帖子
查看: 677|回复: 0
单片机第一个点灯程序
ID:1126656 发表于 2024-9-22 17:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg51.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/* define constants */
#define FOSC 11059200L
#define T1MS (65536-FOSC/12/1000)   //1ms timer calculation method in 12T mode
/* define SFR */
sbit TEST_LED = P1^0;               //work LED, flash once per second
/* define variables */
WORD count;                         //1000 times counter
/* Timer0 interrupt routine */
void tm0_isr() interrupt 1
    TL0 = T1MS;                     //reload timer0 low byte
    TH0 = T1MS >> 8;                //reload timer0 high byte
    if (count-- == 0)               //1ms * 1000 -> 1s
        count = 1000;               //reset counter
        TEST_LED = ! TEST_LED;      //work LED flash
/* main program */
    TMOD = 0x01;                    //set timer0 as mode1 (16-bit)
    TL0 = T1MS;                     //initial timer0 low byte
    TH0 = T1MS >> 8;                //initial timer0 high byte
    TR0 = 1;                        //timer0 start running
    ET0 = 1;                        //enable timer0 interrupt
    EA = 1;                         //open global interrupt switch
    count = 0;                      //initial counter
    while (1);                      //loop
举报
