查看: 1472|回复: 2
[提问]程序调试一直出现看门狗重置 程序是单片机串行输出
  1. #include "reg51.h"
  2. sfr SWDT=0xB8;
  3. sfr WDTS=0xA9;
  4. sfr WDT=0xA8;
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. code Tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//
  8. void send(unsigned char dat)
  9. {
  10.         SBUF=dat;
  11.         while(TI==0);
  12.         ;
  13.         TI=0;
  14. }
  15.         void delay(void)//200ms
  16.         {
  17.                 unsigned char m,n;
  18.                 for(m=0; m<250; m++)
  19.                 for(n=0; n<250; n++)
  20.                 ;
  21.         }
  22.         void main(void)
  23.         {
  24.                 unsigned char i;
  25. //                WDTRST=0x1e;
  26.                 WDTS =0xff;
  27.     WDT=0x0;
  28.                 SWDT =0x0;
  29.                 TMOD=0x20;
  30.                 TH1=0xfd;//9600
  31.                 TL1=0xfd;
  32.                 SCON=0x40;
  33.                 PCON=0x00;
  34.                 TR1=1
  35.                 while(1)
  36.         {
  37.                 for(i=0;i<8;i++)
  38.                 {
  39.                         send(Tab[i]);
  40.                         delay( );
  41.                 }
  42.                 while(1);
  43.                 }
  44.         }
ID:303394 发表于 2019-1-25 14:55 | 只看该作者
开了看门狗,要记得喂狗啊
ID:472515 发表于 2019-1-25 15:17 | 只看该作者
是不是只能外部接口(PE/SWD)手动操作的;不小心传了别的
