查看: 2882|回复: 1
求助关于PCF8591和GP2Y1014传感器,帮忙看看代码哪里有问题,主要是AD转换那块
回帖奖励 50 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
ID:295381 发表于 2018-4-10 15:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PCF8591:
#include <intrins.h>
#define somenop() _nop_(),_nop_(),_nop_(),_nop_(),_nop_(),_nop_()
#define  WRITEADDR 0x90
#define  READADDR  0x91
//PCF89C51??
sbit SCL=P1^0;
sbit SDA=P1^1;
bit ack;
void Init_I2c()
SDA=1;
somenop();
SCL=1;
somenop();
void Start_I2c()
  SDA=1;
  somenop();
  SCL=1;
  somenop();
  SDA=0;
  somenop();
  SCL=0;
  somenop();
void Stop_I2c()
  SDA=0;
  somenop();
  SCL=0;
  somenop();
  SCL=1;
  somenop();
  SDA=1;
  somenop();
void  SendByte(uchar  c)
uchar  i;
for(i=0;i<8;i++)
     if((c<<i)&0x80)SDA=1;
       else  SDA=0;
     somenop();
     SCL=1;
     somenop();
     SCL=0;
    somenop();
    SDA=1;
    somenop();
    SCL=1;
    somenop();
    if(SDA==1)ack=0;
       else ack=1;
    SCL=0;
   somenop();
uchar   RcvByte()
  uchar  retc;
  uchar  i;
  retc=0;
  SDA=1;
  for(i=0;i<8;i++)
        somenop();
        SCL=0;
        somenop();
        SCL=1;
        somenop();
        retc=retc<<1;
        if(SDA==1)retc=retc+1;
        somenop();
  SCL=0;
  somenop();
  return(retc);
void Ack_I2c(bit a)
  if(a==0)
  SDA=0;
  somenop();
  SCL=1;
  somenop();
  SCL=0;
  somenop();
  SDA=0;
  somenop();
  SDA=1;
  somenop();
  SDA=1;
    somenop();
    SCL=1;
    somenop();
    SCL=0;
    somenop();
    SDA=0;
    somenop();
bit ISendByte(uchar add,uchar channel)
   Start_I2c();
   SendByte(add);
   if(ack==0)return(0);
   SendByte(0x40|channel);
   Stop_I2c();
   return(1);
uchar IRcvByte(uchar add)
   uchar dat;
   Start_I2c();
   SendByte(add+1);
   dat=RcvByte();
   Ack_I2c(1);
   Stop_I2c();
   return(dat);
sbit vled  = P3^2;
void Delay1us(uint t)
while(t--)_nop_();
uint read_data()
uint val=0;
//Init_I2c();
vled=0;
Delay1us(20);
ISendByte(WRITEADDR,0);
//val=adc0832(N,M);
val=IRcvByte(WRITEADDR);
vled=1;
Delay1us(400);
return val;
主函数:
#include <reg52.h>
#include <lcd1602.h>
#include <math.h>
#include <pcf.h>
void main(void)
double PM,pm1,pm2;
int PMVAL=0,HPM=200,PM_count=0,pm1_count=0;
uchar disp[16]  ={"PM2.5:0000ug/m3 "};
LCD_Init();
  WriteChar(1,0,16,disp);
  pm1+=read_data();//这里为把AD转换后的值传过来
  if(++PM_count>=20)
     PM_count=0;
      pm1=pm1/20;
   pm2+=pm1;
   pm1=0;
   if(++pm1_count>=5)
    pm1_count=0;
    PM=pm2/5;
    PM=PM*50/255;
    PM-=4;
       PM/=5;
    PM*=1000;
    PMVAL=PM;
    PMVAL+=235; PMVAL=PMVAL/9;
    if(PMVAL>=9999)PMVAL=9999;
    WriteCOMorDATA(0x86,0);
    if(PMVAL<0)//PMVAL=0;
    {WriteCOMorDATA(0+0x30,1);PMVAL=abs(PMVAL);}
    else WriteCOMorDATA(PMVAL/1000+0x30,1);
    WriteCOMorDATA(PMVAL/100%10+0x30,1);
    WriteCOMorDATA(PMVAL/10%10+0x30,1);
    WriteCOMorDATA(PMVAL%10+0x30,1);
    PM=pm1=pm2=0;
ID:307472 发表于 2018-7-5 14:49 | 只看该作者
你好,现在你的程序好使了么???
