查看: 2685|回复: 0
STM32F407跑马灯实验
ID:761160 发表于 2020-5-26 15:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跑马灯实验
一、实验目的与要求
1、熟悉GPIO的使用方法,熟悉HAL固件库中GPIO库函数的使用方法
2、熟悉Timer2的使用方法,熟悉HAL固件库中通用定时器(TIM) 库函数的使用方法
3、熟悉嵌套向量中断控制器(NVIC),熟悉STM32固件库中NVIC库函数的使用方法,进一步熟悉中断程序编写
二、实验设备
SUN ESMC01实验仪(含STM32F407模块)一套、ARM仿真器一套、PC机一台
三、实验内容
1、编写程序:控制STM32F407核心板上的4个指示灯DS1~DS4,,循环点亮,瞬间只有一个灯亮,使用Timer2产生延时。
2、观察实验结果,验证程序是否正确。
基于延时
while (1)
        //LED1 turned on, LED4 turned off
        HAL_GPIO_WritePin(GPIOC,GPIO_PIN_0, GPIO_PIN_SET);
        HAL_Delay(1000);
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0,GPIO_PIN_RESET);
        // LED2 turned on, LED1 turned off
        HAL_GPIO_WritePin(GPIOC,GPIO_PIN_1, GPIO_PIN_SET);
        HAL_Delay(1000);
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_1, GPIO_PIN_RESET);
        // LED3 turned on, LED2 turned off
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_2,GPIO_PIN_SET);
        HAL_Delay(1000);
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_2,GPIO_PIN_RESET);
        // LD4 turned on, LD3 turned off
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_3,GPIO_PIN_SET);
        HAL_Delay(1000);
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_3,GPIO_PIN_RESET);
基于计时器
intmain(void)
  int   t= 0;
  lighton = 0;              //500mssign
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_TIM2_Init();
  __HAL_TIM_CLEAR_IT(&htim2,TIM_IT_UPDATE);//清除中断
  HAL_TIM_Base_Start_IT(&htim2) ;           //启动时钟
  while (1)
        if (lighton)
        lighton = 0;                       //500ms sign
        switch(t)
        case 0:
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_3, GPIO_PIN_RESET);     //LED4off
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_0, GPIO_PIN_SET);      //LED1 on
          break;
        case 1:
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_0, GPIO_PIN_RESET);     //LED1off
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_1, GPIO_PIN_SET);      //LED2 on
          break;
        case 2:
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_1, GPIO_PIN_RESET);     //LED2off
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_2, GPIO_PIN_SET);       //LED3 on
          break;
        case 3:
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_2, GPIO_PIN_RESET);     //LED3off
          HAL_GPIO_WritePin(GPIOC,GPIO_PIN_3, GPIO_PIN_SET);       //LED4 on
          break;
        t++;
        t &= 0x3;
voidHAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
    if (htim == &htim2)
        lighton = 1;
