查看: 4593|回复: 0
关于Proteus仿真8086CPU的一些问题
ID:437959 发表于 2018-12-6 22:07 | 显示全部楼层 |阅读模式
proteus仿真,用8个开关控制数码管显示1到8的数字,仿真电路图如图示(运行状态),代码如下,请问是出了什么问题,代码这么写有问题吗?
  1. code segment
  2.         assume cs:code
  3. start:        mov dx,200h
  4.         in al,dx
  5.         mov bl,al
  6.         cmp bl,7Fh;与对应的状态比较
  7.         jz s1
  8.         cmp bl,0BFh
  9.         jz s2
  10.         cmp bl,0DFh
  11.         jz s3
  12.         cmp bl,0EFh
  13.         jz s4
  14.         cmp bl,0F7h
  15.         jz s5
  16.         cmp bl,0FBh
  17.         jz s6
  18.         cmp bl,0FDh
  19.         jz s7
  20.         cmp bl,0FEh
  21.         jz s8
  22. ;显示数字
  23. s1:        mov al,06h
  24.         out dx,al
  25.         jmp to
  26. s2:        mov al,5bh
  27.         out dx,al
  28.         jmp to
  29. s3:        mov al,4fh
  30.         out dx,al
  31.         jmp to
  32. s4:        mov al,66h
  33.         out dx,al
  34.         jmp to
  35. s5:        mov al,6dh
  36.         out dx,al
  37.         jmp to
  38. s6:        mov al,7dh
  39.         out dx,al
  40.         jmp to
  41. s7:        mov al,07h
  42.         out dx,al
  43.         jmp to
  44. s8:         mov al,7fh
  45.         out dx,al
  46.         jmp to
  47. to:jmp start
  48. code ends
  49.         end start
