查看: 4540|回复: 0
Proteus仿真错误[SPICE] TRAN: Timestep too small; timestep = 1.25e-019: troub...
ID:983169 发表于 2021-11-21 17:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下面的编译成功了 但是仿真的时候遇到fatal simulation error encountered跳转之后就这个问题   想知道哪里有问题怎么解决
[SPICE] TRAN:  Timestep too small; timestep = 1.25e-019: trouble with node #00046.
#include <reg51.h>
#define ulong unsigned long
xdata uchar GPS_Buffer[500]  _at_  0X0000;
xdata uchar GPRS_Buffer[500]  _at_  0X01F4;
sbit YCIN_Flag = 0xD5;
sbit Alarm_EN= P2^0;
sbit GPRS_EN= P2^1;
void EX_lnit()
   EX0=1;
   IT0=1;
   PX0 = 1;
   EX1=1;
   IT1=0;
void UART_lnit()
void delay()
void GPS_Rec()
void GPRS_Rec()
void GPRS_Dec()
void GPRS_Comm()
void EX0_int( ) interrupt 0 using 1
   GPRS_EN = 1;
   delay( );
   GPRS_Rec();
   GPRS_Dec();
   GPRS_Comm();
void EX1_int( ) interrupt 2 using 2
   if( Alarm_EN == 0)
      Alarm_EN = 1;
   GPRS_EN = 0;
   GPS_Rec();
void main(void)
    SP=0X50;
    YCIN_Flag = 0;
    GPRS_EN = 0;
    EX_lnit();
    UART_lnit();
    EA=1;
   // Write your code here
   while (1)
      if(YCIN_Flag)
         if(Alarm_EN ==0)
            Alarm_EN = 1;
         GPRS_EN = 0;
         GPS_Rec();
