查看: 2041|回复: 0
lcd1602 简单显示程序 可用来做液晶程序模板
ID:504391 发表于 2019-4-14 20:17 | 显示全部楼层 |阅读模式
#include<reg52.h>
void write_com(uchar com);
void write_date(uchar dat);
void delay(uint);
void init();
uchar code table[]="I LIKE WMY";
uchar code table1[]="I LIKE LSF";
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
uint num;
    init();
   for(num=0;num<10;num++)
          write_date(table[num]);
          delay(20);
        write_com(0x80+0x40);
          write_date(table1[num]);
          delay(20);
   while(1);
void init()
  RW=0;
  E=0;
  write_com(0x38);
  write_com(0x0f);
  write_com(0x06);
  write_com(0x01);
  write_com(0x80);
  RS=0;
  P0=com;
  delay(10);
  E=1;
  delay(10);
  E=0;
  RS=1;
  P0=dat;
//  delay(1);
  E=1;
  delay(1);
  E=0;
void delay(uint x)
  uint i,j;
   for(i=x;i>0;i--)
     for(j=110;j>0;j--);
}#include<reg52.h>
void delay(uint);
void init();
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
uint num;
    init();
          delay(20);
          delay(20);
   while(1);
void init()
  RW=0;
  E=0;
  write_com(0x38);
  write_com(0x0f);
  write_com(0x06);
  write_com(0x01);
  write_com(0x80);
  RS=0;
  P0=com;
  delay(10);
  E=1;
  delay(10);
  E=0;
  RS=1;
  P0=dat;
//  delay(1);
  E=1;
  delay(1);
  E=0;
void delay(uint x)
  uint i,j;
   for(i=x;i>0;i--)
     for(j=110;j>0;j--);
