查看: 1450|回复: 2
智能车7 8接口对应的轮子不转?附单片机程序
ID:1100860 发表于 2023-12-4 22:00 来自触屏版 | 显示全部楼层 |阅读模式
#include <reg52.h>
sbit IN1=P2^1;
sbit IN2=P2^2;
sbit IN3=P2^6;
sbit IN4=P2^4;
sbit IN5=P1^1;
sbit IN6=P1^2;
sbit IN7=P1^3;
sbit IN8=P1^4;
#define quan_go IN1=1,IN2=0,IN3=1,IN4=0,IN5=0,IN6=1,IN7=1,IN8=0
#define quan_hui IN1=0,IN2=1,IN3=0,IN4=1,IN5=1,IN6=0,IN7=0,IN8=1
#define quan_down IN1=0,IN2=0,IN3=0,IN4=0,IN5=0,IN6=0,IN7=0,IN8=0
#define turn_left IN1=0,IN2=0,IN3=1,IN4=0,IN5=0,IN6=0,IN7=1,IN8=0
#define turn_right IN1=1,IN2=0,IN3=0,IN4=0,IN5=0,IN6=1,IN7=0,IN8=0
uchar a;
void go()
        quan_go;
void hui()
        quan_hui;
void stop()
        quan_down;
void turnleft()
        turn_left;
void turnright()
        turn_right;
void init()
        TMOD=0x20;
    TH1=0xFd;
    TL1=0xFd;
    SCON=0x50;
    PCON=0x00;
    TR1=1;
        ES=1;
    EA=1;
        init();
                if(a=='A') go();
                else if(a=='B')  hui();
                else if(a=='C')turnleft();
                else if(a=='D') turnright();
                else stop();
void serial() interrupt 4
        a=SBUF;
        RI=0;
ID:1008290 发表于 2023-12-5 00:00 | 显示全部楼层
尝试互换一下驱动板
ID:685462 发表于 2023-12-5 11:47 | 显示全部楼层
用万用表测量管脚电平,有输出的再测量驱动板,无输出找程序问题
