查看: 2306|回复: 0
温度湿度代码
ID:257555 发表于 2017-12-5 10:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//主程序清单:
#include<reg52.h>
#include<stdio.h>
#include<intrins.h>
typedef unsigned charuint8;
typedef unsignedint  uint16;
typedef unsigned charuchar;
typedef unsigned intuint;
    uchar i;
    RXBUF tmp;
    EA=1;
    EX0=1;
    EX1=1;
    IT0=1;
    IT1=1;
   receive(&tmp);
        for(i=0;i<100;i++)
        {   BCDDisplay(tmp.HZ,tmp.WZ);
            if(tmp.HZ>=25)  DENG2=0;
            else DENG2=1;
            if(tmp.WZ>=30) DENG1=0;
            else DENG1=1;
//温湿度显示子程序清单:
void start(void)
{   DHT11_IO=1;
    Delay1();
    DHT11_IO=0;
    Delay2(20);//>18ms
    DHT11_IO=1;
    Delay1();//20-40us
    Delay1();
    Delay1();
    Delay1();
    Delay1();
ucharreceive_byte(void)
{  uchar i,temp,count;
    for(i=0;i<8;i++)
        count=2;
        while((!DHT11_IO)&&count++)
//等待50us低电平结束
        temp=0;
    Delay1();Delay1();Delay1();Delay1();
        if(DHT11_IO==1)temp=1;
        count=2;
        while((DHT11_IO)&&count++);
        if(count==1)break;
        data_byte<<=1;
        data_byte|=temp;
    return data_byte;
void receive(RXBUF*tmp)
    uchar check,num_check;
    uchar count;
    start();//开始信号
    DHT11_IO=1;
    if(!DHT11_IO)//读取DHT11响应信号
        count=2;
        while((!DHT11_IO)&&count++);
//DHT11高电平80us是否结束
        count=2;
        tmp -> HZ = receive_byte();
        tmp -> HX = receive_byte();
        tmp -> WZ = receive_byte();
        tmp -> WX = receive_byte();
        check = receive_byte();
        DHT11_IO=0;//拉低延时50us
        DHT11_IO=1;
        num_check = tmp -> HZ + tmp -> HX + tmp -> WZ + tmp-> WX;
        if(num_check = check)
        {      check =num_check;
//外部中断0的子程序清单:
void int0() interrupt0
    while(WASI==0)
        uint i;
        for(i=0;i<250;i++)
            BEEP= 0;
            DENG4=0;
            mDelay(50);
            BEEP=1;
            DENG4=1;
            mDelay(50);
            F_Rotation();
        break;
    while(WASI==0)
        BEEP=0;
        DENG4=0;
        mDelay(150);
        DENG4=1;
        BEEP=1;
        mDelay(150);
    while(WASI==1)
        B_Rotation();
        break;
void BCDDisplay(ucharH,uchar W)
    BCD_PORT = BCD[W / 100];
    BCD1 = 0;
    mDelay(10);
    BCD1 = 1;
