查看: 8394|回复: 3
单片机LCD1602显示年月日时钟带星期和闹钟
ID:36963 发表于 2018-4-6 15:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
长春工业大学
测控技术与仪器专业
单片机LCD1602显示年月日时钟带星期和闹钟,可识别闰年
下载文档即可完全复制
#include <reg52.h>
sbit lcdrs  =P0^7;     //液晶引脚定义
sbit led_cs = P0^6;
sbit lcden  =P0^5;
sbit boom   =P3^6;
sbit key1 = P3^5;
sbit key2 = P3^4;
sbit key3 = P3^3;
sbit keyE = P3^2;
ucharnum,key1num,key2num,count,hour,min,sec,day,mon,year,shi,fen,miao,week;
char  ye1,ye2;
uchar code cg_1602[]={0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00,
0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,};//"年月日"
/*延时函数*/
void delay(uint xms)
       uint i,j;
       for(i=xms;i>0;i--)
       for(j=114;j>0;j--);
/*1602液晶*/
void write_com(uchar com)//写命令
       lcdrs=0;
       lcden=0;
       P0=com;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
void write_data(uchar date)//写数据
       lcdrs=1;
       lcden=0;
       P0=date;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
void write_by_xy(uchar x,uchar y)//坐标定位
       ucharaddress;
       if(y==0)
       address=0x80+x;//y=0,写第一行
       address=0xc0+x;//y=1,写第二行
       write_com(address);
/*void write_char(uchar x,uchar y,uchar date)//坐标定位显示
       write_by_xy(x,y);//先定位
       write_data(date);//后写数
void write_string(uchar x,uchar y,uchar *s)//写字符串
       write_by_xy(x,y);//设定显示位置
       while(*s)//writecharacter
       P0=*s;
       write_data(*s);
       s++;
void write_sfm(uchar add,uchar date)//写时分秒函数
       ucharhour,ge;
       hour=date/10;//分解一个2位数的十位和个位
       ge=date%10;
       write_com(0x80+add);//设置显示位置
       write_data(0x30+hour);//送去液晶显示十位
       write_data(0x30+ge);//送去液晶显示个位
void write_cg()//写入固定汉字和符号
       write_com(0x40);//设定CGRAM地址
       for(num=0;num<24;num++)//将自定义字型码写入CGRAM中
              write_data(cg_1602[num]);
       write_com(0xc4);//年
              write_data(0);
       write_com(0xc7);//月
              write_data(1);
       write_com(0xca);//日
              write_data(2);
       write_string(2,0,":");
       write_string(5,0,":");
       write_string(0x0a,0,":");
       write_string(0x0d,0,":");
       write_string(0x0c,1,"W");
       write_string(0x0d,1,"K");
void init_1602()//初始化
       led_cs=0;
hour=23;min=59;sec=55;key1num=0;count=0;day=28;mon=2;ye1=20;ye2=13;year=ye1*100+ye2;boom=0;shi=0;fen=0;miao=0;week=7;
       write_com(0x38);
       write_com(0x0c);
       write_com(0x06);
       write_com(0x01);
       write_string(0,1,"2013");
       write_string(5,1,"02");
       write_string(8,1,"28");
       write_sfm(8,shi);
       write_sfm(0x0b,fen);
       write_sfm(0x0e,miao);
       write_sfm(0,hour);
       write_sfm(3,min);
       write_sfm(6,sec);
       write_sfm(0x48,day);
       write_sfm(0x45,mon);
       write_sfm(0x40,ye1);
       write_sfm(0x42,ye2);
       write_sfm(0x4e,week);
       write_cg();
       TMOD=0x01;//设置定时器0工作模式1
       TH0=(65536-50000)/256;//定时器装初值
       TL0=(65536-50000)%256;
       EA=1; //开总中断
       ET0=1; //开定时器0中断
       TR0=1; //启动定时器0
/*键盘扫描函数*/
void keyscan()//按键扫描函数
       //keyE =0;
       if(key1==0)
              delay(5);
              if(key1==0)//确认功能键被按下
                     key1num++;//功能键按下次数记录
                     while(!key1);//释放确认
                     if(key1num==1)//第一次被按下时
                            TR0=0;//关闭定时器
                            write_com(0x80+7);//光标定位到秒位置
                            write_com(0x0f);//光标开始闪烁
                     if(key1num==2)//第二次按下光标闪烁定位到分钟位置
                            write_com(0x80+4);
                     if(key1num==3)//第三次按下光标闪烁定位到小时位置
                            write_com(0x80+1);
                     if(key1num==4)//第四次按下光标闪烁定位到日位置
                            write_com(0x80+0x49);
                     if(key1num==5)//第五次按下光标闪烁定位到月位置
                            write_com(0x80+0x46);
                     if(key1num==6)//第六次按下光标闪烁定位到年2位置
                            write_com(0x80+0x43);
                     if(key1num==7)//第七次按下光标闪烁定位到年1位置
                            write_com(0x80+0x41);
                     if(key1num==8)//第八次按下光标闪烁定位到星期位置
                            write_com(0x80+0x4f);
                     if(key1num==9)//第九次按下
                            key1num=0;//记录按键数清零
                            write_com(0x0c);//取消光标闪烁
                            TR0=1;//启动定时器使时钟开始走
       if(key1num!=0)//只有功能键被按下后,增加和减小键才有效
              if(key2==0)
                     delay(5);
                     if(key2==0)//增加键确认被按下
                            while(!key2);//按键释放
                            if(key1num==1)//若功能键第一次按下
                                   sec++;//则调整秒加1
                                   if(sec==60)//若满60后将清零
                                   sec=0;
                                   write_sfm(6,sec);//每调节一次送液晶显示一下
                                   write_com(0x80+7);//显示位置重新回到调节处
                            if(key1num==2)//若功能键第二次按下
                                   min++;//则调整分钟加1
                                   if(min==60)//若满60后将清零
                                   min=0;
                                   write_sfm(3,min);//每调节一次送液晶显示一下
                                   write_com(0x80+4);//显示位置重新回到调节处
                            if(key1num==3)//若功能键第三次按下
                                   hour++;//则调整小时加1
                                   if(hour==24)//若满24后将清零
                                   hour=0;
                                   write_sfm(0,hour);;//每调节一次送液晶显示一下
                                   write_com(0x80+1);//显示位置重新回到调节处
                            if(key1num==4)//若功能键第四次按下
                                   day++;//则调整日加1
                                   if(day>31)//若大于31后将置一
                                   day=1;
                                   write_sfm(0x48,day);//每调节一次送液晶显示一下
                                   write_com(0x80+0x48);//显示位置重新回到调节处
                            if(key1num==5)//若功能键第五次按下
                                   mon++;//则调整月加1
                                   if(mon>12)//若大于12后将置一
                                   mon=1;
                                   write_sfm(0x45,mon);//每调节一次送液晶显示一下
                                   write_com(0x80+0x45);//显示位置重新回到调节处
                            if(key1num==6)//若功能键第六次按下
                                   ye2++;//则调整年加1
                                   if(ye2==0x0a)//若满99后将清零
                                   ye2=0;
                                   year=ye1*100+ye2;
                                   write_sfm(0x42,ye2);//每调节一次送液晶显示一下
                                   write_com(0x80+0x42);//显示位置重新回到调节处
                            if(key1num==7)//若功能键第七次按下
                                   ye1++;//则调整年加100
                                   if(ye1==0x0a)//若满99后将清零
                                   ye1=0;
                                   year=ye1*100+ye2;
                                   write_sfm(0x40,ye1);//每调节一次送液晶显示一下
                                   write_com(0x80+0x40);//显示位置重新回到调节处
                            if(key1num==8)//若功能键第八次按下
                                   week++;//则调整周加一
                                   if(week>7)//若大于7后置一
                                   week=1;
                                   write_sfm(0x4f,week);//每调节一次送液晶显示一下
                                   write_com(0x80+0x4f);//显示位置重新回到调节处
              if(key3==0)
                     delay(5);
                     if(key3==0)//确认减小键被按下
                            while(!key3);//按键释放
                                   sec--;//则调整秒减1
                                   if(sec==-1)//若减到负数则将其重新设置为59
                                          sec=59;
                                   min--;//则调整分钟减1
                                   if(min==-1)//若减到负数则将其重新设置为59
                                          min=59;
                                   hour--;//则调整小时减1
                                   if(hour==-1)//若减到负数则将其重新设置为23
                                          hour=23;
                                   write_sfm(0,hour);//每调节一次送液晶显示一下
                                   day--;//则调整日减1
                                   if(day==0)//若日为零时将置一
                                   day=31;
                                   write_com(0x80+0x49);//显示位置重新回到调节处
                                   mon--;//则调整月减1
                                   if(mon==0)//若月为零将置一
                                   mon=12;
                                   ye2--;//则调整年减1
                                   if(ye2<0)//若小于零后将设置为99
                                   ye2=99;
                                   year=ye1*100+ye2;
                                   ye1--;//则调整年减100
                                   if(ye1<0)//若小于零后将设置为99
                                   ye1=99;
                                   year=ye1*100+ye2;
                                   week--;//则调整周减一
                                   if(week==0)//若等于0后将置7
                                   week=7;
       if(keyE==0)
              delay(5);
              if(keyE==0)//确认功能键被按下
                     key2num++;//功能键按下次数记录
                     while(!keyE);//释放确认
                     if(key2num==1)//第一次被按下时
                            TR0=0;//关闭定时器
                            write_com(0x80+0x0f);//光标定位到秒位置
                     if(key2num==2)//第二次按下光标闪烁定位到分钟位置
                            write_com(0x80+0x0c);
                     if(key2num==3)//第三次按下光标闪烁定位到小时位置
                            write_com(0x80+9);
                     if(key2num==4)//第八次按下
                            key2num=0;//记录按键数清零
                            TR0=1;//启动定时器使时钟开始走
              if(key2num!=0)//只有功能键被按下后,增加和减小键才有效
              if(key2==0)
                     delay(5);
                            while(!key2);//按键释放
                            if(key2num==1)//若功能键第一次按下
                                   miao++;//则调整秒加1
                                   if(miao==60)//若满60后将清零
                                   miao=0;
                                   write_sfm(0x0e,miao);//每调节一次送液晶显示一下
                                   write_com(0x80+0x0e);//显示位置重新回到调节处
                            if(key2num==2)//若功能键第二次按下
                                   fen++;//则调整分钟加1
                                   if(fen==60)//若满60后将清零
                                   fen=0;
                                   write_sfm(0x0b,fen);//每调节一次送液晶显示一下
                                   write_com(0x80+0x0b);//显示位置重新回到调节处
                            if(key2num==3)//若功能键第三次按下
                                   shi++;//则调整小时加1
                                   if(shi==24)//若满24后将清零
                                   shi=0;
                                   write_sfm(8,shi);;//每调节一次送液晶显示一下
                                   write_com(0x80+8);//显示位置重新回到调节处
              if(key3==0)
                     delay(5);
                            while(!key3);//按键释放
                                   miao--;//则调整秒减1
                                   if(miao==-1)//若减到负数则将其重新设置为59
                                          miao=59;
                                   fen--;//则调整分钟减1
                                   if(fen==-1)//若减到负数则将其重新设置为59
                                          fen=59;
                                   shi--;//则调整小时减1
                                   if(shi==-1)//若减到负数则将其重新设置为23
                                          shi=23;
                                   write_sfm(8,shi);//每调节一次送液晶显示一下
/*主函数*/
       led_cs=0;
       init_1602();
              keyscan();
/*中断函数*/
void timer0() interrupt 1//定时器0中断服务程序
       TH0=(65536-50000)/256;//再次装定时器初值
       count++;//中断次数累加
       if(count==20)//20次50毫秒为1秒
              count=0;
              sec++;
              if(sec==60)//秒加到60则进位分钟
                     sec=0;//同时秒数清零
                     min++;
                     if(min==60)//分钟加到60则进位小时
                            min=0;//同时分钟数清零
                            hour++;
                            //boom=1;
                            //delay(5);
                            //boom=0;
                            if(hour==24)//小时加到24则小时清零
                                   hour=0;
                                   day++;
                                   week++;
                                   if(week>7)
                                   week=1;
                                   if(mon==1)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==2)
                                    if((year%4==0 &&year%100!=0)||year%4==0)
                                    if(day>29)
                                    day=1;
                                    mon++;
                                    else if(day>28)
                                    day=1;
                                    mon++;
                                    if(mon==3)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==4)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==5)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==6)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==7)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==8)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    }if(mon==9)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==10)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==11)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==12)
                                    if(day>31)
                                    day=1;
                                    mon=1;
                                    ye2++;
                            write_sfm(0,hour);//小时若变化则重新写入
                     write_sfm(3,min);//分钟若变化则重新写入
              write_sfm(6,sec);//秒若变化则重新写入
                     if((hour==shi&& min==fen) && sec==miao)
              boom=1;
              delay(5);
              boom=0;
收藏收藏5 分享淘帖 顶顶 踩踩
ID:46065 发表于 2018-4-6 21:32 | 只看该作者
楼主,求电路图,先谢谢啦
ID:615302 发表于 2019-10-22 17:40 | 只看该作者
谢谢分享
ID:678764 发表于 2020-1-1 15:35 | 只看该作者
楼主,在哪可以下载完整程序呀,课程设计想要才能考一下。
