完整程序源代码工程文件下载地址:
使用dsp库的FFT函数测相位.rar
(426.12 KB, 下载次数: 363)
stm32 dsp库下载:http://www.51hei.com/bbs/dpj-35381-1.html
- * @file FFT_Demo/src/main.c
- * @author MCD Application Team
- * @version V2.0.0
- * @date 04/27/2009
- * @brief Main program body
- * @copy
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include <math.h>
- #include "stm3210b_lcd.h"
- #include "stm32_dsp.h"
- #include "table_fft.h"
- #define FreqSample (50*NPT) // 50Hz*64=3200
- #define ScalingFactor 20000 // 幅值系数,最大为32767
- #define PERCENT_DC 0.06 // 直流分量对应的百分比,对应直流分量lBUFMAG[0]=1200
- #define PI 3.1415926
- #define PI2 6.28318530717959 // 2*3.14
- #define NPT 256 /* 采样点数,必须为64,256,1024之一*/
- #if (NPT==64)
- #define cr4_fft_stm32 cr4_fft_64_stm32
- #elif (NPT==256)
- #define cr4_fft_stm32 cr4_fft_256_stm32
- #else
- #define cr4_fft_stm32 cr4_fft_1024_stm32
- error!!!!
- // 使用的ram超过了22K,超过了EK-STM32F仿真板上的STM32F103VBT6的ram
- #endif
- extern volatile uint32_t TimingDelay ;
- long lBUFIN[NPT]; /* Complex input vector */
- long lBUFOUT[NPT]; /* Complex output vector */
- long lBUFMAG[NPT + NPT/2]; /* Magnitude vector */
- float lBUFPHASE[NPT + NPT/2];/* phase vector,单位为度 */
- /* Private function prototypes -----------------------------------------------*/
- void MyDualSweep(uint32_t freqinc1,uint32_t freqinc2);
- void MygSin(long nfill, long Fs, long Freq1, long Freq2, long Ampli);
- void powerMag(long nfill, char* strPara);
- void power_Phase_Radians(long nfill);
- void DSPDemoInit(void);
- int main(void)
- DSPDemoInit();
- while (1)
- MyDualSweep(FreqSample/NPT,6*FreqSample/NPT); // 测试fft
- * @brief Produces a combination of two sinewaves as input signal
- * @param freq1: frequency increment for 1st sweep,频率步进值1
- * Freq2: frequency increment for 2nd sweep,频率步进值2
- * @retval : None
- uint32_t freq;
- freq = freqinc1;
- MygSin(NPT, FreqSample, freq, 0, ScalingFactor);
- cr4_fft_stm32(lBUFOUT, lBUFIN, NPT);
- powerMag(NPT,""); // lBUFIN[0]=1192 ,lBUFIN[1]=20008
- power_Phase_Radians(NPT);
- freq = freqinc1;
- MygSin(NPT, FreqSample, freq, freqinc2, ScalingFactor);
- powerMag(NPT,""); // lBUFIN[0]=1192 ,lBUFIN[1]=20008, lBUFIN[6]=4000
- * @param ill: length of the array holding input signal
- * Fs: sampling frequency
- * Freq1: frequency of the 1st sinewave
- * Freq2: frequency of the 2nd sinewave
- * Ampli: scaling factor
- * @retval : None
- uint32_t i;
- float fFs, fFreq1, fFreq2, fAmpli;
- float fZ,fY;
- fFs = (float) Fs;
- fFreq1 = (float) Freq1;
- fFreq2 = (float) Freq2;
- fAmpli = (float) Ampli;
- for (i=0; i < nfill; i++)
- fY =PERCENT_DC/2 // 相位范围0°----360°
- + sin((196.0*PI/180.0)+PI2 * i * (fFreq1/fFs)) ;
- if (fFreq2)
- fY += 0.2*sin((293.0*PI/180.0)+PI2 * i * (fFreq2/fFs));
- fZ = fAmpli * fY;
- // lBUFIN数组中,每个单元数据高字(高16位)中存储采样数据的实部,低字(低16位)存储采样数据的虚部(总是为0)
- lBUFIN[i]= ((short)fZ) << 16 ; /* sine_cosine (cos=0x0) */
- // 高16bit为实部,低16bit为虚部,没有的话,就用0代替
- * @brief Removes the aliased part of the spectrum (not tested)
- * @param ill: length of the array holding power mag
- * @retval : None
- void onesided(long nfill)
- uint32_t i;
- lBUFMAG[0] = lBUFMAG[0];
- lBUFMAG[nfill/2] = lBUFMAG[nfill/2];
- for (i=1; i < nfill/2; i++)
- lBUFMAG[i] = lBUFMAG[i] + lBUFMAG[nfill-i];
- lBUFMAG[nfill-i] = 0x0;
- * @brief Compute power magnitude of the FFT transform 进行FFT变换,并计算各次谐波幅值
- * : strPara: if set to "1SIDED", removes aliases part of spectrum (not tested)
- * @retval : None
- int32_t lX,lY;
- uint32_t i;
- for (i=0; i < nfill/2; i++)
- lX= (lBUFOUT[i]<<16)>>16; /* 取低16bit,sine_cosine --> cos */
- lY= (lBUFOUT[i] >> 16); /* 取高16bit,sine_cosine --> sin */
- float X= (float)lX*(NPT/32768.0);
- float Y = (float)lY*(NPT/32768.0);
- float Mag = sqrt(X*X+ Y*Y)/nfill;
- lBUFMAG[i] = (uint32_t)(Mag*65536);
- 参考 labwindows的函数 ToPolar1D
- Converts the set of rectangular coordinate points (arrayXReal, arrayXImg) to a
- set of polar coordinate points (magnitude, phase). ToPolar1D obtains the
- element of the polar coordinate set using the following formulas:
- The phase value is in the range [-pi: pi].
- ToPolar1D can perform the operations in place;
- that is, the input and output arrays can be the same.
- Prototype
- AnalysisLibErrType ToPolar1D (double Array_X_Real[], double Array_X_Imaginary[], int Number_of_Elements, double Magnitude[], double Phase_Radians[]);
- int32_t lX,lY;
- uint32_t i;
- float X= NPT*((float)lX)/32768;
- float Y = NPT*((float)lY)/32768;
- float phase = atan(Y/X);
- if (Y>=0)
- if (X>=0)
- else
- phase+=PI;
- else
- if (X>=0)
- phase+=PI2;
- else
- phase+=PI;
- lBUFPHASE[i] = phase*180.0/PI;
- * @brief Inserts a delay time.
- * @param ount: specifies the delay time length (time base 10 ms).
- * @retval : None
- void Delay(uint32_t nCount)
- /* Configure the systick */
- __enable_irq();
- /* Setup SysTick Timer for 10 msec interrupts */
- if (SysTick_Config(SystemFrequency /100)) /* SystemFrequency is defined in
- 搒ystem_stm32f10x.h?and equal to HCLK frequency */
- /* Capture error */
- while (1);
- /* Enable the SysTick Counter */
- TimingDelay = nCount;
- while (TimingDelay ) {}
- TimingDelay=0;
- __disable_irq();
- * @brief Initializes the DSP lib demo (clock, peripherals and LCD).
- * @param None
- * @retval : None
- GPIO_InitTypeDef GPIO_InitStructure;
- ErrorStatus HSEStartUpStatus = ERROR;
- /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
- /* RCC system reset(for debug purpose) */
- RCC_DeInit();
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2);
- /* HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- /* PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);
- /* PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);
- /* PLLCLK = 8MHz * 9 = 72 MHz */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- /* Enable PLL */
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- while(RCC_GetSYSCLKSource() != 0x08)
- /* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE and AFIO clocks */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |RCC_APB2Periph_GPIOC
- | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
- /* TIM1 Periph clock enable */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
- /* SPI2 Periph clock enable */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
- /* TIM2 and TIM4 clocks enable */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM4, ENABLE);
- /*------------------- Resources Initialization -----------------------------*/
- /* GPIO Configuration */
- /* Configure PC.06 and PC.07 as Output push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- /*------------------- Drivers Initialization -------------------------------*/
- /* Initialize the LCD */
- STM3210B_LCD_Init();
- /* Clear the LCD */
- LCD_Clear(White);
- LCD_SetTextColor(White);
- LCD_SetBackColor(Black);
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval : None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
- * @file FFT_Demo/src/stm3210b_lcd.c
- * @version V2.0.0
- * @brief This file includes the LCD driver for AM-240320LTNQW00H
- * (LCD_HX8312), AM-240320L8TNQW00H (LCD_ILI9320),
- * AM-240320LDTNQW00H (LCD_SPFD5408B) Liquid Crystal Display
- * Module of STM3210B-EVAL board.
- * @copy
- #include "fonts.h"
- /** @addtogroup FFT_Demo
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define LCD_ILI9320 0x9320
- #define LCD_HX8312 0x8312
- #define LCD_SPFD5408 0x5408
- #define START_BYTE 0x70
- #define SET_INDEX 0x00
- #define READ_STATUS 0x01
- #define LCD_WRITE_REG 0x02
- #define LCD_READ_REG 0x03
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Global variables to set the written text color */
- static __IO uint16_t TextColor = 0x0000, BackColor = 0xFFFF;
- static __IO uint32_t LCDType = LCD_ILI9320;
- static void LCD_WriteRegHX8312(uint8_t LCD_Reg, uint8_t LCD_RegValue);
- static void LCD_WriteRegILI9320(uint8_t LCD_Reg, uint16_t LCD_RegValue);
- /* Private functions ---------------------------------------------------------*/
- * @brief Setups the LCD.
- * @param None
- * @retval : None
- void LCD_Setup(void)
- /* Configure the LCD Control pins --------------------------------------------*/
- LCD_CtrlLinesConfig();
- /* Configure the SPI2 interface ----------------------------------------------*/
- LCD_SPIConfig();
- if(LCDType == LCD_ILI9320)
- Delay(5); /* Delay 50 ms */
- /* Start Initial Sequence ------------------------------------------------*/
- LCD_WriteReg(R229, 0x8000); /* Set the internal vcore voltage */
- LCD_WriteReg(R0, 0x0001); /* Start internal OSC. */
- LCD_WriteReg(R1, 0x0100); /* set SS and SM bit */
- LCD_WriteReg(R2, 0x0700); /* set 1 line inversion */
- LCD_WriteReg(R3, 0x1030); /* set GRAM write direction and BGR=1. */
- LCD_WriteReg(R4, 0x0000); /* Resize register */
- LCD_WriteReg(R8, 0x0202); /* set the back porch and front porch */
- LCD_WriteReg(R9, 0x0000); /* set non-display area refresh cycle ISC[3:0] */
- LCD_WriteReg(R10, 0x0000); /* FMARK function */
- LCD_WriteReg(R12, 0x0000); /* RGB interface setting */
- LCD_WriteReg(R13, 0x0000); /* Frame marker Position */
- LCD_WriteReg(R15, 0x0000); /* RGB interface polarity */
- /* Power On sequence -----------------------------------------------------*/
- LCD_WriteReg(R16, 0x0000); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
- LCD_WriteReg(R17, 0x0000); /* DC1[2:0], DC0[2:0], VC[2:0] */
- LCD_WriteReg(R18, 0x0000); /* VREG1OUT voltage */
- LCD_WriteReg(R19, 0x0000); /* VDV[4:0] for VCOM amplitude */
- Delay(20); /* Dis-charge capacitor power voltage (200ms) */
- LCD_WriteReg(R16, 0x17B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
- LCD_WriteReg(R17, 0x0137); /* DC1[2:0], DC0[2:0], VC[2:0] */
- LCD_WriteReg(R18, 0x0139); /* VREG1OUT voltage */
- LCD_WriteReg(R19, 0x1d00); /* VDV[4:0] for VCOM amplitude */
- LCD_WriteReg(R41, 0x0013); /* VCM[4:0] for VCOMH */
- LCD_WriteReg(R32, 0x0000); /* GRAM horizontal Address */
- LCD_WriteReg(R33, 0x0000); /* GRAM Vertical Address */
- /* Adjust the Gamma Curve ------------------------------------------------*/
- LCD_WriteReg(R48, 0x0006);
- LCD_WriteReg(R49, 0x0101);
- LCD_WriteReg(R50, 0x0003);
- LCD_WriteReg(R53, 0x0106);
- LCD_WriteReg(R54, 0x0b02);
- LCD_WriteReg(R55, 0x0302);
- LCD_WriteReg(R56, 0x0707);
- LCD_WriteReg(R57, 0x0007);
- LCD_WriteReg(R60, 0x0600);
- LCD_WriteReg(R61, 0x020b);
- /* Set GRAM area ---------------------------------------------------------*/
- LCD_WriteReg(R80, 0x0000); /* Horizontal GRAM Start Address */
- LCD_WriteReg(R81, 0x00EF); /* Horizontal GRAM End Address */
- LCD_WriteReg(R82, 0x0000); /* Vertical GRAM Start Address */
- LCD_WriteReg(R83, 0x013F); /* Vertical GRAM End Address */
- LCD_WriteReg(R96, 0x2700); /* Gate Scan Line */
- LCD_WriteReg(R97, 0x0001); /* NDL,VLE, REV */
- LCD_WriteReg(R106, 0x0000); /* set scrolling line */
- /* Partial Display Control -----------------------------------------------*/
- LCD_WriteReg(R128, 0x0000);
- LCD_WriteReg(R129, 0x0000);
- LCD_WriteReg(R130, 0x0000);
- LCD_WriteReg(R131, 0x0000);
- LCD_WriteReg(R132, 0x0000);
- LCD_WriteReg(R133, 0x0000);
- /* Panel Control ---------------------------------------------------------*/
- LCD_WriteReg(R144, 0x0010);
- LCD_WriteReg(R146, 0x0000);
- LCD_WriteReg(R147, 0x0003);
- LCD_WriteReg(R149, 0x0110);
- LCD_WriteReg(R151, 0x0000);
- LCD_WriteReg(R152, 0x0000);
- /* Set GRAM write direction and BGR = 1 */
- /* I/D=01 (Horizontal : increment, Vertical : decrement) */
- /* AM=1 (address is updated in vertical writing direction) */
- LCD_WriteReg(R3, 0x1018);
- LCD_WriteReg(R7, 0x0173); /* 262K color and display ON */
- else if(LCDType == LCD_SPFD5408)
- /* Start Initial Sequence --------------------------------------------------*/
- LCD_WriteReg(R227, 0x3008); /* Set internal timing */
- LCD_WriteReg(R231, 0x0012); /* Set internal timing */
- LCD_WriteReg(R239, 0x1231); /* Set internal timing */
- LCD_WriteReg(R1, 0x0100); /* Set SS and SM bit */
- LCD_WriteReg(R2, 0x0700); /* Set 1 line inversion */
- LCD_WriteReg(R3, 0x1030); /* Set GRAM write direction and BGR=1. */
- LCD_WriteReg(R8, 0x0202); /* Set the back porch and front porch */
- LCD_WriteReg(R9, 0x0000); /* Set non-display area refresh cycle ISC[3:0] */
- /* Power On sequence -------------------------------------------------------*/
- LCD_WriteReg(R17, 0x0007); /* DC1[2:0], DC0[2:0], VC[2:0] */
- LCD_WriteReg(R16, 0x12B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
- LCD_WriteReg(R18, 0x01BD); /* External reference voltage= Vci */
- LCD_WriteReg(R19, 0x1400); /* VDV[4:0] for VCOM amplitude */
- LCD_WriteReg(R41, 0x000E); /* VCM[4:0] for VCOMH */
- LCD_WriteReg(R33, 0x013F); /* GRAM Vertical Address */
- /* Adjust the Gamma Curve --------------------------------------------------*/
- LCD_WriteReg(R48, 0x0007);
- LCD_WriteReg(R49, 0x0302);
- LCD_WriteReg(R50, 0x0105);
- LCD_WriteReg(R53, 0x0206);
- LCD_WriteReg(R54, 0x0808);
- LCD_WriteReg(R55, 0x0206);
- LCD_WriteReg(R56, 0x0504);
- LCD_WriteReg(R60, 0x0105);
- LCD_WriteReg(R61, 0x0808);
- /* Set GRAM area -----------------------------------------------------------*/
- LCD_WriteReg(R96, 0xA700); /* Gate Scan Line */
- LCD_WriteReg(R106, 0x0000); /* Set scrolling line */
- /* Partial Display Control -------------------------------------------------*/
- /* Panel Control -----------------------------------------------------------*/
- I/D=01 (Horizontal : increment, Vertical : decrement)
- AM=1 (address is updated in vertical writing direction) */
- LCD_WriteReg(R7, 0x0112); /* 262K color and display ON */
- else if(LCDType == LCD_HX8312)
- /* Enable the LCD Oscillator ---------------------------------------------*/
- LCD_WriteReg(R1, 0x10);
- LCD_WriteReg(R0, 0xA0);
- LCD_WriteReg(R3, 0x01);
- Delay(1); /* Delay 10 ms */
- LCD_WriteReg(R3, 0x00);
- LCD_WriteReg(R43, 0x04);
- LCD_WriteReg(R40, 0x18);
- LCD_WriteReg(R26, 0x05);
- LCD_WriteReg(R37, 0x05);
- LCD_WriteReg(R25, 0x00);
- /* LCD Power On ----------------------------------------------------------*/
- LCD_WriteReg(R28, 0x73);
- LCD_WriteReg(R36, 0x74);
- LCD_WriteReg(R30, 0x01);
- LCD_WriteReg(R24, 0xC1);
- LCD_WriteReg(R24, 0xE1);
- LCD_WriteReg(R24, 0xF1);
- Delay(6); /* Delay 60 ms */
- LCD_WriteReg(R24, 0xF5);
- LCD_WriteReg(R27, 0x09);
- LCD_WriteReg(R31, 0x11);
- LCD_WriteReg(R32, 0x0E);
- LCD_WriteReg(R30, 0x81);
- /* Chip Set --------------------------------------------------------------*/
- LCD_WriteReg(R157, 0x00);
- LCD_WriteReg(R192, 0x00);
- LCD_WriteReg(R14, 0x00);
- LCD_WriteReg(R15, 0x00);
- LCD_WriteReg(R16, 0x00);
- LCD_WriteReg(R17, 0x00);
- LCD_WriteReg(R18, 0x00);
- LCD_WriteReg(R19, 0x00);
- LCD_WriteReg(R20, 0x00);
- LCD_WriteReg(R21, 0x00);
- LCD_WriteReg(R22, 0x00);
- LCD_WriteReg(R23, 0x00);
- LCD_WriteReg(R52, 0x01);
- LCD_WriteReg(R53, 0x00);
- LCD_WriteReg(R75, 0x00);
- LCD_WriteReg(R76, 0x00);
- LCD_WriteReg(R78, 0x00);
- LCD_WriteReg(R79, 0x00);
- LCD_WriteReg(R80, 0x00);
- LCD_WriteReg(R60, 0x00);
- LCD_WriteReg(R61, 0x00);
- LCD_WriteReg(R62, 0x01);
- LCD_WriteReg(R63, 0x3F);
- LCD_WriteReg(R64, 0x02);
- LCD_WriteReg(R65, 0x02);
- LCD_WriteReg(R66, 0x00);
- LCD_WriteReg(R67, 0x00);
- LCD_WriteReg(R68, 0x00);
- LCD_WriteReg(R69, 0x00);
- LCD_WriteReg(R70, 0xEF);
- LCD_WriteReg(R71, 0x00);
- LCD_WriteReg(R72, 0x00);
- LCD_WriteReg(R73, 0x01);
- LCD_WriteReg(R74, 0x3F);
- LCD_WriteReg(R29, 0x08); /* R29:Gate scan direction setting */
- LCD_WriteReg(R134, 0x00);
- LCD_WriteReg(R135, 0x30);
- LCD_WriteReg(R136, 0x02);
- LCD_WriteReg(R137, 0x05);
- LCD_WriteReg(R141, 0x01); /* R141:Register set-up mode for one line clock */
- LCD_WriteReg(R139, 0x20); /* R139:One line SYSCLK number in one-line */
- LCD_WriteReg(R51, 0x01); /* R51:N line inversion setting */
- LCD_WriteReg(R55, 0x01); /* R55:Scanning method setting */
- LCD_WriteReg(R118, 0x00);
- /* Gamma Set -------------------------------------------------------------*/
- LCD_WriteReg(R143, 0x10);
- LCD_WriteReg(R144, 0x67);
- LCD_WriteReg(R145, 0x07);
- LCD_WriteReg(R146, 0x65);
- LCD_WriteReg(R147, 0x07);
- LCD_WriteReg(R148, 0x01);
- LCD_WriteReg(R149, 0x76);
- LCD_WriteReg(R150, 0x56);
- LCD_WriteReg(R151, 0x00);
- LCD_WriteReg(R152, 0x06);
- LCD_WriteReg(R153, 0x03);
- LCD_WriteReg(R154, 0x00);
- /* Display On ------------------------------------------------------------*/
- LCD_WriteReg(R1, 0x50);
- LCD_WriteReg(R5, 0x04);
- LCD_WriteReg(R0, 0x80);
- LCD_WriteReg(R59, 0x01);
- Delay(4); /* Delay 40 ms */
- LCD_WriteReg(R0, 0x20);
- * @brief Initializes the LCD.
- * @param None
- * @retval : None
- void STM3210B_LCD_Init(void)
- /* Setups the LCD */
- LCD_Setup();
- /* Try to read new LCD controller ID 0x9320 */
- if (LCD_ReadReg(R0) == LCD_ILI9320)
- LCDType = LCD_ILI9320;
- else
- LCDType = LCD_SPFD5408;
- LCD_Setup();
- /* Try to read new LCD controller ID 0x5408 */
- if (LCD_ReadReg(R0) != LCD_SPFD5408)
- LCDType = LCD_HX8312;
- LCD_Setup();
- * @brief Sets the Text color.
- * @param Color: specifies the Text color code RGB(5-6-5).
- * and LCD_DrawPicture functions.
- * @retval : None
- void LCD_SetTextColor(__IO uint16_t Color)
- TextColor = Color;
- * @brief Sets the Background color.
- * @param Color: specifies the Background color code RGB(5-6-5).
- * LCD_DrawChar and LCD_DrawPicture functions.
- * @retval : None
- void LCD_SetBackColor(__IO uint16_t Color)
- BackColor = Color;
- * @brief Clears the selected line.
- * @param Line: the Line to be cleared.
- * This parameter can be one of the following values:
- * @arg Linex: where x can be 0..9
- * @retval : None
- void LCD_ClearLine(uint8_t Line)
- LCD_DisplayStringLine(Line, " ");
- * @brief Clears the hole LCD.
- * @param lor: the color of the background.
- * @retval : None
- void LCD_Clear(uint16_t Color)
- uint32_t index = 0;
- LCD_SetCursor(0x00, 0x013F);
- if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
- LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
- for(index = 0; index < 76800; index++)
- LCD_WriteRAM(Color);
- LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
- * @brief Sets the cursor position.
- * @param Xpos: specifies the X position.
- * @param Ypos: specifies the Y position.
- * @retval : None
- void LCD_SetCursor(uint8_t Xpos, uint16_t Ypos)
- LCD_WriteReg(R32, Xpos);
- LCD_WriteReg(R33, Ypos);
- LCD_WriteReg(R66, Xpos);
- LCD_WriteReg(R67, ((Ypos & 0x100)>> 8));
- LCD_WriteReg(R68, (Ypos & 0xFF));
- * @brief Draws a character on LCD.
- * @param Xpos: the Line where to display the character shape.
- * @param Linex: where x can be 0..9
- * @param Ypos: start column address.
- * @param c: pointer to the character data.
- * @retval : None
- void LCD_DrawChar(uint8_t Xpos, uint16_t Ypos, const uint16_t *c)
- uint32_t index = 0, i = 0;
- uint8_t Xaddress = 0;
- Xaddress = Xpos;
- LCD_SetCursor(Xaddress, Ypos);
- for(index = 0; index < 24; index++)
- for(i = 0; i < 16; i++)
- if((c[index] & (1 << i)) == 0x00)
- LCD_WriteRAM(BackColor);
- else
- LCD_WriteRAM(TextColor);
- Xaddress++;
- * @brief Displays one character (16dots width, 24dots height).
- * @param Line: the Line where to display the character shape .
- * @param Column: start column address.
- * @param Ascii: character ascii code, must be between 0x20 and 0x7E.
- * @retval : None
- void LCD_DisplayChar(uint8_t Line, uint16_t Column, uint8_t Ascii)
- Ascii -= 32;
- LCD_DrawChar(Line, Column, &ASCII_Table[Ascii * 24]);
- * @brief Displays a maximum of 20 char on the LCD.
- * @param *ptr: pointer to string to display on LCD.
- * @retval : None
- void LCD_DisplayStringLine(uint8_t Line, uint8_t *ptr)
- uint32_t i = 0;
- uint16_t refcolumn = 319;
- /* Send the string character by character on lCD */
- while ((*ptr != 0) & (i < 20))
- /* Display one character on LCD */
- LCD_DisplayChar(Line, refcolumn, *ptr);
- /* Decrement the column position by 16 */
- refcolumn -= 16;
- /* Point on the next character */
- ptr++;
- /* Increment the character counter */
- i++;
- * @brief Sets a display window
- * @param Xpos: specifies the X buttom left position.
- * @param Ypos: specifies the Y buttom left position.
- * @param Height: display window height.
- * @param Width: display window width.
- * @retval : None
- void LCD_SetDisplayWindow(uint8_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width)
- /* Horizontal GRAM Start Address */
- if(Xpos >= Height)
- LCD_WriteReg(R80, (Xpos - Height + 1));
- else
- LCD_WriteReg(R80, 0);
- /* Horizontal GRAM End Address */
- LCD_WriteReg(R81, Xpos);
- /* Vertical GRAM Start Address */
- if(Ypos >= Width)
- LCD_WriteReg(R82, (Ypos - Width + 1));
- else
- LCD_WriteReg(R82, 0);
- /* Vertical GRAM End Address */
- LCD_WriteReg(R83, Ypos);
- LCD_WriteReg(R1, 0xD0);
- LCD_WriteReg(R5, 0x14);
- LCD_WriteReg(R69, (Xpos - Height + 1));
- LCD_WriteReg(R70, Xpos);
- LCD_WriteReg(R71, (((Ypos - Width + 1) & 0x100)>> 8));
- LCD_WriteReg(R72, ((Ypos - Width + 1) & 0xFF));
- LCD_WriteReg(R73, ((Ypos & 0x100)>> 8));
- LCD_WriteReg(R74, (Ypos & 0xFF));
- LCD_SetCursor(Xpos, Ypos);
- * @brief Disables LCD Window mode.
- * @param None
- * @retval : None
- void LCD_WindowModeDisable(void)
- LCD_SetDisplayWindow(239, 0x13F, 240, 320);
- * @brief Displays a line.
- * @param Length: line length.
- * @param Direction: line direction.
- * This parameter can be one of the following values: Vertical
- * or Horizontal.
- * @retval : None
- void LCD_DrawLine(uint8_t Xpos, uint16_t Ypos, uint16_t Length, uint8_t Direction)
- uint32_t i = 0;
- if(Direction == Horizontal)
- for(i = 0; i < Length; i++)
- else
- LCD_WriteRAMWord(TextColor);
- Xpos++;
- * @brief Displays a rectangle.
- * @param Height: display rectangle height.
- * @param Width: display rectangle width.
- * @retval : None
- void LCD_DrawRect(uint8_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width)
- LCD_DrawLine(Xpos, Ypos, Width, Horizontal);
- LCD_DrawLine((Xpos + Height), Ypos, Width, Horizontal);
- LCD_DrawLine(Xpos, Ypos, Height, Vertical);
- LCD_DrawLine(Xpos, (Ypos - Width + 1), Height, Vertical);
- * @brief Displays a circle.
- * @retval : None
- void LCD_DrawCircle(uint8_t Xpos, uint16_t Ypos, uint16_t Radius)
- int32_t D;/* Decision Variable */
- uint32_t CurX;/* Current X Value */
- uint32_t CurY;/* Current Y Value */
- D = 3 - (Radius << 1);
- CurX = 0;
- CurY = Radius;
- while (CurX <= CurY)
- LCD_SetCursor(Xpos + CurX, Ypos + CurY);
- LCD_SetCursor(Xpos + CurX, Ypos - CurY);
- LCD_SetCursor(Xpos - CurX, Ypos + CurY);
- LCD_SetCursor(Xpos - CurX, Ypos - CurY);
- LCD_SetCursor(Xpos + CurY, Ypos + CurX);
- LCD_SetCursor(Xpos + CurY, Ypos - CurX);
- LCD_SetCursor(Xpos - CurY, Ypos + CurX);
- LCD_SetCursor(Xpos - CurY, Ypos - CurX);
- if (D < 0)
- D += (CurX << 2) + 6;
- else
- D += ((CurX - CurY) << 2) + 10;
- CurY--;
- CurX++;
- * @brief Displays a monocolor picture.
- * @param Pict: pointer to the picture array.
- * @retval : None
- void LCD_DrawMonoPict(const uint32_t *Pict)
- LCD_SetCursor(0, 319);
- for(index = 0; index < 2400; index++)
- for(i = 0; i < 32; i++)
- if((Pict[index] & (1 << i)) == 0x00)
- else
- * @brief Reset LCD control line(/CS) and Send Start-Byte
- * @param Start_Byte: the Start-Byte to be sent
- * @retval : None
- void LCD_nCS_StartByte(uint8_t Start_Byte)
- LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_RESET);
- SPI_I2S_SendData(SPI2, Start_Byte);
- while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
- * @brief Writes index to select the LCD register.
- * @param LCD_Reg: address of the selected register.
- * @retval : None
- void LCD_WriteRegIndex(uint8_t LCD_Reg)
- /* Reset LCD control line(/CS) and Send Start-Byte */
- LCD_nCS_StartByte(START_BYTE | SET_INDEX);
- /* Write 16-bit Reg Index (High Byte is 0) */
- SPI_I2S_SendData(SPI2, 0x00);
- SPI_I2S_SendData(SPI2, LCD_Reg);
- * @brief Writes to the selected LCD ILI9320 register.
- * @arg LCD_RegValue: value to write to the selected register.
- * @retval : None
- /* Write 16-bit Index (then Write Reg) */
- LCD_WriteRegIndex(LCD_Reg);
- /* Write 16-bit Reg */
- LCD_nCS_StartByte(START_BYTE | LCD_WRITE_REG);
- SPI_I2S_SendData(SPI2, LCD_RegValue>>8);
- SPI_I2S_SendData(SPI2, (LCD_RegValue & 0xFF));
- * @brief Reads the selected LCD Register.
- * @param None
- * @retval : LCD Register Value.
- uint16_t LCD_ReadReg(uint8_t LCD_Reg)
- uint16_t tmp = 0;
- uint8_t i = 0;
- /* SPI2 prescaler: 4 */
- SPI2->CR1 &= 0xFFC7;
- SPI2->CR1 |= 0x0008;
- /* Write 16-bit Index (then Read Reg) */
- /* Read 16-bit Reg */
- LCD_nCS_StartByte(START_BYTE | LCD_READ_REG);
- for(i = 0; i < 5; i++)
- SPI_I2S_SendData(SPI2, 0xFF);
- /* One byte of invalid dummy data read after the start byte */
- while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
- SPI_I2S_ReceiveData(SPI2);
- /* Read upper byte */
- /* Read lower byte */
- tmp = SPI_I2S_ReceiveData(SPI2);
- tmp = ((tmp & 0xFF) << 8) | SPI_I2S_ReceiveData(SPI2);
- /* SPI2 prescaler: 2 */
- return tmp;
- * @brief Prepare to write to the LCD RAM.
- * @param None
- * @retval : None
- void LCD_WriteRAM_Prepare(void)
- LCD_WriteRegIndex(R34); /* Select GRAM Reg */
- * @brief Writes 1 word to the LCD RAM.
- * @param RGB_Code: the pixel color in RGB mode (5-6-5).
- * @retval : None
- void LCD_WriteRAMWord(uint16_t RGB_Code)
- LCD_WriteRAM(RGB_Code);
- * @brief Writes to the selected LCD HX8312 register.
- * @retval : None
- uint16_t tmp = 0;
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_RESET);
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_RESET);
- tmp = LCD_Reg << 8;
- tmp |= LCD_RegValue;
- SPI_I2S_SendData(SPI2, tmp);
- * @brief Writes to the selected LCD register.
- * @retval : None
- void LCD_WriteReg(uint8_t LCD_Reg, uint16_t LCD_RegValue)
- LCD_WriteRegILI9320(LCD_Reg, LCD_RegValue);
- LCD_WriteRegHX8312(LCD_Reg, ((uint8_t)LCD_RegValue));
- * @brief Writes to the LCD RAM.
- * @retval : None
- void LCD_WriteRAM(uint16_t RGB_Code)
- SPI_I2S_SendData(SPI2, RGB_Code >> 8);
- SPI_I2S_SendData(SPI2, RGB_Code & 0xFF);
- if(LCDType == LCD_HX8312)
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_SET);
- SPI_I2S_SendData(SPI2, RGB_Code);
- * @brief Power on the LCD.
- * @param None
- * @retval : None
- void LCD_PowerOn(void)
- /* Power On sequence ---------------------------------------------------------*/
- Delay(5); /* delay 50 ms */
- /* Power On Set */
- * @brief Enables the Display.
- * @param None
- * @retval : None
- void LCD_DisplayOn(void)
- /* Display On */
- /* Display On */
- * @brief Disables the Display.
- * @param None
- * @retval : None
- void LCD_DisplayOff(void)
- /* Display Off */
- LCD_WriteReg(R7, 0x0);
- /* Display Off */
- LCD_WriteReg(R59, 0x00);
- * @brief Configures LCD control lines in Output Push-Pull mode.
- * @param None
- * @retval : None
- void LCD_CtrlLinesConfig(void)
- /* Configure NCS (PB.02) in Output Push-Pull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- /* Configure NWR(RNW), RS (PD.15, PD.07) in Output Push-Pull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_15;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_SET);
- * @brief Sets or reset LCD control lines.
- * @param GPIOx: where x can be B or D to select the GPIO peripheral.
- * @param CtrlPins: the Control line. This parameter can be:
- * @param CtrlPin_NCS: Chip Select pin (PB.02)
- * @param CtrlPin_NWR: Read/Write Selection pin (PD.15)
- * @param CtrlPin_RS: Register/RAM Selection pin (PD.07)
- * @param BitVal: specifies the value to be written to the selected bit.
- * This parameter can be:
- * @param Bit_RESET: to clear the port pin
- * @param Bit_SET: to set the port pin
- * @retval : None
- void LCD_CtrlLinesWrite(GPIO_TypeDef* GPIOx, uint16_t CtrlPins, BitAction BitVal)
- /* Set or Reset the control line */
- GPIO_WriteBit(GPIOx, CtrlPins, BitVal);
- * @brief Configures the SPI2 interface.
- * @param None
- * @retval : None
- void LCD_SPIConfig(void)
- SPI_InitTypeDef SPI_InitStructure;
- /* Enable GPIOB clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- /* Enable SPI2 clock */
- /* Configure SPI2 pins: NSS, SCK, MISO and MOSI */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- SPI_I2S_DeInit(SPI2);
- /* SPI2 Config */
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
- SPI_Init(SPI2, &SPI_InitStructure);
- /* SPI2 enable */
- SPI_Cmd(SPI2, ENABLE);
