查看: 3456|回复: 0
单片机+TLC1543用1602显示的AD转换程序及仿真
  1. /*----------------------Item Description-----------------------------------
  2. -  Project Name          : TLC1543.c
  3. -  Files                 :
  4. -  Description           : None
  5. -  IDE                   : Keil uVision4
  6. -  Author                : Mason    别名:小菜
  7. -  Email Address         : 1609099954@qq.com
  8. -  Create Date           : 2013/7/27
  9. -  Performance           : Finished
  10. -  -------------------------------------------
  11. -  Revision History
  12. -  No.    Date        Revised by    Item    Description
  13. -
  14. -------------------------------------------------------------------------*/
  15. #include <reg52.h>
  16. #include "MICRO.h"
  17. #include "LCD1602.h"
  18. #include "TLC1543.h"
  19. void main()
  20. {
  21.     uint16 volt;
  22.     LCD1602_Init();                    // LCD1602上电初使化
  23.     draw1602_basic();
  24.     TLC1543_init();
  25.     while(1)
  26.     {
  27.         volt = ReadADC_TLC1543(0);
  28.         write1602_DDRAM_pos(7,1);
  29.         write1602_byte(volt/1000+0x30,1);
  30.         write1602_byte(volt/100%10+0x30,1);
  31.         write1602_byte(volt/10%10+0x30,1);
  32.         write1602_byte(volt%10+0x30,1);
  33.     }
  34. }
  1. /*----Head Description----
  2. -  File Name               : TLC1543.H
  3. -  Author                  : Mason    别名:小菜
  4. -  Create Date             : 2013/7/26
  5. -  -------------------------------------------
  6. -  Revision History
  7. -  No.    Date        Revised by    Item    Description
  8. -
  9. -------------------------------------------------------------------------*/
  10. #ifndef _TLC1543_H_
  11. #define _TLC1543_H_
  12. /*----------------------------Head---------------------------------------*/
  13. #include <reg52.h>
  14. #include "MICRO.h"
  15. /*----------------------------Interface----------------------------------*/
  16. sbit EOC_1543  = P3^7;
  17. sbit SCLK_1543 = P3^5;
  18. sbit ADDR_1543 = P3^3;
  19. sbit DOUT_1543 = P3^2;
  20. sbit CS_1543   = P3^4;
  21. /*----------------------------Function Declaration-----------------------*/
  22. uint16 ReadADC_TLC1543(uchar ain);
  23. void TLC1543_init(void);
  24. #endif
TLC1543.7z (48.07 KB, 下载次数: 87)
收藏收藏4 分享淘帖 顶 踩
