查看: 3200|回复: 2
STM32步进电机源码
ID:799384 发表于 2020-7-12 09:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
motor.c
#include "motor.h"  //导入led头文件
#include "stm32f10x.h"  //导入STM32官方库
#include "stm32f10x_rcc.h"  //导入STM32的RCC时钟库
#include "delay.h"       //延时库
void RCC_Configuration(void)
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE , ENABLE);
  GPIO_InitTypeDef GPIO_InitStructure;                                //端口配置结构体
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;                        //PD3管脚
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;         //推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //口线翻转速度为50MHz
  GPIO_Init(GPIOD, &GPIO_InitStructure);                        //初始化端口
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;                        //PD6管脚
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;                //PD12管脚
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;                        //PE4管脚
  GPIO_Init(GPIOE, &GPIO_InitStructure);                        //初始化端口
//电机正转函数
void ZhengZhuan(u16 tt)
            //1000
          GPIO_SetBits(GPIOD, GPIO_Pin_3);
          GPIO_ResetBits(GPIOD, GPIO_Pin_6);
          GPIO_ResetBits(GPIOD, GPIO_Pin_12);
          GPIO_ResetBits(GPIOE, GPIO_Pin_4);
          delay_ms1(tt);
              //1100
          GPIO_SetBits(GPIOD, GPIO_Pin_6);
          delay_ms1(tt);
              //0100
          GPIO_ResetBits(GPIOD, GPIO_Pin_3);
          delay_ms1(tt);
          //0110
          GPIO_SetBits(GPIOD, GPIO_Pin_12);
          delay_ms1(tt);
                  //0010
          delay_ms1(tt);
          //0011
          GPIO_SetBits(GPIOE, GPIO_Pin_4);
          delay_ms1(tt);
          //0001
          delay_ms1(tt);
                  //1001
          delay_ms1(tt);
//电机反转函数
void FanZhuan(u16 tt)
          //1001
          delay_ms1(tt);
                  //0001
          delay_ms1(tt);
          //0011
          delay_ms1(tt);
          //0010
          delay_ms1(tt);
          //0110
          delay_ms1(tt);
                  //0100
          delay_ms1(tt);
          //1100
          delay_ms1(tt);
          //1000
          delay_ms1(tt);
void delay_ms1(u16 nms)
         u32 temp;
         SysTick->LOAD = 9000*nms;
         SysTick->VAL=0X00;//清空计数器
         SysTick->CTRL=0X01;//使能,减到零是无动作,采用外部时钟源
         do
          temp=SysTick->CTRL;//读取当前倒计数值
         }while((temp&0x01)&&(!(temp&(1<<16))));//等待时间到达
         SysTick->CTRL=0x00; //关闭计数器
         SysTick->VAL =0X00; //清空计数器
main.c
#include "misc.h"
//#include "delay.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void ZhengZhuan(u16 tt);
void FanZhuan(u16 tt);
void delay_ms1(u16 nms);
int main(void)
  RCC_Configuration();        //系统时钟设置及外设时钟使能
  GPIO_Configuration();
  //delay_init();  //延时函数初始化
        while (1)
                // ZhengZhuan(3);//逆时针
                 FanZhuan(10);//顺时针
收藏收藏1 分享淘帖 顶 踩
ID:606388 发表于 2020-7-15 08:38 | 只看该作者
楼主,能否上传工程文件,谢谢
ID:364183 发表于 2020-7-15 13:07 | 只看该作者
qingyemurong 发表于 2020-7-15 08:38
楼主,能否上传工程文件,谢谢
我以前传过 你下载看看吧
不知道适不适合你
