查看: 3060|回复: 0
STM8L051F3寄存器片AD驱动
ID:46381 发表于 2019-3-10 18:13 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "Config.h"
u8 VDD_Value1=0;
void AD_IO_Init()
  PC_DDR_DDR4 = 0;        //  设置PD4为输入
  PC_CR1_C14 = 1;         //  设置PD4为上拉输入
  PC_CR2_C24 = 0;         //
void ADC_Init()
   ADC_CLK_EN();
   ADC1_TRIGR1_VREFINTON=1;//打开内部参考电压源
   ADC1_CR1_ADON=1;  //wakes up the ADC from Power down mode.
   ADC1_CR2_PRESC=1;//Select a sample time of 10 μs
//   0: f(ADC_CLK) = CK
//   1: f(ADC_CLK) = CK/2  //系统时钟此时为默认的16M/8=2M,这里分频后,fadc=2M/2=1M
   ADC1_SQR1_DMAOFF=1;    //关闭DMA,暂时不用
   ADC1_CR3_SMTP2=0x06;//采样时间为24 ADC clock cycles,也就是24*1us=24us
//000: 4 ADC clock cycles
//001: 9 ADC clock cycles
//010: 16 ADC clock cycles
//011: 24 ADC clock cycles
//100: 48 ADC clock cycles
//101: 96 ADC clock cycles
//110: 192 ADC clock cycles
//111: 384 ADC clock cycles
   ADC1_CR3_CHSEL=4;
   ADC1_SQR1_CHSEL_S28=1; //选择内部参考电压通道
   ADC1_CR1_EOCIE=1;
#pragma vector=0x14
__interrupt void ADC1_ISR(void)
   static uint16_t temp=0;
  u16 VDD_Value;
   ADC1_SR_EOC=0;
   temp = ADC1_DRH;
   temp = (temp<<8)+ADC1_DRL;
   VDD_Value=(uint32_t)1225*4096/temp;//得到的数值单位为mv
   VDD_Value1=(u8)(VDD_Value/100);
   asm("nop");
void ADC_START(void)
  ADC1_CR1_START  =       1;
void ADC_STOP(void)
//    ADC1_CR1_START  =       0;
