查看: 4692|回复: 3
STM32中断方式的按键控制程序Proteus仿真 8按键整理
希望可以对你有用
  1. #include "stm32f10x_exti.h"
  2. #include "key.h"
  3. #include "Delay.h"
  4. void exit_config(void)
  5. {
  6.     EXTI_InitTypeDef  EXTI_InitStructure;
  7.     NVIC_InitTypeDef  NVIC_InitStructure;
  8.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  9.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource8);        //EXTI8EXTI_Line8中断线与PB8映射,设置PB8为中断源EXTI_Line8
  10.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource9);        //设置PB9为中断源EXTI_Line9
  11.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource10);        //设置PB10为中断源EXTI_Line10
  12.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource11);        //设置PB11为中断源EXTI_Line11
  13.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource12);        //EXTI12EXTI_Line12中断线2与PB12映射,设置PB12为中断源EXTI_Line12
  14.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource13);        //设置PB13为中断源EXTI_Line13
  15.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource14);        //设置PB14为中断源EXTI_Line14
  16.     GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource15);        //设置PB15为中断源EXTI_Line15
  17.
  18.     EXTI_InitStructure.EXTI_Line=0XFF00;//EXTI_Line8|EXTI_Line9|EXTI_Line10|EXTI_Line11|EXTI_Line12|EXTI_Line13|EXTI_Line14|EXTI_Line15;     //将中断映射到中断线EXTI_Line12~EXTI_Line15上
  19.     EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;         //设置为中断模式
  20.     EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //设置为下降沿触发中断
  21.     EXTI_InitStructure.EXTI_LineCmd = ENABLE;                           //中断使能,既开中断
  22.     EXTI_Init(&EXTI_InitStructure);                                    //根据EXTI_InitStruct中指定的参数初始化外设EXTI寄存器
  23.
  24.     NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;            //使能按键所在的外部中断通道
  25.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;     //抢占优先级0位
  26.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0f;             //响应优先级4位,优先级15,为最低优先级
  27.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                    //使能外部中断通道
  28.     NVIC_Init(&NVIC_InitStructure);                                    //中断优先级分组初始化
  29.
  30.     NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;            //使能按键所在的外部中断通道
  31.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;     //抢占优先级0位
  32.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0f;             //响应优先级4位,优先级15,为最低优先级
  33.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                    //使能外部中断通道
  34.     NVIC_Init(&NVIC_InitStructure);                                    //中断优先级分组初始化
  35. }
  36. void EXTI9_5_IRQHandler(void)
  37. {static u8 k1=0,k2=0;     //LED亮和灭状态,为0是熄灭状态,为1是点亮状态
  38.     Delay(20);
  39.     if(KEY1==0)                      //读取K3按键状态,判断K1按键是否按下
  40.     {
  41.         if(k1==0)
  42.             GPIO_ResetBits(GPIOC,GPIO_Pin_8);
  43.         else
  44.             GPIO_SetBits(GPIOC,GPIO_Pin_8);
  45.         k1=!k1;
  46.     }
  47.     else if(KEY2==0)        //读取K4按键状态,判断K4按键是否按下
  48.     {
  49.         if(k2==0)
  50.             GPIO_ResetBits(GPIOC,GPIO_Pin_9);
  51.         else
  52.             GPIO_SetBits(GPIOC,GPIO_Pin_9);
  53.         k2=!k2;
  54.     }
  55.     //while(KEY1!=1||KEY2!=1);//仿真可以取消
  56.     //EXTI_ClearITPendingBit(EXTI_Line8);
  57.     //EXTI_ClearITPendingBit(EXTI_Line9);
  58. }
  59. void EXTI15_10_IRQHandler(void)
  60. {
  61.     static u8 k3=0,k4=0,k5=0,k6=0,k7=0,k8=0;     //LED亮和灭状态,为0是熄灭状态,为1是点亮状态
  62.     Delay(20);
  63.     if(KEY3==0)                      //读取K3按键状态,判断K1按键是否按下
  64.     {
  65.         if(k3==0)
  66.             GPIO_ResetBits(GPIOC,GPIO_Pin_10);
  67.         else
  68.             GPIO_SetBits(GPIOC,GPIO_Pin_10);
  69.         k3=!k3;
  70.     }
  71.     else if(KEY4==0)        //读取K4按键状态,判断K4按键是否按下
  72.     {
  73.         if(k4==0)
  74.             GPIO_ResetBits(GPIOC,GPIO_Pin_11);
  75.         else
  76.             GPIO_SetBits(GPIOC,GPIO_Pin_11);
  77.         k4=!k4;
  78.     }
  79.     else if(KEY5==0)        //读取K5按键状态,判断K5按键是否按下
  80.     {
  81.         if(k5==0)
  82.             GPIO_ResetBits(GPIOC,GPIO_Pin_12);
  83.         else
  84.             GPIO_SetBits(GPIOC,GPIO_Pin_12);
  85.         k5=!k5;
  86.     }
  87.     else if(KEY6==0)        //读取K6按键状态,判断K6按键是否按下
  88.     {
  89.         if(k6==0)
  90.             GPIO_ResetBits(GPIOC,GPIO_Pin_13);
  91.         else
  92.             GPIO_SetBits(GPIOC,GPIO_Pin_13);
  93.         k6=!k6;
  94.     }
  95.         else if(KEY7==0)        //读取K7按键状态,判断K7按键是否按下
  96.     {
  97.         if(k7==0)
  98.             GPIO_ResetBits(GPIOC,GPIO_Pin_14);
  99.         else
  100.             GPIO_SetBits(GPIOC,GPIO_Pin_14);
  101.         k7=!k7;
  102.     }
  103.     else if(KEY8==0)        //读取K7按键状态,判断K7按键是否按下
  104.     {
  105.         if(k8==0)
  106.             GPIO_ResetBits(GPIOC,GPIO_Pin_15);
  107.         else
  108.             GPIO_SetBits(GPIOC,GPIO_Pin_15);
  109.         k8=!k8;
  110.     }
  111.     //while(KEY3!=1||KEY4!=1||KEY5!=1||KEY6!=1||KEY7!=1||KEY8!=1);//仿真可以取消
  112.     //EXTI_ClearITPendingBit(EXTI_Line10);
  113.     //EXTI_ClearITPendingBit(EXTI_Line11);
  114.     //EXTI_ClearITPendingBit(EXTI_Line12);
  115.     //EXTI_ClearITPendingBit(EXTI_Line13);
  116.     //EXTI_ClearITPendingBit(EXTI_Line14);
  117.     //EXTI_ClearITPendingBit(EXTI_Line15);
  118. }
中断方式的按键控制 8按键整理.7z (223.04 KB, 下载次数: 67)
收藏收藏2 分享淘帖 顶 踩
ID:742583 发表于 2020-5-5 15:42 | 只看该作者
下载了后发现是8.7版的呜呜呜
ID:384904 发表于 2020-5-30 10:33 | 只看该作者
试试看
ID:764845 发表于 2020-5-30 14:07 | 只看该作者
可能有用
