查看: 2023|回复: 2
请教各位大神一个关于光立方的小问题。
#include"STC15F2K60S2.h"
#define Segs  P0
#define Out   P1
#define Anm_speed  4
unsigned char code table[]={
//第0帧
0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x01,
0x02,0x02,0x02,0x02,0x02,0x02,0x01,0x01,
unsigned char code Segs_tab[]={
0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf,
0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,
0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,
unsigned char idata Rec_buf[64]={
0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
sbit Rest=P3^0;
void IO_Interrupt_UART_Init();
unsigned char T1_count=0,Anm1=0,Mode=0,Rec_count=0;
unsigned int End,Anm=0;
        End=sizeof(table);
                if(Anm>End)Anm=0;
                Segs=Segs_tab[Anm1];
                switch (Mode)
                        case 0:Out=table[Anm1+Anm];break;//这个Anm1和Anm都是0呀,怎么调用的数组呢。
                        case 1:Out=Rec_buf[Anm1];break;
                        default:break;
void IO_Interrupt_UART_Init()//这个子函数全是控制串口中断的吗
        P0M1=0x00;
        P0M0=0x00;
        P1M1=0x00;
        P1M0=0xff;
        EA=1;
        EX0=1;
        IT0=1;
        ET0=1;
        ET1=1;
        ES=1;
        AUXR |= 0x80;                //定时器时钟1T模式
        TMOD &= 0xF0;                //设置定时器模式
        TL0 = 0x5C;                //设置定时初值
        TH0 = 0xF7;                //设置定时初值
        TF0 = 0;                //清除TF0标志
        TR0 = 1;                //定时器0开始计时
        AUXR &= 0xBF;                //定时器时钟12T模式
        TMOD &= 0x0F;                //设置定时器模式
        TL1 = 0x00;                //设置定时初值
        TH1 = 0x70;                //设置定时初值
        TF1 = 0;                //清除TF1标志
        TR1 = 1;                //定时器1开始计时
        SCON = 0x50;                //8位数据,可变波特率
        AUXR |= 0x04;                //定时器2时钟为Fosc,即1T
        T2L = 0xD0;                //设定定时初值
        T2H = 0xFF;                //设定定时初值
        AUXR |= 0x01;                //串口1选择定时器2为波特率发生器
void Button() interrupt 0
        Mode=Mode+1;
        if(Mode==1)
                AUXR |= 0x10;
                ET1=0;
                TR1=0;
                Anm=0;
                Anm1=0;
        if(Mode>1)IAP_CONTR=0x60;
void Display_delay() interrupt 1//请问这个定时器0中断什么时候调用呀
          TR0=0;
          Anm1=Anm1+1;
          if(Anm1>63)Anm1=0;
          Out=0x00;
          Segs=0xff;
          TR0=1;
void LED_Display() interrupt 3        //请问这个定时器1中断什么时候调用呀
        TR1=0;
        T1_count++;
                if(T1_count==Anm_speed)
                        T1_count=0;
                        Anm=Anm+64;
        TR1=1;
void uart_receive() interrupt 4
        unsigned char ch;
        ES=0;
        if(RI)//若ri=1则执行该语句
                ch=SBUF;
                Rec_buf[Rec_count]=ch;
                Rec_count++;
                if(Rec_count>63)Rec_count=0;
        RI=0;
        ES=1;
这是原理图。
这是原理图。
ID:252667 发表于 2018-3-19 15:48 | 只看该作者
自顶0001
ID:500015 发表于 2019-5-17 08:43 | 只看该作者
使用定时器溢出进入中断,在初始化那里不是不是有定时器的赋初值吗
