查看: 1776|回复: 0
msp-exp-430f5529程序
ID:283860 发表于 2018-4-5 20:45 | 显示全部楼层 |阅读模式
#include <msp430f5529.h>
void UART_Init(void);
void putchar(unsigned char c);
void putstring(unsigned char *s);
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
         P1DIR|=BIT0;
         P1OUT|=BIT0;
  UART_Init();
//putchar('s');
  //__bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
  //__no_operation();                         // For debugger
         // putchar('s');
        //  __delay_cycles(10000);
#pragma vector=USCI_A1_VECTOR
__interrupt void USCI_A1_ISR(void)
    while (!(UCA1IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
    UCA1TXBUF = UCA1RXBUF;                  // TX -> RXed character
    UCA1IFG&=~UCTXIFG;
    P1OUT^=BIT0;
          P4SEL |= BIT4+BIT5;                       // P3.3,4 = USCI_A0 TXD/RXD
          UCA1CTL1 |= UCSWRST;                      // **Put state machine in reset**澶嶄綅浣胯兘
          UCA1CTL1 |= UCSSEL_2;                     // SMCLK   閫夊彇SMLK鏃堕挓
          UCA1BR0 = 9;                              // 1MHz 115200 (see User's Guide)1M/115200=8.68锛屽洓鑸嶄簲鍏ヤ负9
          UCA1BR1 = 0;                              // 1MHz 115200   楂樺叓浣嶄负闆?          UCA1MCTL |= UCBRS_1 + UCBRF_0;            // Modulation UCBRSx=1, UCBRFx=0
          UCA1CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
          UCA1IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
          _EINT();
             UCA1TXBUF = c;
             UCA1IFG&=~UCTXIFG;
        while((*s)!='@')
                putchar(*s);
                s++;
