查看: 1959|回复: 0
单片机秒表仿真+代码工程
  1. #include<reg51.h>
  2. unsigned char code discode1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
  3. unsigned char code discode2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  4. unsigned char timer=0;
  5. unsigned char second;
  6. unsigned char key=0;
  7. main()
  8. {
  9.         TMOD=0x01;
  10.         ET0=1;
  11.         EA=1;
  12.         second=0;
  13.         P0=discode1[second/10];
  14.         P2=discode2[second%10];
  15.         while(1)
  16.         {
  17.                 if((P3&0x80)==0x00)
  18.                 {
  19.                         key++;
  20.                         switch(key)
  21.                         {
  22.                                 case 1:
  23.                                         TH0=0xee;
  24.                                         TL0=0x00;
  25.                                         TR0=1;
  26.                                         break;
  27.                                 case 2:
  28.                                         TR0=0;
  29.                                         break;
  30.                                 case 3:
  31.                                         key=0;
  32.                                         second=0;
  33.                                         P0=discode1[second/10];
  34.                                         P2=discode2[second%10];
  35.                                         break;
  36.                         }
  37.                         while((P3&0x80)==0x00);
  38.                 }
  39.         }
  40. }
  41. void int_T0() interrupt 1 using 0
  42. {
  43.         TR0=0;
  44.         TH0=0xee;
  45.         TL0=0x00;
  46.         timer++;
  47.         if(timer==20)
  48.         {
  49.                 timer=0;
  50.                 second++;
  51.                 P0=discode1[second/10];
  52.                 P2=discode2[second%10];
  53.         }
  54.                 if(second==99)
  55.                 {
  56.                         TR0=0;
  57.                         second=0;
  58.                         key=2;
  59.                 }
  60.                 else
  61.                 {
  62.                         TR0=1;
  63.                 }
  64. }
  65.
单片机实验 秒表.zip (27.89 KB, 下载次数: 19)
