查看: 3671|回复: 1
无线红外模块-AVR程序代码
ID:51024 发表于 2014-7-12 01:56 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
以前学的AVR写的一些程序,分享一下
#include
#include
// Alphanumeric LCD Module functions
#asm
   .equ __lcd_port=0x18 ;PORTB
#endasm
#include
uchar startflag=0,bitnum,irtime,irprosok,irreceok;
uchar irdata[33],dis[8],ircode[4];
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
if(startflag==1)
         if(irtime>=32)
                 bitnum=0;
         irdata[bitnum]=irtime;
         irtime=0;
         bitnum++;
         if(bitnum==33)
                       bitnum=0;
                       irreceok=1;
if(startflag==0)
startflag=1;
irtime=0;
// Timer 0 output compare interrupt service routine
interrupt [TIM0_COMP] void timer0_comp_isr(void)
irtime++;
void irpros(void)
uchar k,value,i,j;
k=1;
for(j=0;j<4;j++)
for(i=0;i<8;i++)
value=value>>1;
if(irdata[k]>6)
value=value|0x80;
k++;
ircode[j]=value;
irprosok=1;
void irwork(void)
dis[0]=ircode[0]/16;
dis[1]=ircode[0];
dis[2]=ircode[1]/16;
dis[3]=ircode[1];
dis[4]=ircode[2]/16;
dis[5]=ircode[2];
dis[6]=ircode[3]/16;
dis[7]=ircode[3];
void display_lcd()
lcd_gotoxy(0,0);
lcd_putchar(dis[0]+48);
lcd_putchar(dis[1]+48);
lcd_putchar(dis[2]+48);
lcd_putchar(dis[3]+48);
lcd_putchar(dis[4]+48);
lcd_putchar(dis[5]+48);
lcd_putchar(dis[6]+48);
lcd_putchar(dis[7]+48);
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 62.500 kHz
// Mode: CTC top=OCR0
// OC0 output: Disconnected
TCCR0=0x0C;
TCNT0=0x00;
OCR0=0x0f;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Falling Edge
// INT1: Off
// INT2: Off
GICR|=0x40;
MCUCR=0x02;
MCUCSR=0x00;
GIFR=0x40;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x02;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// LCD module initialization
lcd_init(16);
// Global enable interrupts
#asm("sei")
while (1)
      {if(irreceok)
      irpros();
      irreceok=0;
      if(irprosok)
      irwork();
      irprosok=0;
      display_lcd();
ID:143447 发表于 2017-6-29 10:18 | 只看该作者
谢谢 分享不错
