#include <reg51.h>
#define out0 P0
#define out1 P1
#define out2 P2
void delay(uint y) //延时函数
uchar x=250;
for(;y>0;y--)
while(--x);
x=100;
uchar code string[]=
/*-- 文字: 欢 --*/
/*-- 宋体14; 此字体下对应的点阵为:宽x高=19x19 --*/
/*-- 宽度不是8的倍数,现调整为:宽度x高度=24x19 --*/
0x08,0x68,0xE8,0xC8,0x88,0xE8,0xF8,0x78,0x88,0xF0,0xFE,0xFE,0xE6,0xA0,0x20,0xE0,
0xF0,0x60,0x00,0x00,0xC0,0xE0,0x79,0x1F,0x1F,0x7F,0x78,0xE3,0xC1,0xF8,0x3F,0x1F,
0x7F,0xF9,0xC1,0x80,0x00,0x00,0x80,0x80,0x86,0x9E,0x9C,0x98,0xF8,0xFC,0xFC,0x04,
0x06,0xFE,0xFC,0xF8,0x08,0xF8,0xF8,0xF8,0x00,
/*-- 文字: 迎 --*/
0x80,0xC0,0xC0,0x7F,0x7F,0xC0,0xCF,0x9F,0x9F,0x8C,0x84,0xFF,0xFF,0xFF,0x88,0x9F,
0x9F,0x8F,0x00,0x00,0x00,0x00,0x08,0x18,0xF8,0xF0,0x60,0xFE,0xFE,0xFE,0x80,0xE0,
0x78,0x38,0x10,0x80,0x00,0x00,0x00,0x01,0x01,0x01,0x81,0xF1,0x7F,0x3F,0x03,0x01,
0xFF,0xFF,0x01,0x01,0x01,0x01,0xF1,0xF1,0x00,
/*-- 文字: 光 --*/
0x00,0xFC,0xFC,0xF8,0xFF,0xFF,0xFF,0xC0,0x78,0x3E,0x2F,0x6F,0xE8,0xC8,0xC8,0x0C,
0x0C,0x08,0x00,0x00,0x7F,0x7F,0x3F,0xFF,0xFF,0xFF,0x00,0xFE,0xFE,0x82,0xFE,0xFE,
0xFF,0x83,0xFE,0xFE,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: 临 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
{ uchar i,j,n;
for(j=0;j<4;j++)
for(n=0;n<40;n++)
for(i=0;i<15;i++)
out1=i%15;
out0=string[i*2+j*32];
out2=string[i*2+1+j*32];
delay(4);
delay(40);
out0=0x00; //点阵正极接P0和P2口,所以给0熄灭
out2=0x00;
