查看: 751|回复: 2
哪位老哥整过stm32串口硬件流控制的代码啊
ID:630212 发表于 2023-5-25 16:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
90黑币
最佳答案
查看完整内容
以下是一个使用STM32的标准库(HAL库)实现硬件流控制的串口代码,用于控制UART2: #include "stm32f4xx_hal.h" UART_HandleTypeDef huart2; void SystemClock_Config(void); int main(void) { HAL_Init(); SystemClock_Config(); __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_USART2_CLK_ENABLE(); GPIO_InitTypeDef GPIO_InitStruct = {0}; GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3; ...
ID:404160 发表于 2023-5-25 16:28 | 只看该作者
int main(void)
  HAL_Init();
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_RTS_CTS;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    while (1);
  uint8_t buffer[] = "Hello, world!\r\n";
  while (1)
    if (HAL_UART_Transmit(&huart2, buffer, sizeof(buffer), 100) != HAL_OK)
      while (1);
    HAL_Delay(1000);
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 16;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    while (1);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    while (1);
在以上代码中,我们使用了硬件流控制(RTS/CTS)来实现串口的数据传输。在初始化UART时,我们将Mode设置为UART_MODE_TX_RX,以允许UART同时进行发送和接收。我们还将HwFlowCtl设置为UART_HWCONTROL_RTS_CTS,以启用硬件流控制。
此时,CTS引脚应该配置为输入模式,如上述代码所示,我们使用GPIOA2引脚作为CTS。在数据发送时,如果CTS引脚处于逻辑高电平,则UART不会将数据发送到接收端,而会等待CTS引脚返回逻辑低电平,然后再继续发送数据。
请注意,上述代码主要用于示例演示,因此省略了错误处理和异常情况处理。在实际应用中,需要根据具体需求添加适当的错误处理和异常情况处理。
ID:404160 发表于 2023-5-28 17:06 | 只看该作者
int main(void)
  HAL_Init();
    while (1);
  while (1)
      while (1);
    HAL_Delay(1000);
    while (1);
    while (1);
