查看: 3366|回复: 5
LCD1602万年字体闪黑块,球大神解答
ID:89734 发表于 2016-1-5 16:00 | 显示全部楼层 |阅读模式
仿真没问题的,字体出来会闪现黑块,求解答。
ID:89734 发表于 2016-1-5 16:02 | 显示全部楼层
黑块是一闪一闪的,下面是我的程序
#include<intrins.h>
#include<AT89X52.H>
uchar code digit[]={"0123456789"};     //定义字符数组显示数字
uchar code Error[]="Error!Check!";     //说明没有检测到DS18B20
uchar code table[]="Alarm Clock";
uchar code table1[]="0123456789";
uchar code table2[]="WEEK";
uchar code table3[]="Today is fine!";
uchar code table4[]="HELLO!";
uchar code table5[]="Made by Kaili";
uchar code table6[]="Happy new year!!";//1.1
//uchar code table7[]="Valentine's Day"; //2.14
以下是对液晶模块的操作程序
sbit RS=P2^5;           //寄存器选择位,将RS位定义为P2.0引脚
sbit RW=P2^6;           //读写选择位,将RW位定义为P2.1引脚
sbit E=P2^7;            //使能信号位,将E位定义为P2.2引脚
sbit BF=P0^7;           //忙碌标志位,,将BF位定义为P0.7引脚
sbit ceshi=P1^0;
sbit T_RST=P1^6;
sbit T_CLK=P1^4;
sbit T_IO=P1^5;
sbit beep=P1^7;
sbit key1=P3^0;          //调闹钟的小时即x
sbit key2=P3^1;          //调闹钟的分钟即y
sbit key4=P3^5;          //显示切换
sbit key3=P3^2;
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit io=P1^1;
uchar time;   //设置全局变量,专门用于严格延时
static uchar x=0x08,y=30;
uchar t_sec,sec1,sec2;
uchar t_min,min1,min2;
uchar t_hour,hour1,hour2;
uchar t_mon,mon1,mon2;
uchar t_day,day1,day2;
uchar t_year,year1,year2;
uchar week,week1;
uchar com,inf;
/*定义变量*/
uchar data_byte=0,count,SHISHI,SHIGE,WENSHI,WENGE;
uint TH_data,TL_data,RH_data,RL_data,CK_data;
uint TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
uchar num;
/*10微妙延时程序*/
void delay1()
         unsigned char i;
         for(i=0; i<3; i++);
函数功能:延时若干微秒
入口参数:n
void delaynus(unsigned char n)
unsigned char i;
for(i=0;i<n;i++)
函数功能:延时1ms
(3j+2)*i=(3×33+2)×10=1010(微秒),可以认为是1毫秒
void delay1ms()
        uchar i,j;
        for(i=0;i<10;i++)
         for(j=0;j<33;j++)
函数功能:延时若干毫秒
入口参数:n
void delaynms(uchar n)
   uchar i;
        for(i=0;i<n;i++)
           delay1ms();
/**********************DHT11模块**********************/
uchar receive_byte()//接收一个字节
         uchar i,temp;
         for(i=0;i<8; i++)
                  count = 2;
                  while((!io)&&count++)//等待50us低电平结束并防止死循环
                  temp = 0;
                  delay1();
                  delay1();
                  delay1();
                  if (io==1)
                           temp = 1;
                           count = 2;
                           while(io && count++);
                   temp = 0;
                   data_byte<<=1;
                   data_byte|=temp;
         return (data_byte);
/*DHT11开始函数*/
void read_io()//开始信号读数据并校验
         io = 0;
         delaynms(18);//主机拉低18ms
         io=1;//DATA总线由上拉电阻拉高 主机延时20us
         delay1();
         delay1();
         delay1();
         delay1();
         io = 1;//主机设置为输入高电平判断从机响应信号
         if(!io)
                  count = 2;
                  while((!io)&&count++);//判断DHT11发出80us低电平响应信号是否结束
                  count = 2;
                  while(io && count++);//判断DHT11拉高总线80us高电平是否结束
                  RH_temp = receive_byte();
                  RL_temp = receive_byte();
                  TH_temp = receive_byte();
                  TL_temp = receive_byte();
                  CK_temp = receive_byte();
                  io = 1;
                  num = (RH_temp+RL_temp+TH_temp+TL_temp);//数据校验
                  if(num==CK_temp)
                           RH_data=RH_temp;
                           RL_data=RL_temp;
                           TH_data=TH_temp;
                           TL_data=TL_temp;
                           CK_data=CK_temp;
         //湿度整数部分
         SHISHI =  RH_data/10;
         SHIGE =  RH_data%10;
         //温度整数部分
         WENSHI =(char) TH_data/10;
         WENGE = (char)    TH_data%10;
函数功能:判断液晶模块的忙碌状态
返回值:result。result=1,忙碌;result=0,不忙
bit BusyTest(void)
    bit result;
        RS=0;       //根据规定,RS为低电平,RW为高电平时,可以读状态
    RW=1;
    E=1;        //E=1,才允许读写
    _nop_();   //空操作
    _nop_();
    _nop_();
    _nop_();   //空操作四个机器周期,给硬件反应时间
        delaynms(5);
    result=BF;  //将忙碌标志电平赋给result
   E=0;         //将E恢复低电平
   return result;
函数功能:将模式设置指令或显示地址写入液晶模块
入口参数:dictate
void WriteInstruction (uchar dictate)
    while(BusyTest()==1);   //如果忙就等待
           P0=dictate;            //将数据送入P0口,即写入指令或地址
         RS=0;                  //根据规定,RS和R/W同时为低电平时,可以写入指令
         RW=0;
         E=0;                   //E置低电平(根据表8-6,写指令时,E为高脉冲,
                           // 就是让E从0到1发生正跳变,所以应先置"0"
        delaynms(5);
         _nop_();
         _nop_();               //空操作两个机器周期,给硬件反应时间
         _nop_();
         _nop_();
         _nop_();
         delaynms(5);
         E=1;                   //E置高电平
         _nop_();
         _nop_();
         _nop_();
         delaynms(5);
          E=0;                  //当E由高电平跳变成低电平时,液晶模块开始执行命令
        delay1ms();
函数功能:指定字符显示的实际地址
入口参数:x
void WriteAddress(unsigned char x)
     WriteInstruction(x|0x80); //显示位置的确定方法规定为"80H+地址码x"
函数功能:将数据(字符的标准ASCII码)写入液晶模块
入口参数:y(为字符常量)
void WriteData(uchar y)
                     P0=y;           //将数据送入P0口,即将数据写入液晶模块
          RS=1;           //RS为高电平,RW为低电平时,可以写入数据
          RW=0;
            delaynms(5);
          delaynms(5);
          _nop_();
          _nop_();
          _nop_();
         delaynms(5);
          E=1;           //E置高电平
          _nop_();
          _nop_();
          _nop_();
函数功能:对LCD的显示模式进行初始化设置
void LcdInitiate(void)
    delaynms(15);               //延时15ms,首次写指令时应给LCD一段较长的反应时间
    WriteInstruction(0x38);     //显示模式设置:16×2显示,5×7点阵,8位数据接口
                delaynms(5);                //延时5ms ,给硬件一点反应时间
        WriteInstruction(0x38);     //连续三次,确保初始化成功
        WriteInstruction(0x0c);     //显示模式设置:显示开,无光标,光标不闪烁
        WriteInstruction(0x06);     //显示模式设置:光标右移,字符不移
        WriteInstruction(0x01);     //清屏幕指令,将以前的显示内容清除
void write_com(uchar com)//向1602写指令
                         P0=com;
          delaynms(5);
         RS=0;
         RW=0;
          delaynms(5);
         delaynms(10);
         E=1;
         delaynms(10);
         E=0;
函数功能:显示温度的小数点
void display_dot(void)
         WriteAddress(0x80+0x40+0x03);          //写显示地址,将在第2行第10列开始显示
         WriteData('.');      //将小数点的字符常量写入LCD
         delaynms(50);         //延时1ms给硬件一点反应时间
函数功能:显示温度的单位(Cent)
void display_cent(void)
    WriteAddress(0x80+0x40+0x02);        //写显示地址,将在第2行第13列开始显示
        WriteData(0xdf);
        WriteData('C');
向1302写一个字节
void input_BYTE(uchar dat)
        uchar i;
        ACC=dat;
        for(i=8;i>0;i--)
                T_IO=ACC0;
                T_CLK=1;
                 delaynms(5);
                T_CLK=0;
                ACC=(ACC>>1);
1302读出一个字节
uchar output_BYTE()
        uchar i;
        for(i=8;i>0;i--)
           ACC=(ACC>>1);
           ACC7=T_IO;
           T_CLK=1;
           T_CLK=0;
        return (ACC);
写数据
void write_1302(uchar add,uchar dat)
        T_RST=0;   //禁止数据传输
        T_CLK=0;   //确保写数据之前SCLK被拉低
        T_RST=1;   //启动数据传输
        delaynms(5);
        input_BYTE(add);   //写入命令字
        input_BYTE(dat);   //写数据
        delaynms(5);
        T_CLK=1;         //将时钟电平至于已知状态
        T_RST=0;
读数据
uchar read_1302(uchar add)
        uchar inf;
        T_RST=0;
    T_CLK=0;
        T_RST=1;
        delaynms(5);
        input_BYTE(add);
        inf=output_BYTE();
        delaynms(5);
        T_CLK=1;
        T_RST=0;
        return (inf);
void init_1302()
        write_1302(0x8e,0x00);//关闭写保护;
//        write_1302(0x90,0xaa);//设置充电方式;
        write_1302(0x80,0x00);//秒寄存器初始化;
        write_1302(0x82,0x29);//分.......
        write_1302(0x84,0x08);//时.......
        write_1302(0x86,0x10);//日........
        write_1302(0x88,0x11);//月.......
        write_1302(0x8a,0x02);//星期...
        write_1302(0x8c,0x15);//年......
        write_1302(0x8e,0x80);//打开写保护;
闹钟显示子程序
void show_naozhong(uchar x,uchar y)
        uchar i,x1,x2,y1,y2;
        x1=x/10; //十位
        x2=x%10;//个位
        WriteAddress(0x80+0x0b);   //显示闹钟的小时部分
        WriteData(table1[x1]);
        WriteAddress(0x80+0x0c);
        WriteData(table1[x2]);
        y1=y/10; //十位
        y2=y%10;//个位
        WriteAddress(0x80+0x0e);   //显示闹钟的分钟部分
        WriteData(table1[y1]);
        WriteAddress(0x80+0x0f);
        WriteData(table1[y2]);
        WriteAddress(0x80+0x0d);   //显示小时与分钟之间的那个冒号
        WriteData(':');
        WriteAddress(0x80);                   //显示字符串:Alarm Clock
        for(i=0;i<11;i++)
                WriteData(table[i]);
        WriteAddress(0x80+0x40);   //显示字符串:Today is fine!
        for(i=0;i<14;i++)
                WriteData(table3[i]);
void main(void)
    uchar i;
//        ceshi=0;
        LcdInitiate();         //将液晶初始化
         delaynms(5);        //延时5ms给硬件一点反应时间
    init_1302();
        EA=1;//开总中断
        EX0=1; //开外部中断1
        IT0=0;        //下降沿触发
        WriteAddress(0x80+0x50);
        for(i=0;i<13;i++)
                WriteData(table5[i]);
        for(i=0;i<30;i++)
                write_com(0x18);
                delaynms(250);
        delaynms(250);
        write_com(0x01);
        {                read_io();
                t_sec=read_1302(0x81);//读秒 ;
                sec1=t_sec&0x0f;
                sec2=(t_sec>>4);
                t_min=read_1302(0x83);//读分 ;
                min1=t_min&0x0f;
                min2=(t_min>>4);
                t_hour=read_1302(0x85);//读小时 ;
                hour1=t_hour&0x0f;
                hour2=(t_hour>>4);
                t_day=read_1302(0x87);//读日;
                day1=t_day&0x0f;
                day2=(t_day>>4);
                t_mon=read_1302(0x89);//读月 ;
                mon1=t_mon&0x0f;
                mon2=(t_mon>>4);
                week=read_1302(0x8b);//读星期 ;
                week1=week&0x0f;
                t_year=read_1302(0x8d);//读年 ;
                year1=t_year&0x0f;
                year2=(t_year>>4);
                WriteAddress(0x80+0x06);
                WriteData('2');
                WriteAddress(0x80+0x07);
                WriteData('0');
                WriteAddress(0x80);          //显示星期(0x80~0x80+0x05)
                for(i=0;i<4;i++)
                        WriteData(table2[i]);
                WriteAddress(0x80+0x04);
                WriteData(table1[week1]);
                WriteAddress(0x80+0x08);//显示年
                WriteData(table1[year2]);
                WriteAddress(0x80+0x09);
                WriteData(table1[year1]);
                WriteAddress(0x80+0x0a);        //显示‘/’
                WriteData('/');
                WriteAddress(0x80+0x0b);//显示月
                WriteData(table1[mon2]);
                WriteData(table1[mon1]);
                WriteAddress(0x80+0x0d);        //显示‘/’
                WriteData('/');
                WriteAddress(0x80+0x0e);//显示日
                WriteData(table1[day2]);
                WriteData(table1[day1]);
                /*第一行在此显示完毕*/
            // display_dot();       //显示温度的小数点
              display_cent();      //显示温度的单位
                WriteAddress(0x80+0x40); //温度
                WriteData(table1[WENSHI]);
                WriteAddress(0x80+0x40+0x01);//
                WriteData(table1[WENGE]);
                WriteAddress(0x80+0x40+0x05); //温度
                WriteData(table1[SHISHI]);
                WriteAddress(0x80+0x40+0x06);//
                WriteData(table1[SHIGE]);
                WriteAddress(0x80+0x40+0x08); //显示小时
                WriteData(table1[hour2]);
                WriteAddress(0x80+0x40+0x09);
                WriteData(table1[hour1]);
                WriteAddress(0x80+0x40+0x0a);  //显示':'
                WriteData(':');
                WriteAddress(0x80+0x40+0x0b);  //显示分钟
                WriteData(table1[min2]);
                WriteAddress(0x80+0x40+0x0c);
                WriteData(table1[min1]);
                WriteAddress(0x80+0x40+0x0d); //显示':'
                WriteData(':');
                WriteAddress(0x80+0x40+0x0e); //显示秒
                WriteData(table1[sec2]);
                WriteAddress(0x80+0x40+0x0f);
                WriteData(table1[sec1]);
                /*第二行在此显示完毕*/
                //以下部分是闹钟键盘检测程序
                if((x==hour2*10+hour1)&&(y==min2*10+min1))//若时间到了,则开启闹钟
                        beep=0;
                else                 //否则,关闭闹钟
                        beep=1;
            delaynms(10);
void exter0()interrupt 0
        uint k;
        write_com(0x01);
        for(k=0;k<2000;k++)
                while(key1==0)                   //键盘扫描.当key1按下时,
                {                                           //闹钟的小时部分加一
                        delaynms(10);
                        if(key1==0)                   //消抖
                                delaynms(10);
                                while(key1==0);        //松手检测
                                x++;
                                if(x==24)           //小时部分加到24后自动清零
                                x=0;
                while(key2==0)                //键盘检测。当key2按下时,
                        delaynms(10);        //闹钟的分钟部分加一
                        if(key2==0)                //消抖
                                delaynms(10);
                                while(key2==0);//松手检测
                                y++;
                                if(y==60)          //若分钟部分加到60,则自动清零
                                y=0;
                show_naozhong(x,y);          //调用闹钟显示程序
        write_com(0x01);
ID:1 发表于 2016-1-5 21:09 来自触屏版 | 显示全部楼层
既然仿真没有问题,那说明这个程序应该是没什么大问题的,建议楼主修改一下延时时间或者换一个晶体振荡器一下
ID:102073 发表于 2016-1-6 19:34 | 显示全部楼层
字符之间不要有空格,英文状态输入
ID:153199 发表于 2017-1-1 12:35 | 显示全部楼层
修改一下延时时间
好了吗,请求楼主分享经验
