- #include<reg51.h>
- sbit DIN=P3^0;//与max7219接口定义
- sbit LOAD=P3^1;
- sbit CLK=P3^2;
- sbit key0=P1^0;//8路抢答器按键
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit key4=P1^4;
- sbit key5=P1^5;
- sbit key6=P1^6;
- sbit key7=P1^7;
- sbit key_clear=P2^0;//主持人时间设置、清除
- sbit begin=P2^1;//主持人开始按键
- sbit sounder=P3^7;//蜂鸣器
- unsigned char second=30;//秒表计数值
- unsigned char counter=0;//counter每100,minite加1
- unsigned char people=0;//抢答结果
- unsigned char num_add[]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};//max7219读写地址、内容
- unsigned char num_dat[]={0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89};
- unsigned char keyscan()//键盘扫描函数
- unsigned char keyvalue,temp;
- keyvalue=0;
- P1=0xff;
- temp=P1;
- if(~(P1&temp))
- switch(temp)
- case 0xfe:
- keyvalue=1;
- break;
- case 0xfd:
- keyvalue=2;
- break;
- case 0xfb:
- keyvalue=3;
- break;
- case 0xf7:
- keyvalue=4;
- break;
- case 0xef:
- keyvalue=5;
- break;
- case 0xdf:
- keyvalue=6;
- break;
- case 0xbf:
- keyvalue=7;
- break;
- case 0x7f:
- keyvalue=8;
- break;
- default:
- keyvalue=0;
- break;
- return keyvalue;
- void max7219_send(unsigned char add,unsigned char dat)//向max7219写指令函数
- unsigned char ADS,i,j;
- LOAD=0;
- i=0;
- while(i<16)
- if(i<8)
- ADS=add;
- else
- ADS=dat;
- for(j=8;j>=1;j--)
- DIN=ADS&0x80;
- ADS=ADS<<1;
- CLK=1;
- CLK=0;
- i=i+8;
- LOAD=1;
- void max7219_init()//max7219初始化函数
- max7219_send(0x0c,0x01);
- max7219_send(0x0b,0x07);
- max7219_send(0x0a,0xf5);
- max7219_send(0x09,0xff);
- void time_display(unsigned char x)//时间显示
- unsigned char i,j;
- i=x/10;
- j=x%10;
- max7219_send(num_add[1],num_dat[j]);
- max7219_send(num_add[0],num_dat[i]);
- void scare_display(unsigned char x)//抢答结果显示
- i=x/10;
- j=x%10;
- max7219_send(num_add[3],num_dat[j]);
- max7219_send(num_add[2],num_dat[i]);
- void holderscan()//抢答时间设置,0-60s
- time_display(second);
- scare_display(people);
- if(~key_clear)//如果有键按下,改变抢答时间
- while(~key_clear);
- if(people)//如果抢答结果没有清空,抢答器重置
- second=30;
- people=0;
- if(second<60)
- second++;
- else
- second=0;
- void timer_init()
- EA=1;
- ET0=1;
- TMOD=0x01;
- TH0=0xd8;//设定10ms中断一次
- TL0=0xef;
- void main()
- while(1)
- do{
- holderscan();
- }while(begin);//开始前进行设置,若未按下开始键
- while(~begin);//防抖
- max7219_init(); //芯片初始化
- timer_init(); //中断初始化
- TR0=1; //开始中断
- do{
- people=keyscan();
- }while((!people)&&(second));//运行直到抢答结束或者时间结束
- TR0=0;
- void timer0() interrupt 1
- if(counter<100)
- counter++;
- if(counter==50)
- sounder=0;
- else
- sounder=1;
- counter=0;
- second=second-1;
- TH0=0xd8;//重新装载
- TL0=0xef;
- TR0=1;
Keil代码与Proteus仿真下载:
8位竞赛抢答器.7z
(52.89 KB, 下载次数: 48)
