查看: 2850|回复: 1
这个单片机warning怎么解决啊?找了半天也没有,求各位大神帮忙
ID:680170 发表于 2020-4-12 19:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  _INTTOSTR
    MODULE:  main.obj (MAIN)
    SYMBOL:  _READ_DATA
    SYMBOL:  ?_READ_DATA?BYTE
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
    ADDRESS: 0D84H
    SYMBOL:  _READ_DATA
    ADDRESS: 0DAFH
    SYMBOL:  _INTTOSTR
    ADDRESS: 0DC4H
    SYMBOL:  _INTTOSTR
    ADDRESS: 0DF0H
    SYMBOL:  _INTTOSTR
    ADDRESS: 0E1CH
    SYMBOL:  _INTTOSTR
    ADDRESS: 0E48H
#include<reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
#include<stdio.h>
#include "18b20.h"
#include "1602.h"
#include "delay.h"
#include "i2c.h"
unsigned char dis0[17];      //打印数组初始化
unsigned long time_20ms=0;     //定时器计数
unsigned char sendata[22]={0};     //串口发送数组
unsigned char tempdata[4]={0};     //临时变量数组
unsigned char Read_Data(int *SuDu,int *Send_temperature,int *Send_Volt,int *Send_Acurrent);
unsigned char ReadTempFlag=0;//定义读时间标志
int temp1;      //读取温度初始值
float temperature;    //实际温度值
float Volt=0.0;     //检测电压
float Acurrent=0.0;      //检测电流
unsigned int PluNum;   //脉冲计数
unsigned char ReadSuDu=0;  //读取速度标志
int SuDu;       //速度值
int Send_temperature ;    //发送上位机的温度*10
int Send_Volt;        // 发送上位机的电压*10
int Send_Acurrent;       // 发送上位机的电流*100
void Init_Timer0(void);  //函数声明
void uartSendStr(unsigned char *s,unsigned char length);
void UART_Init(void);
void uartSendByte(unsigned char dat);
void IntToStr(int value, unsigned char *buf);    //int型转字符串
void main (void)
Init_Timer0();        //定时器0初始化
UART_Init();
EX0=1;         //外部中断0开
IT0=1;         //边沿触发
    EA=1;          //全局中断开
LCD_Init();           //初始化液晶
DelayMs(20);          //延时有助于稳定
LCD_Clear();
DelayMs(200);
uartSendStr("reday ok!!",10);
while (1)         //主循环
  Volt=(float)ReadADC(1)*5.0/255*5;  //计算出电压 *5表示分压值 八位ad转换
  DelayMs(2);          //延时有助于稳定
  Acurrent=(float)ReadADC(0)*5.0/255;  //计算出电流
  if(Acurrent>2.6)    //如果电流转换后的电压值超过2.62
  {Acurrent=(Acurrent-2.6)*2/0.185;}  //电流模块 电压转换计算
  {Acurrent=0;}
  Send_temperature=temperature *10;
  Send_Volt=Volt *10;
  Send_Acurrent=Acurrent *100;
   sprintf(dis0,"S:%3dr/m T:%4.1fC",SuDu,temperature);//打印电压电流值
   LCD_Write_String(0,0,dis0);//显示第二行
   sprintf(dis0,"V:%3.1fv A:%3.2fA ",Volt*76,Acurrent*2);//打印电压电流值
   LCD_Write_String(0,1,dis0);//显示第二行
            Read_Data(&SuDu,&Send_temperature,&Send_Volt,&Send_Acurrent);
   sendata[0] = 0xFE;
   IntToStr(SuDu, tempdata);//   速度数据封包函数
   sendata[1]= tempdata[0];
   sendata[2]= tempdata[1];
   sendata[3]= tempdata[2];
   sendata[4]= tempdata[3];
   sendata[5] = 0x0A;
   IntToStr(Send_temperature, tempdata);//   温度数据封包函数
   sendata[6]= tempdata[0];
   sendata[7]= tempdata[1];
   sendata[8]= tempdata[2];
   sendata[9]= tempdata[3];
   sendata[10] = 0x0A;
     IntToStr(Send_Volt, tempdata);//   电压数据封包函数
   sendata[11] = tempdata[0];
   sendata[12] = tempdata[1];
   sendata[13] = tempdata[2];
   sendata[14] = tempdata[3];
   sendata[15] = 0x0A;
   IntToStr(Send_Acurrent, tempdata);//   电流数据封包函数
   sendata[16] = tempdata[0];
   sendata[17] = tempdata[1];
   sendata[18] = tempdata[2];
   sendata[20]=  tempdata[3];
   sendata[21] = 0x0D;
   if(sendata[1]==0x30)    //对速度高位是否为零进行判断
     sendata[1]=' ';
   if(sendata[6]==0x30)    //对温度高位是否为零进行判断
     sendata[6]=' ';
   if(sendata[11]==0x30)       //对电压高位是否为零进行判断
     sendata[11]=' ';
   if(sendata[16]==0x30)    //对电流高位是否为零进行判断
     sendata[16]=' ';
   uartSendStr(sendata,22);
  if(ReadTempFlag==1)  //读取温度标志
   ReadTempFlag=0;
   temp1=ReadTemperature(); //读取温度
   temperature=(float)temp1*0.0625;   //温度值转换
  if(ReadSuDu==1)     //处理速度
   ReadSuDu=0;
   SuDu=(float)PluNum*15;  //1个脉冲1圈   5s一次
   PluNum=0;       //周期脉冲清空
  DelayMs(40);          //延时有助于稳定
                 外部中断程序
void ISR_Key(void) interrupt 0 using 1
PluNum++;   //外部中断清空计数
TMOD |= 0x01;   //使用方式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
TH0=(65536-20000)/256;    //重新赋值 20ms
TL0=(65536-20000)%256;
EA=1;            //总中断打开
ET0=1;           //定时器中断打开
TR0=1;           //定时器开关打开
void Timer0_isr(void) interrupt 1
time_20ms++;
   if(time_20ms%200==0)    //定时处理速度
  ReadSuDu=1; //读标志位置1
if(time_20ms%10==0)   //读取温度
  ReadTempFlag=1; //读标志位置1
    SCON  = 0x50;          // SCON: 模式 1, 8-bit UART, 使能接收
    TMOD |= 0x20;               // TMOD: timer 1, mode 2, 8-bit 重装
    TH1   = 0xFD;               // TH1:  重装值 9600 波特率 晶振 11.0592MHz
TL1 = TH1;
    TR1   = 1;                  // TR1:  timer 1 打开
    EA    = 1;                  //打开总中断
    ES    = 1;                  //打开串口中断
unsigned char time_out;
time_out=0x00;
SBUF = dat;     //将数据放入SBUF中
while((!TI)&&(time_out<100))  //检测是否发送出去
{time_out++;DelayUs2x(10);} //未发送出去 进行短暂延时
TI = 0;      //清除ti标志
unsigned char NUM;
NUM=0x00;
while(NUM<length) //发送长度对比
  uartSendByte(*s);  //放松单字节数据
  s++;    //指针++
  NUM++;    //下一个++
void UART_SER (void) interrupt 4  //串行中断服务程序
if(RI)                        //判断是接收中断产生
  RI=0;                      //标志位清零
if(TI)  //如果是发送标志位,清零
TI=0;
ID:584814 发表于 2020-4-13 10:55 | 只看该作者
提示中的几个函数不能正确读出,未贴全部程序只能自己找。
