查看: 2291|回复: 0
DS18B20读取数据1602显示
代码如下
#include <reg51.h>
sbit DQ=P2^7;
sbit led=P1^0;
sbit rs=P2^0;
sbit rw=P2^1;
sbit e=P2^2;
uchar temp,temp1;
void delay(uint t);
void delay_1ms(uint z);
uchar init_ds18b20();
void write_byte(uchar dat);
uchar read_byte(void);
uchar read_tem(void);
void write_com(uchar com);
void write_dat(uchar dat);
void init();
{  unsigned char n;
     init();
     temp=read_tem();      //温度值的整数部分
   n=init_ds18b20();
    if(n)
      led=0;
   write_com(0x80+8);
   write_dat(0xdf);    //显示温度符号
   write_dat(0x43);     //显示温度符号
   delay_1ms(5);
   write_com(0x80+1);
   write_dat(0x30+temp/10);     //显示温度的十位
   write_dat(0x30+temp%10);     //显示温度的个位
   write_com(0x80+4);
   write_dat('.');
   write_dat(0x30+temp1);      //显示小数部分
void delay_1ms(uint z) //
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void delay(uint t)
     while(t--);
     uchar n;
     DQ=1;
     delay(8);
     DQ=0;
     delay(80);//600us
     DQ=1;
     delay(8);//15us~60us
     n=DQ;
     delay(4);
  return 0;
    uchar i;
    for(i=0;i<8;i++)
       DQ=0;
       DQ=dat&0x01;
       delay(4);
       DQ=1;
       dat=dat>>1;
    delay(4);
   uchar i,value;
   for(i=0;i<8;i++)
       DQ=0;
       value>>=1;
       DQ=1; //
       if(DQ)
         value|=0x80;
       delay(4);
   return value;
    uchar a,b,temp0;
    init_ds18b20();
    write_byte(0xcc);//ì?1yROM
    write_byte(0x44);//???ˉ???è2aá?
    delay(300);
    init_ds18b20();
    write_byte(0xcc);
    write_byte(0xbe);//?á???è
    a=read_byte();
    b=read_byte();
    b<<=4;
temp1=(a&0x0f);
temp1=temp1*0.625+0.5;
    a>>=4;
    temp0=b|a;
    return temp0;
   rs=0;
   rw=0;
   P1=com;
   e=1;
   delay_1ms(5);//?T?óê±2??ü?y3£1¤×÷
   e=0;
   rs=1;//????D′êy?Y
   rw=0;
   P1=dat;
   e=1;
   delay_1ms(5);//
   e=0;
void init()  //
   delay_1ms(15);
   write_com(0x38);
   delay_1ms(6);
   write_com(0x38);
   delay_1ms(6);
   write_com(0x38);
   write_com(0x38);
   write_com(0x0c);
   write_com(0x06);
   write_com(0x01);
