                 _nop_();_nop_();_nop_();
  381.                 AD_SCLK=1;
  382.                 _nop_();_nop_();_nop_();
  383.                 if (AD_OUT==1)
  384.                 {
  385.                         ad_data=ad_data|0x0001;
  386.                 }
  387.         }
  388. //        AD_CS=
  389.         AD_SCLK=1;
  390.         AD_DIN=1;
  391.         return ad_data;
  392. }
  393.
  394. unsigned int read_ad7705(uchar channel)
  395. {                           uint AD1;
  396.                         if(channel==0)
  397.                         {        ad_write(0x39);
  398.                         } else
  399.                         {        ad_write(0x38);
  400.                         }
  401.                         AD1=ad_read(16);
  402.                     return AD1;
  403. }
  404. void init_time(void)
  405. {
  406.         TMOD=0x01;
  407.         ET0=true;
  408.         TH0=0x4c;
  409.         TL0=0x00;
  410.         TR0=true;
  411.         EA=1;
  412.         _nop_();
  413.         return;
  414. }
  415. void time0isr(void) interrupt 1 using 1
  416. {        EA=false;
  417.         TH0=0x4c;
  418.         TL0=0x00;
  419.         EA=true;
  420.     CycleCheck++;
  421.         _nop_();
  422.         return;
  423. }
