查看: 1670|回复: 1
运行错误 单片机步进电机模块 正转,反转调速Proteus仿真+程序
步进电机模块,正转,反转调速
                         LCD1602.C文件 LCD1602的函数
#include "hardware.h"
#include "lcd1602.h"
void LCD_check_busy(void)   //检测LCD状态,看它是不是还在忙呢
   LCD_EN=0;
   LCD_RS=0;
   LCD_RW=1;
   LCD_DATA=0xff;
   LCD_EN=1;
   if(!LCD_BUSY)break;
LCD_EN=0;
void LCD_cls(void)          //LCD清屏
LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=1;
LCD_EN=1;
LCD_EN=0;
void LCD_write_instruction(unsigned char LCD_instruction)   //写指令到LCD
  LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=LCD_instruction;
LCD_EN=1;
LCD_EN=0;
void LCD_write_data(unsigned char LCD_data)      //输出一个字节数据到LCD
  LCD_check_busy();
LCD_RS=1;
LCD_RW=0;
LCD_DATA=LCD_data;
LCD_EN=1;
LCD_EN=0;
void LCD_set_position(unsigned char x)            //LCD光标定位到x处
LCD_write_instruction(0x80+x);
void LCD_go_home(void)                         //LCD光标归位
LCD_write_instruction(LCD_GO_HOME);
void LCD_printc(unsigned char lcd_data)          //输出一个字符到LCD
LCD_write_data(lcd_data);
void LCD_prints(unsigned char *lcd_string)       //输出一个字符串到LCD
unsigned char i=0;
while(lcd_string[ i]!=0x00)
   LCD_write_data(lcd_string[ i]);
   i++;
void LCD_initial(void)                        //初始化LCD
LCD_write_instruction(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
LCD_write_instruction(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
LCD_write_instruction(LCD_DISPLAY_DOUBLE_LINE);
LCD_cls();
运行错误 求指导: 步进电机模块.zip (59.61 KB, 下载次数: 11)
参与人数 1黑币 +10 收起 理由
admin + 10 共享资料的黑币奖励!
收藏收藏2 分享淘帖 顶 踩
ID:102963 发表于 2022-3-30 10:08 | 只看该作者
仿真图没有Lcd1602,程序里面怎么有Lcd1602的程序呢?
