查看: 2094|回复: 0
去年做的基于Qt的人脸识别系统,这是在Qt客户端上运行的完整代码
ID:718394 发表于 2020-3-29 21:15 | 显示全部楼层 |阅读模式
  1. #include "facedetectwnd.h"
  2. #include "ui_facedetectwnd.h"
  3. #include <QByteArray>
  4. #include <QHostAddress>
  5. #include "FaceDetect.h"
  6. FaceDetectThr::FaceDetectThr(QObject *parent):
  7.     QThread (parent)
  8. {
  9. }
  10. FaceDetectThr::~FaceDetectThr()
  11. {
  12. }
  13. void FaceDetectThr::run()
  14. {
  15. #define MAXLEN int(800*600)
  16.    int size;
  17.    //分配缓存:用于保存接收图片数据
  18.    char *buffer  = new char[MAXLEN];
  19.         //分配套接字
  20.    QTcpSocket *s = new QTcpSocket;
  21.    // 连接服务器
  22.    s->connectToHost(QHostAddress("192.168.21.131"), 59999);
  23.    //等连接成功
  24.    if(!s->waitForConnected(~0)){
  25.        goto ERR_STEP;
  26.    }
  27.    //给界面发生连接成功信号
  28.    emit sigConnected();
  29.         //死循环
  30.    while(1){
  31.        char req[]= "clientack";
  32.                 //给服务器发送请求
  33.        s->write(req, sizeof(req));
  34.                 //等待套接字缓存可读(给服务器发送请求后,服务器收到则采样一张图片,回发客户端)
  35.        if(s->waitForReadyRead(~0)){
  36.                    //读出4字节协议头:图片正文的长度
  37.            s->read((char *)&size, 4);
  38.            int len = size;
  39.            char *p1 = (char *)&len;
  40.            char *p2 = (char *)&size;
  41.            p1[0] = p2[3];
  42.            p1[1] = p2[2];
  43.            p1[2] = p2[1];
  44.            p1[3] = p2[0];
  45.            if(MAXLEN < len){
  46.                goto ERR_STEP;
  47.            }
  48.                         //循环接收len字节数据(不多收也不少收)
  49.            p1 = buffer;
  50.            int pos = len;
  51.            while(pos){
  52.                if(!s->waitForReadyRead(~0)){
  53.                    goto ERR_STEP;
  54.                }
  55.                size = int(s->read(p1, pos));
  56.                pos -= size;
  57.                p1 += size;
  58.            }
  59.            qDebug("len = %d, pos=%d\n", len, pos);
  60.                         //把接收来的图片数据装到字节数组
  61.            QByteArray arr;
  62.            arr.append(buffer, len);
  63.                    //定义管理图片的QImage对象
  64.            QImage img;
  65.                    //把字节数组中图片用img对象管理起来
  66.            img.loadFromData(arr);
  67.            //把QImage转换成Mat格式
  68.            cv::Mat frame = ::QImage_to_Mat(img);
  69.            //人脸检测
  70.            ::detectFaceOpenCV(frame);
  71.            //把Mat转换成QImage
  72.            img = ::Mat_to_QImage(frame);
  73.            //把QImage转换QPixmap
  74.            QPixmap pix = QPixmap::fromImage(img);
  75.                         //给界面发送信号
  76.            emit sigPixmap(pix);
  77.        }
  78.    }
  79. ERR_STEP:
  80.    qDebug("线程出错退出");
  81.    delete [] buffer;
  82.    delete s;
  83.    emit sigDisconnected();
  84.    return;
  85. }
  86. FaceDetectWnd::FaceDetectWnd(QWidget *parent) :
  87.     QWidget(parent),
  88.     ui(new Ui::FaceDetectWnd)
  89. {
  90.     ui->setupUi(this);
  91.     //分配一个接收线程对象
  92.     detectThr = new FaceDetectThr;
  93.     connect(detectThr, SIGNAL(sigPixmap(QPixmap)),
  94.             this, SLOT(slotRecv(QPixmap)));
  95.     connect(detectThr, SIGNAL(sigConnected()),
  96.             this, SLOT(slotConnected()));
  97.     connect(detectThr, SIGNAL(sigDisconnected()),
  98.             this, SLOT(slotDisconnected()));
  99.     setWindowTitle("智能门岗");
  100. }
  101. FaceDetectWnd::~FaceDetectWnd()
  102. {
  103.     delete ui;
  104. }
  105. void FaceDetectWnd::slotConnected()
  106. {
  107.     setWindowTitle("连接成功");
  108.     ui->pushButton->setEnabled(true);
  109. }
  110. void FaceDetectWnd::slotDisconnected()
  111. {
  112.     setWindowTitle("连接断开");
  113.     ui->pushButton->setText("连接");
  114.     ui->pushButton->setEnabled(true);
  115. }
  116. void FaceDetectWnd::slotRecv(QPixmap pix)
  117. {
  118.     ui->label->setPixmap(pix);
  119. }
  120. void FaceDetectWnd::on_pushButton_clicked()
  121. {
  122.     if("连接" == ui->pushButton->text()){
  123.         ui->pushButton->setText("断开");
  124.         detectThr->start();
  125.         setWindowTitle("连接中...");
  126.         ui->pushButton->setEnabled(false);
  127.     }else{
  128.         ui->pushButton->setText("连接");
  129.         detectThr->terminate();
  130.     }
  131. }
