查看: 1901|回复: 3
C8051F500单片机Watchdog程序
ID:959278 发表于 2021-8-6 19:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
// Program Description:
// This program helps the user to learn about operating the Watch Dog Timer.
// The WDT is used to generate resets if the times between writes to the WDT
// update register (PCA0CPH5) exceed a specified limit. The WDT can be disabled
// and enabled in the software as needed. When enabled the PCA Module 5 acts as
// the WDT. This program resets the MCU when P1.4 switch is pressed. Also upon
// reset the LED blinks approximately five times faster when compared to
// before.The reset is caused due to a WDT overflow and can be confirmed by
// checking the value of the RSTSRC register where bit 3 is set to indicate a
// reset caused by WDT.
// Resources Used:
// * Internal Oscillator: MCU clock source
// * Timer 2: Blinks LED
// * PCA Module 5 : Watchdog Timer
// How to Test:
// 1) Compile and download code to a 'F500 device.
// 2) Make sure the LED and switch jumpers are placed on J19.
// 3) Run the code:
//        - The test will blink the LED at a rate of 10Hz until the switch SW1
//          (P1.4) is pressed.
//        - Once the the switch is pressed and held for a long enough time,
//          it will prevent the WDT from being touched and the WDT will
//          cause a reset.
//        - Upon reset the code checks for a WDT reset and blinks the LED five
//          times faster than before to indicate the same.
// Target:         C8051F500 (Side A of a C8051F500-TB)
// Tool chain:     Keil C51 8.0 / Keil EVAL C51
// Command Line:   None
// Release 1.1 / 11 JUN 2008 (ADT)
//    -Edited Formatting
// Release 1.0 / 03 MAR 2008 (GP)
//    -Initial Revision
// Includes
#include <compiler_defs.h>
#include <C8051F500_defs.h>            // SFR declarations
// Global CONSTANTS
#define SYSCLK       24000000 / 8      // SYSCLK frequency in Hz
SBIT (LED, SFR_P1, 3);                 // LED == 1 means ON
SBIT (SW1, SFR_P1, 4);                 // SW1 == 0 means switch depressed
// Function PROTOTYPES
void OSCILLATOR_Init (void);
void PORT_Init (void);
void PCA_Init (void);
void TIMER2_Init (U16 counts);
INTERRUPT_PROTO (TIMER2_ISR, INTERRUPT_TIMER2);
// main() Routine
// The MAIN routine performs all the intialization, and then loops until the
// switch is pressed. When SW2 (P0.7) is pressed the code checks the RSTSRC
// register to make sure if the last reset is because of WDT.
void main (void)
   SFRPAGE = ACTIVE_PAGE;              // Set SFR Page for PCA0MD and RSTSRC
   PCA0MD &= ~0x40;                    // Disable the watchdog timer
   OSCILLATOR_Init ();                 // Initialize system clock to 24.5/8 MHz
   PCA_Init ();                         // Intialize the PCA
   PORT_Init ();                        // Initialize crossbar and GPIO
   if ((RSTSRC & 0x02) == 0x00)        // First check the PORSF bit. if PORSF
   {                                   // is set, all other RSTSRC flags are
                                       // invalid
      // Check if the last reset was due to the Watch Dog Timer
      if (RSTSRC == 0x08)
         TIMER2_Init (SYSCLK / 12 / 50);    // Make LED blink at 50Hz
         EA = 1;                            // Enable global interrupts
         while (1);                          // Wait forever
         // Init Timer2 to generate interrupts at a 10Hz rate.
         TIMER2_Init (SYSCLK / 12 / 10);
   // Calculate Watchdog Timer Timeout
   // Offset calculated in PCA clocks
   // Offset = ( 256 x PCA0CPL5 ) + 256 - PCA0L
   //        = ( 256 x 255(0xFF)) + 256 - 0
   // Time   = Offset * (12/SYSCLK)
   //        = 255 ms ( PCA uses SYSCLK/12 as its clock source)
   PCA0MD  &= ~0x40;                   // Disable watchdog timer
   PCA0L    = 0x00;                    // Set lower byte of PCA counter to 0
   PCA0H    = 0x00;                    // Set higher byte of PCA counter to 0
   PCA0CPL5 = 0xFF;                    // Write offset for the WDT
   PCA0MD  |= 0x40;                    // Enable the WDT
   // Main Application Loop/Task Scheduler
   while (1)
       // Task #1 - Check Port I/O
       while (!SW1);                 // Force the MCU to stay in this task as
                                    // long as SW1 is pressed. This task must
                                    // finish before the watchdog timer
                                    // timeout expires.
       // Task #2 - Reset Watchdog Timer
       PCA0CPH5 = 0x00;             // Write a 'dummy' value to the PCA0CPH5
                                    // register to reset the watchdog timer
                                    // timeout. If a delay longer than the
                                    // watchdog timer delay occurs between
                                    // successive writes to this register,
                                    // the device will be reset by the watch
                                    // dog timer.
// Initialization Subroutines
// OSCILLATOR_Init
// Return Value : None
// Parameters   : None
// This routine initializes the system clock to use the internal 24 MHz / 8
// oscillator as its clock source.  Also enables missing clock detector reset.
   U8 SFRPAGE_save = SFRPAGE;
   SFRPAGE = CONFIG_PAGE;
   OSCICN = 0x84;                      // Configure internal oscillator for
                                       // 24 MHz / 8
   RSTSRC = 0x04;                      // Enable missing clock detector
   SFRPAGE = SFRPAGE_save;
// PCA_Init
// This routine initializes the PCA to use the SYSCLK / 12
// as its clock source.  It also sets the offset value by writing to PCA0CPL2.
void PCA_Init()
   PCA0CN     =  0x40;                 // PCA counter enable
   PCA0MD    &= ~0x40 ;                // Watchdog timer disabled
   PCA0MD    &=  0xF1;                 // Timebase selected - System clock / 12
   PCA0CPL5   =  0xFF;                 // Offset value
// PORT_Init
// This function configures the Crossbar and GPIO ports.
// P1.3   digital   push-pull     LED
// P1.4   digital   open-drain    SW1
   P1MDOUT |= 0x08;                    // Enable LED as a push-pull output
   XBR2     = 0x40;                    // Enable crossbar and weak pull-ups
// TIMER2_Init
// Parameters   :
//   1)  int counts - calculated Timer overflow rate
//                    range is positive range of integer: 0 to 32767
// Configure Timer2 to 16-bit auto-reload and generate an interrupt at
// interval specified by <counts> using SYSCLK/48 as its time base.
   TMR2CN  = 0x00;                     // Stop Timer2; Clear TF2;
                                       // use SYSCLK/12 as timebase
   CKCON  &= ~0x60;                    // Timer2 clocked based on T2XCLK;
   TMR2RL  = -counts;                  // Init reload values
   TMR2    = 0xFFFF;                   // Set to reload immediately
   ET2     = 1;                        // Enable Timer2 interrupts
   TR2     = 1;                        // Start Timer2
// Interrupt Service Routines
// Timer2_ISR
// This routine changes the state of the LED whenever Timer2 overflows.
INTERRUPT (TIMER2_ISR, INTERRUPT_TIMER2)
   TF2H = 0;                           // Clear Timer2 interrupt flag
   LED  = !LED;                        // Change state of LED
// End Of File
参与人数 1黑币 +20 收起 理由
admin + 20 共享资料的黑币奖励!
ID:64765 发表于 2021-12-20 10:20 | 只看该作者
正在学习C8051F单片机,学习参考。谢谢分享。
ID:713888 发表于 2021-12-20 19:51 | 只看该作者
单片机,学习参考。谢谢分享
ID:64765 发表于 2022-2-6 13:20 | 只看该作者
正在学习C8081F系列单片机,真是雪中送炭。谢谢分享。
