查看: 3334|回复: 0
单片机直流电机加减速及测速系统设计
#include <showfun.h>
#include <stdio.h>
extern char fnLCMInit(); // LCM 初始化
extern void at(unsigned char x,unsigned char y);/*设定文本x,y值*/
extern void cls();         // 清屏
extern void charout(unsigned char *str); //ASCII(8*8) 显示函数
extern void fnSetPos(unsigned char urow, unsigned char  ucol);        // 设置当前地址
extern uchar dprintf(uchar x,uchar y,char *fmt);// ASCII(8*16) 及 汉字(16*16) 显示函数
extern uchar fnPR12(uchar uCmd); // 写无参数的指令
extern uchar fnPR13(uchar uData); // 写数据
extern unsigned int Adc0832(unsigned char channel);
extern void Line( unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, bit Mode);
extern void Pixel(unsigned char PointX,unsigned char PointY, bit Mode);
uchar dsp[10]={0,0,0,0,0,0,0,0,0,0,};
char abc[3]={0,0,0,};
uchar key=0;
uint a=100;
uchar n=5;
uchar count=1;
uint k1=0;
uchar GeyKey();
void delay(uchar i);
void control();
main()
         fnLCMInit();
        fnSetPos(0,0);
        dprintf(0,0,"直流电机加-减速及测速系统");
        dprintf(0,12,"键盘+:步长加速");
        dprintf(0,24,"键盘-:步长减速");
        dprintf(0,36,"键盘=:顺时针转");
        dprintf(0,48,"键盘on/c:逆时针转");
     dprintf(0,72,"方向:");
           dprintf(0,84,"转速:");
         P1_1=0;
     TMOD=0x15;
         TH1=0x3c;
         TL1=0xb0;
     TH0=0x00;
         TL0=0x00;
         ET0=1;
         ET1=1;
         TR0=1;
         TR1=1;
        {  key=GeyKey();
      switch(key)
       {   case '1': {          a=10;
                                    //sprintf(abc,"%3.2f",a/255.0);
                                        dprintf(0,96,"  5    r/min");
                                //dprintf(0,96,abc);
                                dprintf(60,96,"r/min");
                                    break;      }
               case '2': {          a=25;dprintf(0,96,"  25    r/min");    break;      }
                   case '3': {          a=40; dprintf(0,96," 40    r/min");   break;      }
                   case '4': {          a=55; dprintf(0,96," 60    r/min");   break;      }
                   case '5': {          a=70; dprintf(0,96," 80    r/min");   break;      }
                   case '6': {          a=90; dprintf(0,96,"100    r/min");   break;      }
                   case '7': {          a=110; dprintf(0,96,"120    r/min");   break;      }
                   case '8': {          a=130; dprintf(0,96,"135    r/min");   break;      }
                   case '9': {          a=150; dprintf(0,96,"150    r/min");   break;      }
               case '+': {          dprintf(0,72,"方向: 顺时针");
                                    control();
        break;
           case '-': {         P1_0=0;
                                        dprintf(0,72,"方向: 逆时针");
                                         control();
                                        break;
           case '=': {P1_0=1;dprintf(0,72,"方向: 顺时针");break;}
           case 'c': {P1_0=0;dprintf(0,72,"方向: 逆时针");break;}
           case '/': {dprintf(0,72,"方向: 顺时针");
                                    control();}
                   default:  break;
uchar GeyKey()
         P1_4=0;
         P1_5=1;
         P1_6=1;
         P1_7=1;
        P3_0=1;
        P3_1=1;
        P3_2=1;
    P3_3=1;
        _nop_();_nop_();
        if(!P3_0)return '7';
         if(!P3_1)return '8';
         if(!P3_2)return '9';
    if(!P3_3)return '/';
         P1_4=1;
         P1_5=0;
         P1_6=1;
         P1_7=1;
        _nop_();_nop_();
        if(!P3_0)return '4';
         if(!P3_1)return '5';
         if(!P3_2)return '6';
    if(!P3_3)return '*';
         P1_4=1;
         P1_5=1;
         P1_6=0;
         P1_7=1;
        _nop_();_nop_();
        if(!P3_0)return '1';
         if(!P3_1)return '2';
         if(!P3_2)return '3';
    if(!P3_3)return '-';
         P1_4=1;
         P1_5=1;
         P1_6=1;
         P1_7=0;
        _nop_();_nop_();
        if(!P3_0)return 'c';
         if(!P3_1)return '0';
         if(!P3_2)return '=';
    if(!P3_3)return '+';
        return 0;
void delay(uchar i)
{  uchar j,k;
    for(;i>0;i--)
    for(j=15;j>0;j--)
    for(k=11;k>0;k--);
void time()interrupt 3
     TR1=0;
     count++;
     k1+=TL0;
         if(count==51)
              sprintf(dsp,"%3d",k1);
                  dprintf(0,108,dsp);
          dprintf(60,108,"r/min");
                  count=1;
          k1=0;
          TH1=0x3c;
          TL1=0xb0;
          TH0=0x00;
          TL0=0x00;
          TR1=1;
void control()
       EA=1;
           {    if(a>=150)
               a=150;
                        if(a<=10)
                            a=10;
                         P1_1=0;
                         delay(160-a);
                         P1_1=1;
                         delay(a);
                         key=GeyKey();
                         if(key=='-') a-=n;
                           if(key=='+') a+=n;
                           if(key=='=')
                           {  P1_0=1;
                         if(key=='c')
                         {  P1_0=0;
                          if(key=='*')
                          {   P1_1=0;
                              break;
                         if(key!=0)
                           break;
                 EA=0;
完整资料下载(完整代码+仿真图):
http://www.51hei.com/bbs/dpj-56438-1.html
