查看: 3530|回复: 1
16x32点阵显示2个汉字的proteus仿真电路及单片机C语言程序
#include <REGX52.H>
sbit SCLK=P1^0;
sbit DAT=P1^2;
sbit SLCK=P1^1;
sbit P20=P2^0;
sbit P21=P2^1;
sbit P22=P2^2;
sbit P23=P2^3;
uchar code table[64]={//{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x04,0xFF,0xFE,0x01,0x00,0x02,0x80,
0x02,0x80,0x02,0x40,0x04,0x40,0x04,0x20,0x08,0x10,0x10,0x0E,0x60,0x04,0x00,0x00};// 大
//0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
uchar code table1[64]={
0x22,0x08,0x11,0x08,0x11,0x10,0x00,0x20,0x7F,0xFE,0x40,0x02,0x80,0x04,0x1F,0xE0,
0x00,0x40,0x01,0x84,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00,//学
// 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
void delay(void);
uint offset;
void display_595(uchar L1,uchar L2,uchar L3,uchar L4)//
{  uchar i;
   uchar j;
  uchar a[3];
         a[0]=L1;
                 a[1]=L2;
          a[2]=L3;
                  a[3]=L4;
      SLCK=0;
    for(j=0;j<4;j++)
        for(i=0;i<8;i++)//把数组中的每一个数送到移位寄存器(8位的数)
         SCLK=0;//寄存器的时钟输入,上升沿有效
          DAT=a[j]&0x80;
         a[j]=a[j]<<1; //将a值左移一位
         SCLK=1;
SLCK=1;
void main(void)
TMOD=0x01;
TH0=0xb1;
TL0=0xe0;
ET0=1;
EA=1;
TR0=1;
{  uchar i;
for(i=0;i<16;i++)
   display_595(table[offset+2*i],table[offset+2*i+1],table1[offset+2*i],table1[offset+2*i+1]);//
delay();
P2=i;
  delay();
void delay(void)
uint i;
for(i=0;i<10;i++);
void timer0() interrupt 1 using 3
         uchar n;
        TF0=0;
        TH0=0xb1;
        TL0=0xe0;
        if(n<20)
           n++;
//  offset+=2;
//if(offset>32)
// offset=0;
            n=0;
全部资料51hei下载地址:
16x32点阵显示2个汉字计.zip (48.19 KB, 下载次数: 31)
收藏收藏4 分享淘帖 顶顶 踩踩
ID:102963 发表于 2020-6-15 08:22 | 只看该作者
这仿真都没法用,怎么还分享出来?
