查看: 1706|回复: 2
这个LcdShowDat为什么没有调用呀,搞不懂呀
ID:453409 发表于 2018-12-24 15:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void delay_ms(unsigned int d);
void ScanKeyboard();
void LcdShowStr(unsigned char x,unsigned char y,unsigned char*str);
void LcdShowDat(unsigned char x,unsigned char y,unsigned char dat);
unsigned char cnt=0,w=0,key=0;
unsigned char code KeyCode[]=
{0xe7,0xd7,0xb7,0x77,0xeb,0xdb,0xbb,0x7b,0xed,0xdd,0xdb,0xbd,0x7d,0xee,0xde,0xbe,0x7e};
        unsigned char temp;
        unsigned char str[]="hello";
        TMOD=0X01;
        TH0=0X4C;
        TL0=0X00;
        IE=0X82;
        TR0=1;
        InitLcd1602();
        LcdShowStr(2,0,str);
        while(1);
        temp=w;
        LcdShowDat(4,1,temp);
void LcdWaitReady()
        unsigned char sta;
        LCD1602_DB=0XFF;
        LCD1602_RS=0;
        LCD1602_RW=1;
        do{
                LCD1602_E=1;
                sta=LCD1602_DB;
                LCD1602_E=0;
        while(sta&0x80);
void LcdWriteCmd(unsigned char cmd)
        LcdWaitReady();
        LCD1602_RS=0;
        LCD1602_RW=0;
        LCD1602_DB=cmd;
        LCD1602_E=1;
        LCD1602_E=0;
void LcdWriteDat(unsigned char dat)
        LcdWaitReady();
        LCD1602_RS=1;
        LCD1602_RW=0;
        LCD1602_DB=dat;
        LCD1602_E=1;
        LCD1602_E=0;
void LcdSetCursor(unsigned char x,unsigned char y)
        unsigned char addr;
        if(y==0)
        addr=0x00+x;
        addr=0x40+x;
        LcdWriteCmd(addr|0x80);
        LcdSetCursor(x,y);
        while(*str!='\0')
                LcdWriteDat(*str++);
        LcdSetCursor(x,y);
        LcdWriteDat(dat);
void InitLcd1602()
        LcdWriteCmd(0x38);
        LcdWriteCmd(0x0c);
        LcdWriteCmd(0x06);
        LcdWriteCmd(0x01);
void ScanKeyboard()
        unsigned char scan1,scan2,keyboard;
        unsigned char i;
        P2=0xf0;
        scan1=P2;
        if((scan1&0xf0)!=0xf0)
                delay_ms(10);
                scan1=P2;
                        P2=0xf0;
                        scan2=P2;
                        keyboard=scan1|scan2;
                        while((P2&0x0f)!=0x0f)
                        for(i=0;i<=15;i++)
                                if(keyboard==KeyCode[i])
                                key=i;
void clock()interrupt 1
        unsigned char key,i;
        cnt++;
        TH0=0X4C;
        TL0=0X00;
        ScanKeyboard();
        if(key==1)
                w=0x20;
        if(key==2)
                for(i=0;cnt<=20;i++)
                 w=0x61+0x01;
                 if(i==3)
                         i=0;
                         w=0x61;
        unsigned char i;
        while(d--)
                for(i=0;i<=110;i++);
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_LCDSHOWDAT?ABC
ID:451718 发表于 2018-12-24 17:52 | 只看该作者
主程序最后一个语句不是么?
另外,你这个程序能跑起来么? 真的有点佩服。建议你还是先初步了解一下单片机的教程,你框架结构有很大的问题。  中断里面处理了太多事,还没有等中断恢复,第二次中断就该响应了。
ID:453692 发表于 2018-12-24 17:54 | 只看该作者
子程序调用函数是不是有问题,是不是涉及到是否修改数值问题。三种传值方式
