查看: 1518|回复: 0
STM32F10控制OV7275摄像头源程序
ID:51217 发表于 2020-6-20 14:14 | 显示全部楼层 |阅读模式
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "lcd.h"
#include "usart.h"
#include "string.h"
#include "ov7725.h"
#include "tpad.h"
#include "timer.h"
#include "exti.h"
#include "usmart.h"
//由于OV7725传感器安装方式原因,OV7725_WINDOW_WIDTH相当于LCD的高度,OV7725_WINDOW_HEIGHT相当于LCD的宽度
//注意:此宏定义只对OV7725有效
#define  OV7725_WINDOW_WIDTH                320         // <=320
#define  OV7725_WINDOW_HEIGHT                240         // <=240
const u8*LMODE_TBL[6]={"Auto","Sunny","Cloudy","Office","Home","Night"};//6种光照模式
const u8*EFFECTS_TBL[7]={"Normal","Negative","B&W","Redish","Greenish","Bluish","Antique"};        //7种特效
extern u8 ov_sta;        //在exit.c里 面定义
extern u8 ov_frame;        //在timer.c里面定义
//更新LCD显示(OV7725)
void OV7725_camera_refresh(void)
        u32 i,j;
         u16 color;
        if(ov_sta)//有帧中断更新
                LCD_Scan_Dir(U2D_L2R);                //从上到下,从左到右
                LCD_Set_Window((lcddev.width-OV7725_WINDOW_WIDTH)/2,(lcddev.height-OV7725_WINDOW_HEIGHT)/2,OV7725_WINDOW_WIDTH,OV7725_WINDOW_HEIGHT);//将显示区域设置到屏幕中央
                if(lcddev.id==0X1963)
                        LCD_Set_Window((lcddev.width-OV7725_WINDOW_WIDTH)/2,(lcddev.height-OV7725_WINDOW_HEIGHT)/2,OV7725_WINDOW_HEIGHT,OV7725_WINDOW_WIDTH);//将显示区域设置到屏幕中央
                LCD_WriteRAM_Prepare();     //开始写入GRAM
                OV7725_RRST=0;                                //开始复位读指针
                OV7725_RCK_L;
                OV7725_RCK_H;
                OV7725_RCK_L;
                OV7725_RRST=1;                                //复位读指针结束
                OV7725_RCK_H;
                for(i=0;i<OV7725_WINDOW_HEIGHT;i++)
                        for(j=0;j<OV7725_WINDOW_WIDTH;j++)
                                OV7725_RCK_L;
                                color=GPIOC->IDR&0XFF;        //读数据
                                OV7725_RCK_H;
                                color<<=8;
                                OV7725_RCK_L;
                                color|=GPIOC->IDR&0XFF;        //读数据
                                OV7725_RCK_H;
                                LCD->LCD_RAM=color;
                 ov_sta=0;                                        //清零帧中断标记
                ov_frame++;
                LCD_Scan_Dir(DFT_SCAN_DIR);        //恢复默认扫描方向
int main(void)
        u8 key;
         u8 i=0;
        u8 msgbuf[15];//消息缓存区
        u8 tm=0;
        u8 lightmode=0,effect=0;
        s8 saturation=0,brightness=0,contrast=0;
        delay_init();                     //延时函数初始化
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
        uart_init(115200);                 //串口初始化为 115200
         usmart_dev.init(72);                //初始化USMART
         LED_Init();                                          //初始化与LED连接的硬件接口
        KEY_Init();                                        //初始化按键
        LCD_Init();                                           //初始化LCD
        TPAD_Init(6);                                //触摸按键初始化
         POINT_COLOR=RED;                        //设置字体为红色
        LCD_ShowString(30,50,200,16,16,"WarShip STM32");
        LCD_ShowString(30,70,200,16,16,"OV7725 TEST");
        LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(30,110,200,16,16,"2019/10/16");
        LCD_ShowString(30,130,200,16,16,"KEY0:Light Mode");
        LCD_ShowString(30,150,200,16,16,"KEY1:Saturation");
        LCD_ShowString(30,170,200,16,16,"KEY2:Brightness");
        LCD_ShowString(30,190,200,16,16,"KEY_UP:Contrast");
        LCD_ShowString(30,210,200,16,16,"TPAD:Effects");
          LCD_ShowString(30,230,200,16,16,"OV7725 Init...");
        while(1)//初始化OV7725
                if(OV7725_Init()==0)
                        LCD_ShowString(30,210,200,16,16,"OV7725 Init OK       ");
                                key=KEY_Scan(0);
                                if(key==KEY0_PRES)
                                        OV7725_Window_Set(OV7725_WINDOW_WIDTH,OV7725_WINDOW_HEIGHT,0);//QVGA模式输出
                                        break;
                                }else if(key==KEY1_PRES)
                                        OV7725_Window_Set(OV7725_WINDOW_WIDTH,OV7725_WINDOW_HEIGHT,1);//VGA模式输出
                                        break;
                                i++;
                                if(i==100)LCD_ShowString(30,230,210,16,16,"KEY0:QVGA  KEY1:VGA"); //闪烁显示提示信息
                                if(i==200)
                                        LCD_Fill(30,230,210,250+16,WHITE);
                                        i=0;
                                delay_ms(5);
                        OV7725_Light_Mode(lightmode);
                        OV7725_Color_Saturation(saturation);
                        OV7725_Brightness(brightness);
                        OV7725_Contrast(contrast);
                        OV7725_Special_Effects(effect);
                        OV7725_CS=0;
                        break;
                }else
                        LCD_ShowString(30,210,200,16,16,"OV7725 Error!!");
                        delay_ms(200);
                        LCD_Fill(30,210,239,246,WHITE);
                        delay_ms(200);
        TIM6_Int_Init(10000,7199);                        //10Khz计数频率,1秒钟中断
        EXTI8_Init();                                            //使能外部中断8,捕获帧中断
        LCD_Clear(BLACK);
                key=KEY_Scan(0);//不支持连按
                if(key)
                        tm=20;
                        switch(key)
                                case KEY0_PRES:        //灯光模式Light Mode
                                        lightmode++;
                                        if(lightmode>5)lightmode=0;
                                        sprintf((char*)msgbuf,"%s",LMODE_TBL[lightmode]);
                                        break;
                                case KEY1_PRES:        //饱和度Saturation
                                        saturation++;
                                        if(saturation>4)saturation=-4;
                                        else if(saturation<-4)saturation=4;
                                        sprintf((char*)msgbuf,"Saturation:%d",saturation);
                                        break;
                                case WKUP_PRES:        //对比度Contrast
                                        contrast++;
                                        if(contrast>4)contrast=-4;
                                        else if(contrast<-4)contrast=4;
                                        sprintf((char*)msgbuf,"Contrast:%d",contrast);
                                        break;
                if(TPAD_Scan(0))//检测到触摸按键
                        effect++;
                        if(effect>6)effect=0;
                        OV7725_Special_Effects(effect);                //设置特效
                         sprintf((char*)msgbuf,"%s",EFFECTS_TBL[effect]);
                        tm=20;
                OV7725_camera_refresh();                //更新显示
                 if(tm)
                        LCD_ShowString((lcddev.width-240)/2+30,(lcddev.height-320)/2+60,200,16,16,msgbuf);
                        tm--;
                i++;
                if(i>=15)//DS0闪烁.
                        i=0;
                        LED0=!LED0;
STM32F10控制OV7275摄像头.zip
400.46 KB, 下载次数: 4, 下载积分: 黑币 -5
