查看: 12349|回复: 20
51单片机可调直流电源 原理图+程序+Proteus仿真
自己做的单片机可调直流电源Proteus仿真设计,下面是原理图:
51单片机可调直流电源的源程序:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include "timer.h"
  4. #include "global.h"
  5. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  6. #define vout 1
  7. #define vset 0
  8. #define vmode
  9. sbit RS = P2^0;
  10. sbit RW = P2^1;
  11. sbit EN  = P2^2;
  12. sbit DACSCLK = P2^3;
  13. sbit DACCS = P2^4;
  14. sbit DACDIN  = P2^5;
  15. sbit CS  = P1^0;
  16. sbit CLK = P1^1;
  17. sbit DIO = P1^2;
  18. sbit KEY1 = P3^6;
  19. sbit KEY2 = P3^7;
  20. #ifdef vmode
  21. uchar Display_Buffer[] = "00.00V           ";
  22. uchar code Line1[] = "Current Voltage:";
  23. #else
  24. uchar Display_Buffer[] = "                ";
  25. uchar code Line1[]     = "Current Speed:  ";
  26. #endif
  27. extern uint speed;
  28. void Delayms(uint ms)
  29. {
  30.          uchar i;
  31.         while(ms--)
  32.         {
  33.                  for(i=0;i<120;i++);
  34.         }
  35. }
  36. uchar Busy_Check()
  37. {
  38.          uchar LCD_Status;
  39.         RS = 0;
  40.         RW = 1;
  41.         EN = 1;
  42.         Delayms(1);
  43.            LCD_Status = P0;
  44.         EN = 0;
  45.         return LCD_Status;
  46. }
  47. void Write_LCD_Command(uchar cmd)
  48. {
  49.          while((Busy_Check()&0x80)==0x80);
  50.         RS = 0;
  51.         RW = 0;
  52.         EN = 0;
  53.         P0 = cmd;
  54.         EN = 1;
  55.         Delayms(1);
  56.         EN = 0;
  57. }
  58. void Write_LCD_Data(uchar dat)
  59. {
  60.          while((Busy_Check()&0x80)==0x80);
  61.         RS = 1;
  62.         RW = 0;
  63.         EN = 0;
  64.         P0 = dat;
  65.         EN = 1;
  66.         Delayms(1);
  67.         EN = 0;
  68. }
  69. void Initialize_LCD()
  70. {
  71.          Write_LCD_Command(0x38);
  72.         Delayms(1);
  73.         Write_LCD_Command(0x01);
  74.         Delayms(1);
  75.         Write_LCD_Command(0x06);
  76.         Delayms(1);
  77.         Write_LCD_Command(0x0c);
  78.         Delayms(1);
  79. }
  80. void ShowString(uchar x,uchar y,uchar *str)
  81. {
  82.          uchar i = 0;
  83.         if(y == 0)
  84.                 Write_LCD_Command(0x80 | x);
  85.         if(y == 1)
  86.                 Write_LCD_Command(0xc0 | x);
  87.         for(i=0;i<16;i++)
  88.         {
  89.                  Write_LCD_Data(str[i]);
  90.         }
  91. }
  92. uchar Get_AD_Result(uchar ch)
  93. {
  94.          uchar i,dat1=0,dat2=0;
  95.         CS  = 0;
  96.         CLK = 0;
  97.         DIO = 1; _nop_(); _nop_();
  98.         CLK = 1; _nop_(); _nop_();
  99.         CLK = 0;
  100.         DIO = 1; _nop_(); _nop_();
  101.         CLK = 1; _nop_(); _nop_();
  102.         CLK = 0;
  103.         if(ch)
  104.         DIO = 1;
  105.         else
  106.         DIO = 0;
  107.          _nop_(); _nop_();
  108.         CLK = 1; _nop_(); _nop_();
  109.         CLK = 0;
  110.         DIO = 1; _nop_(); _nop_();
  111.         for(i=0;i<8;i++)
  112.         {
  113.                  CLK = 1; _nop_(); _nop_();
  114.                 CLK = 0; _nop_(); _nop_();
  115.                 if(DIO) dat1 |=0x80>>i;
  116.         }
  117.         for(i=0;i<8;i++)
  118.         {
  119.                 if(DIO) dat2 |=0x01<<i;
  120.                 CLK = 1; _nop_(); _nop_();
  121.                 CLK = 0; _nop_(); _nop_();
  122.         }
  123.         CS = 1;
  124.         if (dat1 == dat2)
  125.                 return dat1;
  126.         else
  127.                 return 0x00;
  128. }
  129. void Set_DAC(uint dacvalue)
  130. {
  131.          uchar i;
  132.         uint dat;
  133.         dat = dacvalue;
  134.         dat &= 0x03ff;
  135.         DACCS  = 0;
  136.         DACSCLK = 0;
  137.         for(i=0;i<12;i++)
  138.         {
  139.                  if(dat & 0x0200)
  140.                         DACDIN = 1;
  141.                 else
  142.                         DACDIN = 0;
  143.                 DACSCLK = 1;
  144.                 dat <<= 1;
  145.                 DACSCLK = 0;
  146.         }
  147.         DACCS = 1;
  148. }
  149. void main()
  150. {
  151.          uchar B;
  152.         uint d,v;
  153.         Initialize_LCD();
  154.         InitTimer();
  155.         Delayms(10);
  156.         v = 0x0100;
  157.         StartTimer(0);
  158.         B = 0;
  159.         while(1)
  160.         {
  161.                  d = Get_AD_Result(vset);
  162.                 d &=0x00FF;
  163.                 Set_DAC(d*4);
  164.                 d = Get_AD_Result(vout);
  165.                 d &=0x00FF;
  166.                 d = d*1000.0/255;
  167.                 #ifdef vmode
  168.                 if(d/1000)
  169.                 Display_Buffer[0]=d/1000+'0';
  170.                 else
  171.                 Display_Buffer[0]=' ';
  172.                 Display_Buffer[1]=d/100%10+'0';
  173.                 Display_Buffer[3]=d/10%10+'0';
  174.                 Display_Buffer[4]=d%10+'0';
  175.                 #else
  176.                 if(speed/1000)
  177.                 Display_Buffer[0]=speed/1000+'0';
  178.                 else
  179.                 Display_Buffer[0]=' ';
  180.                 Display_Buffer[1]=speed/100%10+'0';
  181.                 Display_Buffer[2]=speed/10%10+'0';
  182.                 Display_Buffer[3]=speed%10+'0';
  183.                 #endif
  184.                 ShowString(0,0,Line1);
  185.                 ShowString(0,1,Display_Buffer);
  186.         }
  187. }
可调直流电源Proteus仿真.zip
87.82 KB, 下载次数: 197, 下载积分: 黑币 -5
参与人数 3黑币 +14 收起 理由
zsyzdx + 1 很给力!
ZHANGJINGYU + 8 赞一个!
月光 + 5 赞一个!
收藏收藏6 分享淘帖 顶1 踩
ID:143768 发表于 2016-10-21 15:22 | 只看该作者
路过。。。。51黑有你更精彩!!!
ID:143768 发表于 2016-10-21 15:23 | 只看该作者
再多弄两个开关电源。。。
ID:99130 发表于 2017-1-29 18:51 | 只看该作者
TLC5615是什么元件???还有一个比较器是什么型号???以及输出范围是多大???
ID:99130 发表于 2017-1-29 18:58 | 只看该作者
输出端在哪???????VOUT????
ID:189979 发表于 2017-4-15 21:38 | 只看该作者
很好 很好
ID:189979 发表于 2017-4-15 21:51 | 只看该作者
做得好
ID:202306 发表于 2017-5-18 19:46 | 只看该作者
谢谢,参考
ID:218056 发表于 2017-7-8 10:16 | 只看该作者
很好,学习
ID:218056 发表于 2017-7-8 10:19 | 只看该作者
好好学习
ID:219970 发表于 2017-7-15 22:45 | 只看该作者
学习下
ID:320306 发表于 2018-5-31 11:32 | 只看该作者
感谢楼主!!!!!!!!!!!!!!!
ID:346802 发表于 2018-6-7 12:28 | 只看该作者
可以 这个资料真的很棒
ID:355214 发表于 2018-6-20 15:05 | 只看该作者
学习学习
ID:60854 发表于 2019-1-18 10:25 | 只看该作者
这个真的很强大 感谢
ID:499929 发表于 2019-3-28 15:22 来自手机 | 只看该作者
问一下,这是51单片机吗
ID:499929 发表于 2019-3-28 18:06 来自手机 | 只看该作者
程序在proteus上实现不了
ID:970160 发表于 2021-10-6 20:13 | 只看该作者
厉害了,很需要这个,刚好看到,提供了思路
ID:895034 发表于 2021-12-12 23:05 | 只看该作者
为什么仿真不了呢,程序好像有点问题,不知道是不是软件版本的问题
ID:800382 发表于 2021-12-20 08:33 | 只看该作者
可以仿真
ID:1067203 发表于 2023-4-7 18:26 | 只看该作者
谢谢,学习了,天天向上
