查看: 2208|回复: 1
通过超声波测距选择性亮灯arduino程序
ID:420243 发表于 2018-11-3 20:51 | 显示全部楼层 |阅读模式
long duration,inches,cm;
const int trigPin=8;
const int echoPin=7;
int ledr = 5;
int ledb = 4;
int ledg = 2;
long dist=0;
void setup() {
  // put your setup code here, to run once:
  pinMode(ledb, OUTPUT);
  pinMode(ledg, OUTPUT);
  pinMode(ledr, OUTPUT);
  pinMode(trigPin,OUTPUT);
  pinMode(echoPin,INPUT);
  Serial.begin(9600);
void loop() {
  // put your main code here, to run repeatedly:
digitalWrite(trigPin,LOW);
delayMicroseconds(2);
digitalWrite(trigPin,HIGH);
delayMicroseconds(5);
duration=pulseIn(echoPin,HIGH);
dist=duration/29/2;
cm=dist;
if(dist<=50){
  digitalWrite(ledr,LOW);
  digitalWrite(ledg,HIGH);
  digitalWrite(ledb,HIGH);
  Serial.println(dist);
else if(dist<=100){
  digitalWrite(ledb,LOW);
  digitalWrite(ledr,HIGH);
else{
  digitalWrite(ledg,LOW);
delay(100);
ID:1 发表于 2018-11-4 02:17 | 显示全部楼层
补全原理图或者详细说明一下电路连接即可获得100+黑币
