查看: 10014|回复: 0
51单片机控制ds18b20代码
ID:328740 发表于 2018-5-13 11:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
include <reg52.H>
#include <intrins.h>
sbit    D18B20=P3^7;    //DQ接P3^7
#define  NOP()   _nop_()
#define  _Nop()  _nop_()
void TempDelay (unsigned char idata us);  //延时函数定义
void Init18b20 (void);                   //初始化函数定义
void WriteByte (unsigned char idata wr);  //单字节写入
void read_bytes (unsigned char idata j);  //定义多字节数据读取
unsigned char CRC (unsigned char j);//定义校验码数组
void GemTemp (void);                //数据处理
void Config18b20 (void);    //配置上下限即处理位数(9/10/11)
void ReadID (void);         //读取器件ID,即ROM中的数据
void TemperatuerResult(void); //最终数据输出
//bit  flag;
unsigned int  idata Temperature,D[10]; //定义温度数组
unsigned char idata temp_buff[9];      //定义RAM数据暂存数组
//存储读取的字节,read scratchpad为9字节,read rom ID为8字节
unsigned char idata id_buff[8];    //定义ROM数据暂存数组
unsigned char idata *p,TIM;        //指针变量
unsigned char idata crc_data;      //CRC计算变量定义
unsigned char code CrcTable [256]={
0,  94, 188,  226,  97,  63,  221,  131,  194,  156,  126,  32,  163,  253,  31,  65,
157,  195,  33,  127,  252,  162,  64,  30,  95,  1,  227,  189,  62,  96,  130,  220,
35,  125,  159,  193,  66,  28,  254,  160,  225,  191,  93,  3,  128,  222,  60,  98,
190,  224,  2,  92,  223,  129,  99,  61,  124,  34,  192,  158,  29,  67,  161,  255,
70,  24,  250,  164,  39,  121,  155,  197,  132,  218,  56,  102,  229,  187,  89,  7,
219,  133, 103,  57,  186,  228,  6,  88,  25,  71,  165,  251,  120,  38,  196,  154,
101,  59, 217,  135,  4,  90,  184,  230,  167,  249,  27,  69,  198,  152,  122,  36,
248,  166, 68,  26,  153,  199,  37,  123,  58,  100,  134,  216,  91,  5,  231,  185,
140,  210, 48,  110,  237,  179,  81,  15,  78,  16,  242,  172,  47,  113,  147,  205,
17,  79,  173,  243,  112,  46,  204,  146,  211,  141,  111,  49,  178,  236,  14,  80,
175,  241, 19,  77,  206,  144,  114,  44,  109,  51,  209,  143,  12,  82,  176,  238,
50,  108,  142,  208,  83,  13,  239,  177,  240,  174,  76,  18,  145,  207,  45,  115,
202,  148, 118,  40,  171,  245,  23,  73,  8,  86,  180,  234,  105,  55,  213, 139,
87,  9,  235,  181,  54,  104,  138,  212,  149,  203,  41,  119,  244,  170,  72,  22,
233,  183,  85,  11,  136,  214,  52,  106,  43,  117,  151,  201,  74,  20,  246,  168,
116,  42,  200,  150,  21,  75,  169,  247,  182,  232,  10,  84,  215,  137,  107,  53};
//CRC数据表
//Function:延时处理
while(us--);
//Function:18B20初始化
D18B20=1;  //侦测到下跳沿,初始化
_nop_();
D18B20=0;
TempDelay(160);   //delay480 us  (480)
_nop_();
D18B20=1;   //释放总线
TempDelay(30);   //delay 96 us (60-112)
_nop_();
_nop_();
_nop_(); //18B20侦测到此上升沿,会自动应答
    //发送presence信号
//if(D18B20==0)
// flag = 1;   //detect 1820 success!
//else
// flag = 0;    //detect 1820 fail!
TempDelay(30);       //delay 96 us(60-240)
_nop_();    //发送应答脉冲
_nop_();
D18B20 = 1;   //释放总线
//Function:向18B20写入一个字节
void WriteByte (unsigned char idata wr)  //单字节写入
unsigned char idata i;
for (i=0;i<8;i++)
  D18B20 = 1;
     _nop_();
  D18B20 = 0;   //侦测到下跳沿,初始化
  _nop_();
  D18B20=wr&0x01;   //写数据在(60-120)us内
  TempDelay(30);   //delay 96(60-120)us
  _nop_();
  _nop_();   //至少大于1us恢复时间
  D18B20=1;   //释放总线
  wr >>= 1;   //一个字节8位,总共写8次
//Function:读18B20的一个字节
unsigned char ReadByte (void)     //读取单字节
unsigned char idata i,u=0;
for(i=0;i<8;i++)
  D18B20 = 1;
     _nop_();
  D18B20 = 0;  //负跳沿,初始化
  u >>= 1;
  D18B20 = 1;   //释放总线
  if(D18B20==1)
  u |= 0x80;
  TempDelay (3); //15us内采样
  _nop_();
return(u);
//Function:读18B20
  for(i=0;i<j;i++)
    *p = ReadByte();
    p++;
//Function:CRC校验
    unsigned char idata i,crc_data=0;
   for(i=0;i<j;i++)  //查表校验
    crc_data = CrcTable[crc_data^temp_buff[i]];
    return (crc_data);//返回i=8时的crc_data
}//若为0,校验正确,即此时的temp_buff[8]=0x00;
//Function:读取温度
void GemTemp (void)
   read_bytes (9);
   if (CRC(9)==0) //校验正确
   { //暂存器第0字节低8位,第一字节为高8位。
     Temperature = temp_buff[1]*0x100 + temp_buff[0];
//     Temperature *= 0.625;
  Temperature /= 16; //转换成10进制
  TempDelay(1);
//Function:内部配置
void Config18b20 (void)  //重新配置报警限定值和分辨率
     Init18b20();
     WriteByte(0xcc);  //skip rom
     WriteByte(0x4e);  //配置暂存器2,3,4字节数据
     WriteByte(0x19);  //上限
     WriteByte(0x1a);  //下限
     WriteByte(0x7f);     //set 11 bit (0.125)
     Init18b20();
     WriteByte(0x48);  //保存设定值
     Init18b20();
     WriteByte(0xb8);  //回调设定值
//Function:读18B20ID
void ReadID (void)//读取器件 id
Init18b20();
WriteByte(0x33);  //read rom
read_bytes(8);
//Function:18B20ID全处理
   p = id_buff;
   ReadID();    //读取器件ID
   Config18b20(); //ROM配置
Init18b20 (); //初始化
WriteByte(0xcc);   //单点检测,跳过ROM检索
WriteByte(0x44);   //启用温度转换
Init18b20 ();
WriteByte(0xbe);   //读取暂存器的全部内容
p = temp_buff;
GemTemp();
unsigned int TempTick=0;
void GetTemp()
     if(TIM==1)
{  TIM=0;
    TemperatuerResult();
//  D[5]=Temperature;
//刷新时间
void T1zd(void) interrupt 3
   TH1 = 0xfe;       TL1 = 0x33;
   TIM++;
