查看: 2168|回复: 0
基于单片机的电磁屏蔽门Proteus仿真源程序 开关模拟红关门外传感器检测
电磁屏蔽门是屏蔽设备最为关键的屏蔽部件。是工作人员和设备进出的主要通道。在确保屏蔽效能的前提下,它的可靠性、稳定性、实用性以及美观性将至关重要,本设计以单片机为核心,采用红外感应实现屏蔽门的关与开。仿真与原程序齐全。
屏蔽门指示灯
亮 代表门已关上
灭 代表门已打开
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. #define uint unsigned int
  5. sbit SW_2 = P2^0;
  6. sbit IN_1  = P2^3;        //引脚定义--电机驱动引脚 1
  7. sbit IN_2  = P2^4;        //引脚定义--电机驱动引脚 2
  8. sbit SW_1  = P2^5;
  9. sbit Touch = P2^6;        //引脚定义--调节按键 4
  10. sbit Beep  = P2^7;
  11. sbit LED_Red = P1^0;
  12. sbit LED_Green = P1^1;
  13. sbit LED_3 = P1^2;
  14. sbit LED_4 = P1^3;
  15. unsigned int Beep_Flag = 0;
  16. unsigned int Timing_Beep = 0;
  17. unsigned int Timing_Open = 0;
  18. unsigned int Open_Flag = 0;
  19. unsigned int Door_Close_Flag = 0;
  20. unsigned int Timing_Door_Close = 0;
  21. unsigned int Door_Open_Flag = 0;
  22. unsigned int Timing_Door_Open = 0;
  23. uchar Windows_1_Flag_Str[3];        //数组定义--储存 温度
  24. void InitTimer0(void)
  25. {
  26.     TMOD = 0x01;
  27.     TH0 = 0x0D8;
  28.     TL0 = 0x0F0;
  29.     EA = 1;
  30.     ET0 = 1;
  31.     TR0 = 1;
  32. }
  33. //1ms延时函数//
  34. void delay1ms()
  35. {
  36.         unsigned char i,j;
  37.   for(i=0;i<10;i++)
  38.                 for(j=0;j<33;j++);
  39. }
  40. //n ms延时函数//
  41. void delaynms(int n)
  42. {
  43.         unsigned char i;
  44.         for(i=0;i<n;i++)
  45.                 delay1ms();
  46. }
  47. //显示函数//
  48. void Show()
  49. {
  50.         if( SW_1 == 0 && Beep_Flag == 0 )
  51.         {
  52.                 Beep_Flag = 1;
  53.         }
  54.
  55.         if( SW_1 == 1 && Beep_Flag == 2 )
  56.         {
  57.                 Beep_Flag = 0;
  58.         }
  59. }
  60. void System_Init()
  61. {
  62.         InitTimer0();
  63.         IN_1 = IN_2 = 0;
  64.         Beep = 0;
  65.         LED_Green = 0;
  66. }
  67. /************************主函数**************************/
  68. void main()
  69. {
  70.         System_Init();
  71.         while(1)
  72.         {
  73.                 Show();
  74.                 delaynms(20);
  75.         }
  76. }
  77. void Timer0Interrupt(void) interrupt 1
  78. {
  79.         TH0 = 0x0D8;
  80.         TL0 = 0x0F0;
  81.
  82.         if( SW_2 == 0 && Open_Flag == 0 )
  83.         {
  84.                 Open_Flag = 1;
  85.
  86.         }
  87.
  88.         if( Open_Flag == 1 )
  89.         {
  90.                 Timing_Open ++;
  91.                 if( Timing_Open <= 1000 )
  92.                 {
  93.                         IN_1 = 0;
  94.                         IN_2 = 1;
  95.                         LED_Red = 0;
  96.                         LED_Green = 1;
  97.                         LED_3 = 0;
  98.                         LED_4 = 1;
  99.                 }
  100.                 else
  101.                 {
  102.                         Timing_Open = 0;
  103.                         Open_Flag = 2;
  104.                         IN_1 = 0;
  105.                         IN_2 = 0;
  106.                         LED_Red = 1;
  107.                         LED_Green = 0;
  108.                         LED_3 = 1;
  109.                         LED_4 = 1;
  110.                 }
  111.         }
  112.
  113.         if( Open_Flag == 2 )
  114.         {
  115.                 if( Touch == 1 )
  116.                 {
  117.                         if( SW_1 == 0 )
  118.                         {
  119.                                 if( Beep_Flag == 1 && SW_1 == 0 )
  120.                                 {
  121.                                         Timing_Beep ++;
  122.                                         if( Timing_Beep <= 500 )
  123.                                         {
  124.                                                 if( (Timing_Beep < 100) || (Timing_Beep > 200 && Timing_Beep < 300) || (Timing_Beep > 400 && Timing_Beep < 500) )
  125.                                                 {
  126.                                                         Beep = 1;
  127.                                                         LED_Red = 0;
  128.                                                 }
  129.                                                 else
  130.                                                 {
  131.                                                         Beep = 0;
  132.                                                         LED_Red = 1;
  133.                                                 }
  134.                                         }
  135.                                         else
  136.                                         {
  137.                                                 Timing_Beep = 0;
  138.                                                 Beep_Flag = 2;
  139.                                                 Beep = 0;
  140.                                                 LED_Red = 1;
  141.                                                 Door_Close_Flag = 1;
  142.                                         }
  143.                                 }
  144.                                 else
  145.                                 {
  146.                                         Beep = 0;
  147.                                         LED_Red = 1;
  148.                                 }
  149.                         }
  150.                         else
  151.                         {
  152.                                 Timing_Beep = 0;
  153.                                 Beep_Flag = 0;
  154.                                 Beep = 0;
  155.                                 LED_Green = 1;
  156.                                 LED_Red = 1;
  157.                         }
  158.                 }
  159.
  160.                 if( SW_1 == 0 )
  161.                 {
  162.                         if( Touch == 1 )
  163.                         {
  164.                                 if( Door_Close_Flag == 2 )
  165.                                         Door_Close_Flag = 1;
  166.                                 if( Door_Close_Flag == 1 )
  167.                                 {
  168.                                         Timing_Door_Close ++;
  169.                                         if( Timing_Door_Close <= 1000 )
  170.                                         {
  171.                                                 IN_1 = 1;
  172.                                                 IN_2 = 0;
  173.                                                 LED_3 = 1;
  174.                                                 LED_4 = 0;
  175.                                         }
  176.                                         else
  177.                                         {
  178.                                                 Open_Flag = 0;
  179.                                                 IN_1 = 0;
  180.                                                 IN_2 = 0;
  181.                                                 LED_3 = LED_4 = 1;
  182.                                                 Timing_Door_Close = 0;
  183.                                                 Door_Close_Flag = 0;
  184.                                                 LED_Green = 0;
  185.                                         }
  186.                                 }
  187.                         }
  188.                         else
  189.                         {
  190.                                 if( Timing_Door_Close != 0 )
  191.                                 {
  192.                                         Timing_Door_Open ++;
  193.                                         if( Timing_Door_Open <= Timing_Door_Close )
  194.                                         {
  195.                                                 IN_1 = 0;
  196.                                                 IN_2 = 1;
  197.                                                 LED_3 = 1;
  198.                                                 LED_4 = 0;
  199.                                         }
  200.                                         else
  201.                                         {
  202.                                                 Door_Close_Flag = 2;
  203.                                                 Timing_Door_Open = 0;
  204.                                                 Timing_Door_Close = 0;
  205.                                                 IN_1 = 0;
  206.                                                 IN_2 = 0;
  207.                                                 LED_3 = LED_4 = 1;
  208.                                         }
  209.                                 }
  210.                         }
  211.                 }
  212.                 else
  213.                 {
  214.                         Door_Close_Flag = 0;
  215.                         Timing_Door_Open = 0;
  216.                         Timing_Door_Close = 0;
  217.                         IN_1 = 0;
  218.                         IN_2 = 0;
  219.                         LED_3 = LED_4 = 1;
  220.                 }
  221.         }
  222. }
本人初学,仅供参考,存在错误和不足之处,请大家回帖多多指教,切勿照搬,文件下载:
Keil代码与Proteus仿真下载:
电磁屏蔽门.zip (111.48 KB, 下载次数: 38)
收藏收藏2 分享淘帖 顶 踩
