查看: 8264|回复: 0
步进电机arduino正反转程序
ID:251993 发表于 2017-11-21 18:22 | 显示全部楼层 |阅读模式
int dirPin = 7;
int stepperPin = 8;
const byte SW = 6;
int buttonPushCounter = 0;
void setup() {
pinMode(dirPin, OUTPUT);
pinMode(stepperPin, OUTPUT);
pinMode(SW,INPUT);
void step(boolean dir,int steps){
  digitalWrite(dirPin,dir);
   delay(1000);
   for(int i=0;i<steps;i++){
   digitalWrite(stepperPin, HIGH);
   delayMicroseconds(5000);
   digitalWrite(stepperPin, LOW);
   delayMicroseconds(50000);
void loop(){
   boolean val = digitalRead(SW);
   if(val){
    step(true,600);
    delay(1);}
    else if(val){
    step(false,600);
    delay(1);}
