查看: 3350|回复: 1
51单片机查表输出SPWM
ID:321404 发表于 2018-5-3 17:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define uInt unsigned int
uchar t_max = 10;                       //一个周期
static uchar t = 0,i = 0;        //PWM计数
uchar code SinParam[40]={
0,3,6,9,13,16,19,22,25,28,31,34,37,40,43,45,
48,51,54,56,59,61,64,66,68,71,73,75,77,79,81,83,
84,86,88,89,90,92,93,94,95,96,97,98,98,99,99,100,
100,100,100,100,100,100,99,99,98,98,97,96,95,94,93,92,
90,89,88,86,84,83,81,79,77,75,73,71,68,66,64,61,
59,56,54,51,48,45,43,40,37,34,31,28,25,22,19,16,
13,9,6,3
uchar code SinParam[20]={
  5,5,6,7,7,8,9,9,9,9,10,9,9,9,9,8,
7,7,6,5
// 200点正弦波样本值
void main(void)
        TMOD = 0x02;                                //定时器0,工作模式2,8位定时模式
        TH0 = 146;                                //写入预置初值(取值1-255,数越大PWM频率越高)
        TL0 = 146;                                //写入预置值(取值1-255,数越大PWM频率越高)
        TR0 = 1;                                        //启动定时器
        ET0 = 1;                                        //允许定时器0中断
        EA = 1;                                        //允许总中断
        P2 = 0xff;                                //初始化P1
timer0()interrupt 1 using 2
        t++;                                //每次定时器溢出加1
        if(t < t_max && t >= SinParam[i])        //PWM周期                                          5
                        P2 = 0x00;                        //使LED灯亮
                else if( t >= t_max)
                        t = 0;        //使t=0,开始新的PWM周期
                        i++;
                        P2 = 0xff;
   if(i >= 20) i = 0;
收藏收藏2 分享淘帖 顶顶 踩踩
ID:321404 发表于 2018-5-3 17:09 | 只看该作者
求问这样写对吧
