查看: 2517|回复: 0
51单片机矩阵键盘输入lcd显示
ID:640422 发表于 2019-11-12 14:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
#define KEYPORT P3
sbit line0=KEYPORT^0;
sbit line1=KEYPORT^1;
sbit line2=KEYPORT^2;
sbit line3=KEYPORT^3;
sbit RS=P2^2;
sbit RW=P2^1;
sbit E=P2^0;
uchar code dis[]={"0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15"};
bit iskeyinput()
KEYPORT=0x0f;
if((KEYPORT&0x0f)==0x0f)
   return 0;
   return 1;
uchar key_identify()
uchar linecode=0,rowcode=0;
uchar i;
uchar scancode=0xef;
for(i=0;i<4;i++)
   KEYPORT=scancode;
  rowcode++;
  scancode=scancode<<1|1;
    if(line0==0)linecode=0;
if(line1==0)linecode=4;
if(line2==0)linecode=8;
if(line3==0)linecode=12;
break;
  return linecode+rowcode;
void wait_key_release()
  KEYPORT=0x0f;
  break;
void delay(uchar ms)
uchar i;
while(ms--)
   for(i=0;i<250;i++)
     _nop_();_nop_();_nop_();_nop_();_nop_();
bit busy()
bit result;
RS=0;
RW=1;
E=1;
result=(bit)(P1&0x80);
E=0;
return result;
void wcmd(uchar cmd)
while(busy());
RW=0;
E=0;
_nop_();_nop_();
P1=cmd;
E=1;
E=0;
void pos(uchar y,uchar x)
y&=0x1;
x&=0xF;
if(y==1)x|=0xc0;
if(y==0)x|=0x80;
wcmd(x);
void wdat(uchar dat)
while(busy());
RS=1;
RW=0;
E=0;
P1=dat;
E=1;
E=0;
void init()
wcmd(0x3c);
delay(1);
wcmd(0x0e);
delay(1);
wcmd(0x06);
delay(1);
wcmd(0x01);
delay(1);
void main(void)
uchar keycode;
unsigned int i;
uchar j;
init();
  while(!iskeyinput());
  for(i=0;i<500;i++);
  if(iskeyinput())
   keycode=key_identify();
   wait_key_release();
   delay(10);
   pos(0,keycode);
   j=keycode;
   while(dis[j]!=' ')
    wdat(dis[j]);
    j++;
   // while(1);
