查看: 7622|回复: 10
单片机LED灯出现不灭或一直闪烁怎么解决?
  1. #include<reg52.h>      //52系列单片机头文件
  2. #define uchar unsigned char     //宏定义
  3. #define uint unsigned int
  4. sbit led1=P2^0;sbit led2=P2^1;
  5. sbit led3=P2^2;sbit led4=P2^3;
  6. sbit led5=P2^4;sbit led6=P2^5;
  7. sbit led7=P2^6;sbit led8=P2^7;
  8. sbit led9=P3^0;
  9. sbit key1=P3^1;sbit key2=P3^2;
  10. sbit key3=P3^3;sbit key4=P3^4;
  11. /*************************延时函数*****************************/
  12. void delay1ms(uint y)
  13. {
  14.                 uint j;
  15.                 while(y--)for(j=0;j<120;j++);
  16. }
  17. /*************************子函数******************************/
  18. uchar flag;
  19. uchar flag2;
  20. void keyplus(void)
  21. {
  22.                                 if(key1==0)                                //确认按键是否被按下
  23.                                 {
  24.                                                 delay1ms(5);    //延时消抖动
  25.                                                 if(key1==0)     //消抖后在判断按键是否按下
  26.                                                 {
  27.        while(!key1);   //等待按键释放
  28.        flag++;
  29.        if(flag==10)flag=1;
  30.                                                 }
  31.                                 }
  32.                                 switch(flag)
  33.                                 {
  34.                                         case 1:
  35.                                                 led1=0;
  36.                                                 break;
  37.                                         case 2:
  38.                                                 led2=0;
  39.                                                 break;
  40.                                         case 3:
  41.                                                 led3=0;
  42.                                                 break;
  43.                                         case 4:
  44.                                                 led4=0;
  45.                                                 break;
  46.                                         case 5:
  47.                                                 led5=0;
  48.                                                 break;
  49.                                         case 6:
  50.                                                 led6=0;
  51.                                                 break;
  52.                                         case 7:
  53.                                                 led7=0;
  54.                                                 break;
  55.                                         case 8:
  56.                                                 led8=0;
  57.                                                 break;
  58.                                         case 9:
  59.                                                 led9=0;
  60.                                                 break;
  61.                                 }
  62.
  63. }
  64. void keyreduce(void)
  65. {
  66.                                 if(key2==0)                                //确认按键是否被按下
  67.                                 {
  68.                                                 delay1ms(5);    //延时消抖动
  69.                                                 if(key2==0)     //消抖后在判断按键是否按下
  70.                                                 {
  71.        while(!key2);   //等待按键释放
  72.        flag2++;
  73.        if(flag2==10)flag2=1;
  74.                                                 }
  75.                                 }
  76.                                 switch(flag2)
  77.                                 {
  78.                                         case 1:
  79.                                                 led9=1;
  80.                                                 break;
  81.                                         case 2:
  82.                                                 led8=1;
  83.                                                 break;
  84.                                         case 3:
  85.                                                 led7=1;
  86.                                                 break;
  87.                                         case 4:
  88.                                                 led6=1;
  89.                                                 break;
  90.                                         case 5:
  91.                                                 led5=1;
  92.                                                 break;
  93.                                         case 6:
  94.                                                 led4=1;
  95.                                                 break;
  96.                                         case 7:
  97.                                                 led3=1;
  98.                                                 break;
  99.                                         case 8:
  100.                                                 led2=1;
  101.                                                 break;
  102.                                         case 9:
  103.                                                 led1=1;
  104.                                                 break;
  105.                                 }
  106. }
  107. /*************************主函数******************************/
  108. void main()
  109. {
  110.                 while(1)
  111.                 {
  112.                                 keyjia();
  113.                                 keyjian();
  114.                 }
  115. }
ID:213173 发表于 2019-3-4 18:05 | 只看该作者
这样写就没有问题了
  4. sbit led1=P2^0;
  5. sbit led2=P2^1;
  6. sbit led3=P2^2;
  7. sbit led4=P2^3;
  8. sbit led5=P2^4;
  9. sbit led6=P2^5;
  10. sbit led7=P2^6;
  11. sbit led8=P2^7;
  12. sbit led9=P3^0;
  13. sbit key1=P3^1;
  14. sbit key2=P3^2;
  15. sbit key3=P3^3;
  16. sbit key4=P3^4;
  17. uchar flag;
  18. //uchar flag2;
  19. /*************************延时函数*****************************/
  20. void delay1ms(uint y)
  21. {
  22.         uint j;
  23.         while(y--)
  24.         for(j=0;j<120;j++);
  25. }
  26. /*************************子函数******************************/
  27. void keyscan()
  28. {
  29.         if(key1==0)  //确认按键是否被按下
  30.         {
  31.                 delay1ms(5);    //延时消抖动
  32.                 if(key1==0)     //消抖后在判断按键是否按下
  33.                 {
  34.                         if(flag<9)
  35.                                 flag++;
  36.                         switch(flag)
  37.                         {
  38.                                 case 1:led1=0;break;
  39.                                 case 2:led2=0;break;
  40.                                 case 3:led3=0;break;
  41.                                 case 4:led4=0;break;
  42.                                 case 5:led5=0;break;
  43.                                 case 6:led6=0;break;
  44.                                 case 7:led7=0;break;
  45.                                 case 8:led8=0;break;
  46.                                 case 9:led9=0;break;
  47.                         }
  48.                         while(!key1);   //等待按键释放
  49.                 }
  50.         }
  51.         if(key2==0)                                //确认按键是否被按下
  52.         {
  53.                 delay1ms(5);    //延时消抖动
  54.                 if(key2==0)     //消抖后在判断按键是否按下
  55.                 {
  56.                         if(flag>0)
  57.                                 flag--;
  58.                         switch(flag)
  59.                         {
  60.                                 case 0:led1=1;break;
  61.                                 case 1:led2=1;break;
  62.                                 case 2:led3=1;break;
  63.                                 case 3:led4=1;break;
  64.                                 case 4:led5=1;break;
  65.                                 case 5:led6=1;break;
  66.                                 case 6:led7=1;break;
  67.                                 case 7:led8=1;break;
  68.                                 case 8:led9=1;break;
  69.                         }
  70.                         while(!key2);   //等待按键释放
  71.                 }
  72.         }
  73. }
  74. /*************************主函数******************************/
  75. void main()
  76. {
  77.         while(1)
  78.         {
  79.                 keyscan();
  80.         }
  81. }
参与人数 1黑币 +1 收起 理由
魔法少女 + 1 赞一个!
ID:10947 发表于 2019-3-4 18:48 | 只看该作者
每个分支里,亮灯1秒后灭灯
ID:484462 发表于 2019-3-4 19:59 | 只看该作者
是不是 延时太短了
ID:484376 发表于 2019-3-5 09:28 | 只看该作者
写的很详细,感谢分享!
ID:471161 发表于 2019-3-5 16:45 | 只看该作者
wulin 发表于 2019-3-4 18:05
这样写就没有问题了
C:\Users\Administrator\Desktop\12.jpg想加多个按键依次点亮LED循环怎么写
