查看: 11521|回复: 12
AT1846S引脚图与datasheet_v0.2资料下载
ID:77104 发表于 2018-10-30 17:37 | 显示全部楼层 |阅读模式
AT1846S引脚图:
AT1846S_datasheet_v0.2:
1.  General Description
The  AT1846S   is a highly  integrated single-chip
transceiver for Walkie Talkie applications. It totally
realizes the translation from RF carrier to voice in
the RX path and from voice to RF carrier in the TX
path, requiring only one micro controller.
The  AT1846S   has  a  powerful  digital  signal
processor,  which  makes  it  have  optimum  voice
quality,  flexible  function  options,  and  robust
performance under varying reception conditions.
The  AT1846S   can  be  tuned  to  the  worldwide
frequency band for Walkie Talkie from 400MHz to
500MHz and especially from 134MHz to 174MHz
which  meets  the  frequency  band  of  weather
broadcast.
The  transceiver  uses  the CMOS  process with  a
package  size  of  5X5mm.  By  virtue  of  its  high
integration,  it  requires  the  least  external
components  and  eliminates  the  complicated
design of sensitive RF circuits on PCB.
完整的pdf格式文档51黑下载地址:
AT1846S_datasheet_v0.2.pdf (7.75 MB, 下载次数: 159)
ID:406092 发表于 2019-2-24 21:40 | 显示全部楼层
正好需要,感谢!
ID:476826 发表于 2019-4-2 11:20 | 显示全部楼层
正好需要,感谢!
ID:570870 发表于 2019-6-24 15:19 | 显示全部楼层
正好需要,找了好久都没找到
ID:640938 发表于 2019-11-25 22:40 | 显示全部楼层
正好需要,非常感谢分享
ID:726675 发表于 2020-4-10 23:59 | 显示全部楼层
没有编程用的用户手册,哪位大有啊?
ID:605943 发表于 2020-6-8 12:59 | 显示全部楼层
下载来看看
ID:398557 发表于 2020-11-3 16:13 | 显示全部楼层
有没人用过这个片
ID:824490 发表于 2022-11-30 08:51 | 显示全部楼层
wth1688 发表于 2020-4-10 23:59
没有编程用的用户手册,哪位大有啊?
好象我有
ID:1135294 发表于 2024-11-2 11:02 | 显示全部楼层
感谢大神,正好需要这个资料
ID:1135294 发表于 2024-11-2 11:03 | 显示全部楼层
请问一下,这个1846跟RDA的是一回事吧?
ID:1135294 发表于 2024-11-2 11:04 | 显示全部楼层
这块PLL是如何选择的?片外实现?
ID:1135294 发表于 2024-11-2 11:05 | 显示全部楼层
这个跟RDA的是否是一样的?
