查看: 4776|回复: 4
基于51单片机的出租车计费系统Proteus仿真原理图PCB与源程序
用51单片机做了一个模拟计程车计费系统,内容包括AD画图,PCB制作,Protues仿真,代码程序。
电路原理图如下:
  1. #include "include.h"
  2. bit fare_flag = 0;//开始计费标志
  3. uchar hour,min,sec;//时钟三变量
  4. uchar vol,speed;//AD输出电压和模拟速度
  5. uchar dang_flag = 0;//档位
  6. uchar mode  = 1;//数码管显示3个界面
  7. uint cost,cost1,time;//计费时间和费用
  8. void Timer0_Init(void);
  9. void main(void)
  10. {
  11.         uchar temp;
  12.
  13.         init_ds1302();
  14.         Timer0_Init();
  15.         pcf8591_write(3);
  16.         LED = 0;
  17.         while(1)
  18.         {
  19.                 sec = Read_Ds1302_Byte(0x81);
  20.                 min = Read_Ds1302_Byte(0x83);
  21.                 hour = Read_Ds1302_Byte(0x85);
  22.
  23.                 vol = pcf8591_read();
  24.                 vol = (float)vol/255*5;
  25.
  26.                 if(fare_flag)
  27.                 {
  28.                         switch(vol)
  29.                         {
  30.                                 case 0: dang_flag = 1; break;
  31.                                 case 1: dang_flag = 2; break;
  32.                                 case 2: dang_flag = 3; break;
  33.                                 case 3: dang_flag = 4; break;
  34.                                 case 4: dang_flag = 5; break;
  35.                         }
  36.                         speed = dang_flag*10;
  37.
  38.                         if(temp != dang_flag)
  39.                         {
  40.                                 time = 0;
  41.                                 cost1 = cost;
  42.                         }
  43.                         temp = dang_flag;
  44.                         cost = dang_flag*10*time/18+cost1;
  45.                 }
  46.
  47.
  48.                 if(key == 1)
  49.                 {
  50.                         key = 0;
  51.                         fare_flag = ~fare_flag;
  52.                         if(fare_flag)
  53.                                 time = 0;
  54.                 }
  55.                 else if(key == 2)
  56.                 {
  57.                         key = 0;
  58.                         mode++;
  59.                         if(mode >= 4)
  60.                                 mode = 1;
  61.                 }
  62.
  63.                 if(mode == 1)
  64.                 {
  65.                         Dis[0] = Tab[hour/16];
  66.                         Dis[1] = Tab[hour%16]|0x80;
  67.                         Dis[2] = Tab[min/16];
  68.                         Dis[3] = Tab[min%16];
  69.                 }
  70.                 else if(mode == 2)
  71.                 {
  72.                         Dis[0] = Tab[dang_flag];
  73.                         Dis[1] = Tab[10];
  74.                         Dis[2] = Tab[speed/10];
  75.                         Dis[3] = Tab[speed%10];
  76.                 }
  77.                 else if(mode == 3)
  78.                 {
  79.                         Dis[0] = Tab[cost/1000%10];
  80.                         Dis[1] = Tab[cost/100%10];
  81.                         Dis[2] = Tab[cost/10%10]|0x80;
  82.                         Dis[3] = Tab[cost%10];
  83.                 }
  84.         }
  85. }
  86. void Timer0_Init(void)
  87. {
  88.         TMOD |= 0x01;//设置为16位计数器
  89.         TH0 = (65535-20000)/256;//时间定为20ms
  90.         TL0 = (65535-20000)%256;
  91.         EA = 1;
  92.         ET0 = 1;
  93.         TR0 = 1;
  94. }
  95. void Interrupt0(void)interrupt 1
  96. {
  97.         static uint t = 0;
  98.
  99.         TH0 = (65535-20000)/256;
  100.         TL0 = (65535-20000)%256;
  101.         if(fare_flag == 1)//如果开始计费
  102.         {
  103.                 LED = 1;
  104.                 t++;
  105.                 if(t>=50)
  106.                 {
  107.                         time++;
  108.                         t = 0;
  109.                 }
  110.         }
  111.         else if(fare_flag == 0)//如果停止计费
  112.         {
  113.                 LED = 0;
  114.                 t= 0;
  115. //                cost = 0;
  116.                 cost1 = 0;
  117.                 time = 0;
  118.                 dang_flag = 0;
  119.                 speed = 0;
  120.         }
  121.
  122.         key2();
  123.         Display();
  124. }
以上资料51hei附件下载:
基于C51的计程车计费系统.zip (2.52 MB, 下载次数: 126)
admin + 50 回帖助人的奖励!
收藏收藏6 分享淘帖 顶 踩
ID:862074 发表于 2022-6-29 19:49 | 只看该作者
你好,请问代码里的 mode2 是实现什么功能啊,怎么改预设的时间?
ID:576900 发表于 2022-8-10 10:37 | 只看该作者
您好,mode=2是在数码管上显示档位和速度的,要调预设时间的话呢,需要到时钟驱动代码里面调哦
ID:954635 发表于 2022-8-29 16:20 | 只看该作者
出租车计费器的按键程序不太懂,能否请楼主解答
ID:1078572 发表于 2023-5-20 19:34 | 只看该作者
请问,pcb里面有pcb原件封装库吗
