查看: 1895|回复: 1
51单片机 甲醛采集程序
ID:497387 发表于 2019-3-24 18:18 | 显示全部楼层 |阅读模式
stc12c5a60s2 甲醛程序
        timer0();
        init_uart0();  //初始化串口功能
        LCD_Init();           //初始化液晶
        DelayMs(50);          //延时有助于稳定
        LCD_Clear();          //清屏
        DelayUs2x(10);
        Uart0SendString("01",2); //发送数据
        buzzer = 0;DelayMs(50); buzzer = 1;
        while (1)
                if(disFlag == 1)   //更新显示
                        disFlag = 0 ;//显示标志
                        sprintf(dis0,"nowV: %05.1fv  ",voltA);        //打印        );//打印
                        LCD_Write_String(0,0,dis0);
                        jiaQuan = pow (10,((-2.631+1.528*voltA+(-0.125)*voltA*voltA)));//该计算公式从手册中来Log(ppm) = (-2.631) + 1.528 * (Vout) + (0.125) * (Vout)*(Vout)2
                        sprintf(dis1,"JQ:%4.1fppm    ",jiaQuan);//显示甲醛大小
                        LCD_Write_String(0,1,(unsigned char *)dis1);
                        if(jiaQuan>=2)//浓度过高
                        {buzzer = !buzzer;}
                        {buzzer = 1;}
                        uNum++;
                        if(uNum>=4)//延时计数到
                                uNum = 0; //重新计数
                                Uart0SendString(dis0,16); //发送数据
                                DelayMs(5);
                                Uart0SendString("\r\n",2); //发送数据
                                DelayMs(5);
                                Uart0SendString(dis1,16); //发送数据
                                DelayMs(5);
                if(readADflag == 1)           //读取ad标志           定时器中置1
                        InitADC(0);                  //读取电压
                        readADflag=0;         //清除标志
51-甲醛.zip
93.36 KB, 下载次数: 7, 下载积分: 黑币 -5
ID:1 发表于 2019-3-25 00:16 | 显示全部楼层
