查看: 1752|回复: 3
一个语法错误找不出来,望指明
#include <reg52.h>
#include<intrins.h>
uint K=0;
uchar code tabel[][8]=        {0x81,0xFD,0xFD,0x81,0xFD,0xFD,0x81,0xFF,
0x81,0xBF,0xBF,0x81,0xFD,0xFD,0x81,0xFF,0x81,0xF7,0xF7,0xF7,0xD7,0xC7,0xE7,0xFF};
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void KEY()
        P3=0Xf0;
        if(P3!=0xf0)
                delay(20);
                if(P3!=0xf0)
                        switch(P3)
                                case 0xe0: K=0;        break;
                                case 0xd0: K=1; break;
                                case 0xb0: K=2; break;
                                case 0x70: K=3; break;
                        P3=0x0f;
                        switch(P3)
                                case 0x0e: K=K; break;
                                case 0x0d: K=K+4; break;
                                case 0x0b: K=K+8; break;
                                case 0x07: K=K+12; break;
                        while(P3!=0X0f);
        P3=0xff;
        if(P3!=0xff)
                delay(20);
                if(P3!=0xff)
                        switch(P3)
                                case 0xfe: K=16; break;
                                case 0xfd: K=17; break;
                                case 0xfb: K=18; break;
                                case 0xf7: K=19; break;
                        while(P3!=0xff);
sbit DIO=P3^4;
sbit S_CLK=P3^5;
sbit R_CLK=P3^6;
void Send_Byte(uchar dat)
        uchar i;
        S_CLK=0;
        R_CLK=0;
        for(i=0;i<8;i++)
                if(dat & 0x01)
                        DIO=1;
                        DIO=0;
                S_CLK=1;
                dat >>= 1;
                S_CLK=0;
void Out_Byte()
          uchar ROM,j;
        ROM=0X80;
        for(j=0;j<8;j++)
                Send_Byte(tabel[K][j]);
                Send_Byte(ROM);
                R_CLK=1;
                ROM=_cror_(ROM,1);
                void KEY();
                P3=0X00;
                void Out_Byte();
                delay(100);
ID:342822 发表于 2021-12-3 22:53 | 只看该作者
                 KEY();
                P3 = 0X00;
                Out_Byte();
                delay(100);
ID:908826 发表于 2021-12-4 10:32 | 只看该作者
主函数里面那个调用函数,把返回类型去掉,不能这么写。
ID:57657 发表于 2021-12-4 10:47 | 只看该作者
C语言有这种写法?
