查看: 2976|回复: 5
单片机程序编译错误求大神帮助!新手上路!
ID:423279 发表于 2018-11-8 21:42 | 显示全部楼层 |阅读模式
求大神帮助!新手上路!
#include <reg52.h>
#define uint  unsigned int
#include <intrins.h>
sbit CS=P1^4;
sbit SCL=P1^5;
sbit DO=P1^6;
sbit beep = P1^3;
sbit rs=P1^0;
sbit rw=P1^1;
sbit e =P1^2;
sbit c_send   = P3^2;
sbit c_recive = P3^3;
uchar flag_hc_value;
long distance;
uint set_d;
bit flag_csb_juli;
uint  flag_time0;
bit flag_200ms = 1 ;
uchar guangxian;
uchar qiang_gx;
uchar ruo_gx;
uchar value;
uchar flag_alarm;
uchar miao = 0,fen = 0,shi;
uchar s_miao = 55,s_fen = 44,s_shi=0;
bit xuexi_start;
uchar menu_1;
uchar i;
uchar flag_gx  ;
uchar flag_juli ;
uchar flag_time = 0;
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
  for(j=0;j<120;j++);
void write_eeprom()
SectorErase(0x2000);
byte_write(0x2000, set_d % 256);
byte_write(0x2001, set_d / 256);
byte_write(0x2002, qiang_gx);
byte_write(0x2003, ruo_gx);
byte_write(0x2004, s_miao);
byte_write(0x2005, s_fen);
byte_write(0x2006, s_shi);
byte_write(0x2057, a_a);
void read_eeprom()
set_d = byte_read(0x2001);
set_d  = set_d * 256 + byte_read(0x2000);
qiang_gx = byte_read(0x2002);
ruo_gx   = byte_read(0x2003);
s_miao   = byte_read(0x2004);
s_fen   = byte_read(0x2005);
s_shi   = byte_read(0x2006);
a_a    = byte_read(0x2057);
void init_eeprom()
read_eeprom();
if(a_a != 2)
  set_d = 40;
  a_a = 2;
  qiang_gx = 80;
  ruo_gx = 20;
  s_miao = 0,s_fen = 45,s_shi=0;
  write_eeprom();
void delay_uint(uint q)
while(q--);
void write_com(uchar com)
e=0;
rs=0;
rw=0;
P0=com;
delay_uint(3);
e=1;
delay_uint(25);
e=0;
void write_data(uchar dat)
e=0;
rs=1;
rw=0;
P0=dat;
delay_uint(3);
e=1;
delay_uint(25);
e=0;
部分程序
万分感谢!!!!!!
是原型未声明吗 不会啊 求大神!
是原型未声明吗 不会啊 求大神!
ID:246251 发表于 2018-11-9 14:42 | 显示全部楼层
SectorErase();这个函数在哪写的
ID:423279 发表于 2018-11-9 20:32 | 显示全部楼层
求帮助 NKYproteus 仿真.rar (70.57 KB, 下载次数: 7)
ID:280876 发表于 2018-11-12 16:55 | 显示全部楼层
你还是贴代码上来吧,别人哪有那么多时间下载来看
ID:213173 发表于 2018-11-12 20:53 | 显示全部楼层
没有发现编译错误,下载程序如下:
#define DUAN P0
#include <reg52.h>
unsigned char code tab[]={0xa0,0xbb,0x62,0x2a,0x39,0x2c,0x24,0xba,0x20,0x28,0xff};
unsigned char code tab_dian[]={0x80,0x9b,0x42,0x0a,0x19,0x0c,0x04,0x9a,0x00,0x08,0xdf};
uchar pdata tt[51];
uchar scale=20,rsd_sec;
char min,sec;
bit bdata flag_auto,ss,flag_bs,flag_rsd,flag_jiejin=1;
uchar flag_set=0;
uchar lum;
void delay(uchar i);
sbit LED = P3^4;
sbit change= P2^3;
sbit set = P2^2;
sbit add = P2^1;
sbit sub = P2^0;
sbit rsd = P3^6;
sbit jiejin=P3^5;
sbit buzz=P3^7;
sbit W0=P2^7;
sbit W1=P2^6;
sbit W2=P2^5;
sbit W3=P2^4;
void display()
        if(flag_set==0)
                DUAN=tab[min/10];
                W0=0;
                delay(1);
                W0=1;
                DUAN=tab_dian[min%10];
                W1=0;
                delay(1);
                W1=1;
                DUAN=tab[sec/10];
                W2=0;
                delay(1);
                W2=1;
                DUAN=tab[sec%10];
                W3=0;
                delay(1);
                W3=1;
        else if(flag_set==1)
                if(ss==1)
                        DUAN=~tab[min/10];
                        W0=0;
                        delay(1);
                        W0=1;
                        DUAN=~tab_dian[min%10];
                        W1=0;
                        delay(1);
                        W1=1;
                        DUAN=~tab[10];
                        W0=0;
                        delay(1);
                        W0=1;
                        DUAN=~tab_dian[10];
                        W1=0;
                        delay(1);
                        W1=1;
                DUAN=~tab[sec/10];
                W2=0;
                delay(1);
                W2=1;
                DUAN=~tab[sec%10];
                W3=0;
                delay(1);
                W3=1;
                DUAN=~tab[min/10];
                W0=0;
                delay(1);
                W0=1;
                W1=0;
                delay(1);
                W1=1;
                if(ss==1)
                        DUAN=~tab[sec/10];
                        W2=0;
                        delay(1);
                        W2=1;
                        DUAN=~tab[sec%10];
                        W3=0;
                        delay(1);
                        W3=1;
                        DUAN=~tab[10];
                        W2=0;
                        delay(1);
                        W2=1;
                        DUAN=~tab[10];
                        W3=0;
                        delay(1);
                        W3=1;
void KEY()
        uint lum_mean,lum_all;
        uchar b,c;
        if(change==0)
                delay(10);
                if(change==0)
                        buzz=0;
                        flag_auto=!flag_auto;
                        if(flag_auto==1)
                        scale=20;
                while(!change) display();buzz=1;
        if(jiejin==0&&flag_jiejin==1)
                buzz=0;
                flag_jiejin=0;
        if(jiejin!=flag_jiejin)
                buzz=1;
                flag_jiejin=1;
        if(set==0)
                delay(10);
                if(set==0)
                        buzz=0;
                        flag_set++;
                        if(flag_set==3)
                        flag_set=0;
                        flag_bs=0;
                while(!set) display(); buzz=1;
        if(flag_set==1)
                if(add==0)
                        delay(10);
                        if(add==0)
                                buzz=0;
                                min++;
                                if(min>=60)
                                min=0;
                        while(!add) display(); buzz=1;
                if(sub==0)
                        delay(10);
                        if(sub==0)
                                buzz=0;
                                min--;
                                if(min>0)
                                min=59;
                        while(!sub) display(); buzz=1;
        if(flag_set==2)
                if(add==0)
                        delay(10);
                        if(add==0)
                                buzz=0;
                                sec++;
                                if(sec>=60)
                                sec=0;
                if(sub==0)
                        delay(10);
                        if(sub==0)
                                buzz=0;
                                sec--;
                                if(sec<0)
                                sec=59;
                while(!sub);
        if(flag_auto==0)
                if(flag_rsd==1)
                        for(b=0;b<49;b++)
                                tt=tt[b+1];
                        for(c=0;c<50;c++)
                                lum_all=lum_all+tt[c];
                        lum_mean=lum_all/50;
                        if(lum_mean<=30) scale=1;
                        else if(lum_mean>=150) scale=41;
                        else scale=((lum_mean-30)/3)+1;
                scale=1;
                if(flag_set==0)
                        if(add==0)
                                delay(10);
                                if(add==0)
                                //        buzz=0;
                                        scale++;
                                        if(scale>=41)
                                        scale=41;
                                        display();
                        if(sub==0)
                                delay(10);
                                if(sub==0)
                                        scale--;
                                        if(scale>1)
                                        scale=1;
                                        display();
void init()
        TMOD=0x11;
        TH1=0x3c;
        TL1=0xb0;
        TH0=0xff;
        TL0=0xe7;
        ET0=1;
        ET1=1;
        EA=1;
        TR0=1;
        TR1=0;
        init();
        flag_auto=1;
        rsd=0;
        delay(500);
                KEY();
                display();
void delay(uchar i)
  uchar j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void time0() interrupt 1
        uchar n;
        TH0=0xff;
        TL0=0xe7;
        n++;
        if(n>scale)
                LED=1;
        else if(n<=scale)
                LED=0;
        if(n==40)
                n=0;
        else ;
void time1() interrupt 3
        uchar m;
        TH1=0x3c;
        TL1=0xb0;
        m++;
        if((m==10||m==20)&&flag_set!=0)
                ss=!ss;
        if(m==20)
                m=0;
                if(rsd==0)
                rsd_sec++;
                if(rsd_sec<=30&&rsd==1)
                        rsd_sec=0;
                        flag_rsd=1;
                else if(rsd_sec>30&&rsd==0)
                        flag_rsd=0;
                        rsd_sec=0;
                if(flag_set==0&&flag_bs==0&&((min+sec)!=0))
                        sec--;
                        if(sec<0)
                                sec=59;
                                min--;
                        if(min<=0&&sec==0)
                                min=0;
                                flag_bs=1;
                                buzz=0;
ID:111339 发表于 2018-11-13 11:51 | 显示全部楼层
函数声明要放在调用之前
