查看: 2812|回复: 0
单片机tft_lcd128*128液晶屏操作相关函数头文件下载
ID:335111 发表于 2018-11-28 12:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
头文件:
  1. #ifndef _oled12864spi_H_
  2. #define _oled12864spi_H_
  3. #define RED          0xf800
  4. #define GREEN        0x07e0
  5. #define BLUE         0x001f
  6. #define WHITE        0xffff
  7. #define BLACK        0x0000
  8. #define YELLOW  0xFFE0
  9. #define GRAY0   0xEF7D
  10. #define GRAY1   0x8410
  11. #define GRAY2   0x4208
  12. #define MAGENTA 0xF81F           //×Ï
  13. #define CYAN        0x07FF           //Çà
  14. typedef unsigned char         uchar;
  15. typedef unsigned int          uint;
  16. void lcd_initial();
  17. void LCD_Clear(int color);//ÇåÆá
  18.
  19. void LCD_A_Char8X16(uint x, uint y, uint fc, uint bc, uchar *s)reentrant;
  20. void LCD_Char8X16_String(uint x,uint y,uint fc,uint bc,uchar *s,uchar c)reentrant;
  21. void LCD_CHN16X16(uint x, uint y, uint fc, uint bc, uchar *s);
  22. void LCD_CHN16X16_String(uint x,uint y,uint fc,uint bc,uchar *s,uchar c);
  23. //void LCD_CHN32X32(uint x, uint y, uint fc, uint bc, uchar *s); //ÏÔê¾ò»¸ö32*32oo×Ö
  24. //void LCD_CHN32X32_String(uint x,uint y,uint fc,uint bc,uchar *s,uchar c);//ÏÔê¾ò»′®32*32oo×Ö
  25. //void LCD_A_Char24X48(uint x, uint y, uint fc, uint bc, uchar *s);
  26. #endif
  27. C文件
  28. //********************************************************************************
  29. #include <intrins.h>
  30. #define uchar unsigned char
  31. #define uint unsigned int
  32. #include "delay.h"
  33. #include "tft128128spi.h"
  34. #include "STC15.h"
  35. //---------------------------液晶屏接线说明-------------------------------------//
  36. //接线前请参考液晶屏说明书第10页引脚定义
  37. sbit scl       =P2^7;//接模块CLK引脚,接裸屏Pin9_SCL
  38. sbit sda       =P2^6;//接模块DIN/MOSI引脚,接裸屏Pin8_SDA
  39. sbit reset     =P2^5;//接模块dcT引脚,接裸屏Pin6_RES
  40. sbit dc        =P2^4;//接模块D/C引脚,接裸屏Pin7_A0
  41. sbit cs        =P2^3;//接模块CE引脚,接裸屏Pin12_CS
  42. sbit bl        =P2^2;//接模块BL引脚,背光可以采用IO控制或者PWM控制,也可以直接接到高电平常亮
  43. //---------------------------End of液晶屏接线---------------------------------//
  44. bit USE_LANDSCAPE;//程序横竖屏切换
  45. //向液晶屏写一个8位指令
  46. void  LCD_WrCmd(uchar cmd)
  47. {
  48. uchar i;
  49. cs=0;dc=0;
  50. for(i=0;i<8;i++)
  51. {
  52.   scl=0;
  53.   if(cmd&0x80)sda=1;else sda=0;
  54.   scl=1;
  55.   cmd<<=1;
  56. }
  57. cs=1;
  58. }
  59. //向液晶屏写一个8位数据
  60. void  LCD_WrDat(uchar dat)
  61. {
  62. uchar i;
  63. cs=0;dc=1;
  64. for(i=0;i<8;i++)
  65. {
  66.   scl=0;
  67.   if(dat&0x80)sda=1;else sda=0;
  68.   scl=1;
  69.   dat<<=1;
  70. }
  71. cs=1;
  72. }
  73. //向液晶屏写一个16位数据
  74. void  LCD_WrDat_16Bit(uint dat)
  75. {
  76. LCD_WrDat(dat>>8);                         //写入高8位数据
  77. LCD_WrDat(dat);                         //写入低8位数据
  78. }
  79. void Reset()
  80. {
  81.     reset=0;
  82.     delayms(100);
  83.     reset=1;
  84.     delayms(100);
  85. }
  86. //////////////////////////////////////////////////////////////////////////////////////////////
  87. //液晶屏初始化 for S6D02A1
  88. void lcd_initial()
  89. {        Reset();//Reset before LCD Init.
  90.
  91.         //LCD Init For 1.44Inch LCD Panel with ST7735R.
  92.         LCD_WrCmd(0x11);//Sleep exit
  93.         delayms (120);
  94.
  95.         //ST7735R Frame Rate
  96.         LCD_WrCmd(0xB1);
  97.         LCD_WrDat(0x01);
  98.         LCD_WrDat(0x2C);
  99.         LCD_WrDat(0x2D);
  100.         LCD_WrCmd(0xB2);
  101.         LCD_WrDat(0x01);
  102.         LCD_WrDat(0x2C);
  103.         LCD_WrDat(0x2D);
  104.         LCD_WrCmd(0xB3);
  105.         LCD_WrDat(0x01);
  106.         LCD_WrDat(0x2C);
  107.         LCD_WrDat(0x2D);
  108.         LCD_WrDat(0x01);
  109.         LCD_WrDat(0x2C);
  110.         LCD_WrDat(0x2D);
  111.
  112.         LCD_WrCmd(0xB4); //Column invedcion
  113.         LCD_WrDat(0x07);
  114.
  115.         //ST7735R Power Sequence
  116.         LCD_WrCmd(0xC0);
  117.         LCD_WrDat(0xA2);
  118.         LCD_WrDat(0x02);
  119.         LCD_WrDat(0x84);
  120.         LCD_WrCmd(0xC1);
  121.         LCD_WrDat(0xC5);
  122.         LCD_WrCmd(0xC2);
  123.         LCD_WrDat(0x0A);
  124.         LCD_WrDat(0x00);
  125.         LCD_WrCmd(0xC3);
  126.         LCD_WrDat(0x8A);
  127.         LCD_WrDat(0x2A);
  128.         LCD_WrCmd(0xC4);
  129.         LCD_WrDat(0x8A);
  130.         LCD_WrDat(0xEE);
  131.
  132.         LCD_WrCmd(0xC5); //VCOM
  133.         LCD_WrDat(0x0E);
  134.
  135.         LCD_WrCmd(0x36); //MX, MY, RGB mode
  136. if(USE_LANDSCAPE)
  137.         LCD_WrDat(0xA8); //竖屏C8 横屏08 A8
  138. else
  139.         LCD_WrDat(0xC8); //竖屏C8 横屏08 A8
  140.
  141.         //ST7735R Gamma Sequence
  142.         LCD_WrCmd(0xe0);
  143.         LCD_WrDat(0x0f);
  144.         LCD_WrDat(0x1a);
  145.         LCD_WrDat(0x0f);
  146.         LCD_WrDat(0x18);
  147.         LCD_WrDat(0x2f);
  148.         LCD_WrDat(0x28);
  149.         LCD_WrDat(0x20);
  150.         LCD_WrDat(0x22);
  151.         LCD_WrDat(0x1f);
  152.         LCD_WrDat(0x1b);
  153.         LCD_WrDat(0x23);
  154.         LCD_WrDat(0x37);
  155.         LCD_WrDat(0x00);
  156.         LCD_WrDat(0x07);
  157.         LCD_WrDat(0x02);
  158.         LCD_WrDat(0x10);
  159.         LCD_WrCmd(0xe1);
  160.         LCD_WrDat(0x0f);
  161.         LCD_WrDat(0x1b);
  162.         LCD_WrDat(0x0f);
  163.         LCD_WrDat(0x17);
  164.         LCD_WrDat(0x33);
  165.         LCD_WrDat(0x2c);
  166.         LCD_WrDat(0x29);
  167.         LCD_WrDat(0x2e);
  168.         LCD_WrDat(0x30);
  169.         LCD_WrDat(0x30);
  170.         LCD_WrDat(0x39);
  171.         LCD_WrDat(0x3f);
  172.         LCD_WrDat(0x00);
  173.         LCD_WrDat(0x07);
  174.         LCD_WrDat(0x03);
  175.         LCD_WrDat(0x10);
  176.
  177.         LCD_WrCmd(0x2a);
  178.         LCD_WrDat(0x00);
  179.         LCD_WrDat(0x00+2);
  180.         LCD_WrDat(0x00);
  181.         LCD_WrDat(0x80+2);
  182.         LCD_WrCmd(0x2b);
  183.         LCD_WrDat(0x00);
  184.         LCD_WrDat(0x00+3);
  185.         LCD_WrDat(0x00);
  186.         LCD_WrDat(0x80+3);
  187.
  188.         LCD_WrCmd(0xF0); //Enable test command
  189.         LCD_WrDat(0x01);
  190.         LCD_WrCmd(0xF6); //Disable ram power save mode
  191.         LCD_WrDat(0x00);
  192.
  193.         LCD_WrCmd(0x3A); //65k mode
  194.         LCD_WrDat(0x05);
  195.
  196.
  197.         LCD_WrCmd(0x29);//Display on
  198.         bl=1;                         //背光
  199. }
  200. /*************************************************
  201. 函数名:LCD_Set_Region
  202. 功能:设置lcd显示区域,在此区域写点数据自动换行
  203. 入口参数:xy起点和终点
  204. 返回值:无
  205. *************************************************/
  206. void Lcd_SetRegion(uint x_start,uint y_start,uint x_end,uint y_end)reentrant
  207. {
  208. if(USE_LANDSCAPE)//使用横屏模式
  209.    {
  210.     LCD_WrCmd(0x2a);
  211.         LCD_WrDat(0x00);
  212.         LCD_WrDat(x_start+3);
  213.         LCD_WrDat(0x00);
  214.         LCD_WrDat(x_end+3);
  215.         LCD_WrCmd(0x2b);
  216.         LCD_WrDat(0x00);
  217.         LCD_WrDat(y_start+2);
  218.         LCD_WrDat(0x00);
  219.         LCD_WrDat(y_end+2);
  220.    }
  221. else//竖屏模式
  222.   {
  223.         LCD_WrCmd(0x2a);
  224.         LCD_WrDat(0x00);
  225.         LCD_WrDat(x_start+2);
  226.         LCD_WrDat(0x00);
  227.         LCD_WrDat(x_end+2);
  228.         LCD_WrCmd(0x2b);
  229.         LCD_WrDat(0x00);
  230.         LCD_WrDat(y_start+3);
  231.         LCD_WrDat(0x00);
  232.         LCD_WrDat(y_end+3);
  233.   }
  234.         LCD_WrCmd(0x2c);
  235. }
  236. void LCD_Clear(int color)
  237. {
  238.          uchar i,j;
  239.         Lcd_SetRegion(0,0,128-1,128-1);
  240.          for (i=0;i<128;i++)
  241.             for (j=0;j<128;j++)
  242.                 LCD_WrDat_16Bit(color);
  243. }
  244. void LCD_A_Char8X16(uint x, uint y, uint fc, uint bc, uchar *s)reentrant
  245. {
  246. uchar i,j,temp;
  247. Lcd_SetRegion(x,y,x+8-1,y+16-1);
  248. for(i=0;i<16;i++)
  249.         {
  250.          temp=s[ i];[ i]
  251.          for(j=0;j<8;j++)
  252.            {
  253.             if(temp&0x80)LCD_WrDat_16Bit(fc);
  254.                 else if        (fc!=bc) LCD_WrDat_16Bit(bc);
  255.             temp<<=1;
  256.            }
  257.         }
  258. }
  259. void LCD_Char8X16_String(uint x,uint y,uint fc,uint bc,uchar *s,uchar c)reentrant
  260. {
  261. uchar i;
  262. for(i=0;i<c;i++) LCD_A_Char8X16(x+i*8,y,fc,bc,s+i*16);
  263. }
  264. void LCD_CHN16X16(uint x, uint y, uint fc, uint bc, uchar *s) //显示一个汉字
  265. {
  266. uchar i,j,temp;
  267. Lcd_SetRegion(x,y,x+16-1,y+16-1);
  268. for(i=0;i<32;i++)
  269.         {
  270.          temp=s[ i];[ i]
  271.          for(j=0;j<8;j++)
  272.            {
  273.             if(temp&0x80)LCD_WrDat_16Bit(fc);
  274.                 else if        (fc!=bc) LCD_WrDat_16Bit(bc);
  275.             temp<<=1;
  276.            }
  277.         }
  278. }
  279. void LCD_CHN16X16_String(uint x,uint y,uint fc,uint bc,uchar *s,uchar c)
  280. {
  281. uchar i;
  282. for(i=0;i<c;i++)LCD_CHN16X16(x+i*16,y,fc,bc,s+i*32);
  283. }
  284. //void LCD_A_Char16X32(uint x, uint y, uint fc, uint bc, uchar *s)
  285. //{
  286. // uchar i,j,temp;
  287. // Lcd_SetRegion(x,y,x+16-1,y+32-1);
  288. // for(i=0;i<64;i++)                                                  //16*32西文字符点阵64个8位字节
  289. //        {
  290. //         temp=s[ i];[ i]
  291. //         for(j=0;j<8;j++)
  292. //           {
  293. //            if(temp&0x80)LCD_WrDat_16Bit(fc);
  294. //                else if        (fc!=bc) LCD_WrDat_16Bit(bc);
  295. //            temp<<=1;
  296. //           }
  297. //        }
  298. //
  299. //}
  300. /*
  301. void LCD_A_Char24X48(uint x, uint y, uint fc, uint bc, uchar *s)
  302. {
  303. uchar i,j,temp;
  304. Lcd_SetRegion(x,y,x+24-1,y+48-1);
  305. for(i=0;i<144;i++)                                                  //24*48西文字符点阵144个8位字节
  306.         {
  307.          temp=s[ i];[ i]
  308.          for(j=0;j<8;j++)
  309.            {
  310.             if(temp&0x80)LCD_WrDat_16Bit(fc);
  311.                 else if        (fc!=bc) LCD_WrDat_16Bit(bc);
  312.             temp<<=1;
  313.            }
  314.         }
  315. }
  316. void LCD_CHN32X32(uint x, uint y, uint fc, uint bc, uchar *s) //显示一个32*32汉字
  317. {
  318. uchar i,j,temp;
  319. Lcd_SetRegion(x,y,x+32-1,y+32-1);
  320. for(i=0;i<128;i++)        //32*32汉字128字节
  321.         {
  322.          temp=s[ i];[ i]
  323.          for(j=0;j<8;j++)
  324.            {
  325.             if(temp&0x80)LCD_WrDat_16Bit(fc);
  326.                 else if        (fc!=bc) LCD_WrDat_16Bit(bc);
  327.             temp<<=1;
  328.            }
  329.         }
  330. }
  331. void LCD_CHN32X32_String(uint x,uint y,uint fc,uint bc,uchar *s,uchar c)//显示一串32*32汉字
  332. {
  333. uchar i;
  334. for(i=0;i<c;i++)LCD_CHN32X32(x+i*32,y,fc,bc,s+i*128);
  335. }
  336. */
