查看: 2099|回复: 1
单片机数码管一闪一闪的,按钮除了复位和K5能按,其它都按不了,而且也没啥反应
数码管一闪一闪的,按钮除了复位和K5能按,其它都按不了,而且也没啥反应····
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. sbit SPK=P1^5;
  5. sbit K1=P2^0;
  6. sbit K2=P2^1;
  7. sbit K3=P2^2;
  8. sbit K4=P2^3;
  9. sbit K5=P2^4;
  10. sbit A1=P1^0;
  11. sbit A2=P1^1;
  12. sbit A3=P1^2;
  13. sbit A4=P1^3;
  14. uchar miao_g,miao_d,fen_g,fen_d;
  15. uchar code Num[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xf8,0x80,0x90};
  16. uchar num1;
  17. uchar code song[]={0x58,0x84,0xA8,0x84,0x68,0x82,0x62,0x5C,0xA4,0xA4,0xA4,0xA4,0x93,0x81,0x9C,0x9C,0xC8,0xC4,0xC8,0xD2,0xC2,0xA8,0x92,0x82,0x6B,0xC4,0xC4,0xC4,0xA8,0x94,0x8C,0xFF};
  18. //音律部分,前四位为音阶,后四位为节拍,其中以1/4节拍为单位节拍;
  19. uchar m;
  20. uchar code yinjie[]={0xff,0xff,0xFC,0x4A,0xFC,0xAE,0xFD,0x08,0xFD,0x30,0xFD,0x80,0xFD,0xC6,0xFE,0x02,0xFE,0x2A,0xFE,0x5C,0xFE,0x84,0xFE,0x98,0xFE,0xC0,0xFE,0xE8,0xFF,0x06};
  21. //音阶所对应的计时器初值,前两位是占位,中间14位是中音1~7,后面14位是高音1~7,晶振为12MHz;
  22. uchar ding;
  23. void delay_1();//1/4节拍函数声明;
  24. void delay(uint k);//计数器延时函数声明;
  25. void display(uint fen_g,uint fen_d,uint miao_g,uint miao_d);//数码管显示函数声明;
  26. void music();//音乐函数声明;
  27. void delayxiaodou(int n);//消抖函数声明,用于主函数K5;
  28. //数码管部分
  29. void delay(uint k)          //延时函数,用于计时器计算1s部分和数码管延时显示部分
  30. {  uint x,y;
  31.     for(x=k;x>0;x--)
  32.            for(y=125;y>0;y--);
  33.            }
  34. void delayxiaodou(int n)
  35. {
  36.      while(n--);
  37. }
  38. void display(uint fen_g,uint fen_d,uint miao_g,uint miao_d)   //数码管显示时间
  39. {
  40.
  41.             P0=0xFF;                 //消隐;
  42.      A1=1;A2=0;A3=0;A4=0;
  43.          P0=Num[fen_g];
  44.          delay(1);
  45.          P0=0xFF;
  46.          A1=0;A2=1;A3=0;A4=0;
  47.          P0=Num[fen_d];
  48.          delay(1);
  49.          A1=0;A2=0;A3=1;A4=0;
  50.          P0=0xFF;
  51.          P0=Num[miao_g];
  52.          delay(1);
  53.          A1=0;A2=0;A3=0;A4=1;
  54.          P0=0xFF;
  55.          P0=Num[miao_d];
  56.          delay(1);
  57.          TR0=0;
  58.
  59. }
  60. //倒计时部分
  61. void timer()interrupt 1        //定时器0,方式1
  62. {
  63.    TH0=0x3C;  //50ms倒计时
  64.    TL0=0xB0;
  65.    num1++;
  66.    if(num1==20) //50ms*20=1s
  67.    {   num1=0;
  68.        miao_d--;
  69.            if(miao_d==-1)
  70.            {   miao_d=9;
  71.                miao_g--;
  72.                    if(miao_g==-1)
  73.                    {  miao_g=5;
  74.                       fen_d--;
  75.                           if(fen_d==-1)
  76.                           {  fen_d=9;
  77.                              fen_g--;
  78.                                  if(fen_g==-1)
  79.                                  {
  80.                                     fen_g=5;}}}}}}
  81. //音乐部分
  82. void music()
  83. {  uint data j=0;
  84.     uchar data g;
  85.         uchar data i;
  86.         while (*(song+j)!=0xff)//歌曲的停顿;
  87.         {   g=*(song+j)&0x0F;//低4位,节拍;
  88.             m=*(song+j)>>4;         //高4位,音阶;
  89.                 TH1=yinjie[2*m];
  90.                 TL1=yinjie[2*m+1];
  91.                 TR1=1;
  92.                 if((yinjie[2*m]==0xff)&&(yinjie[2*m+1]==0xff))
  93.                 {  TR1=0;
  94.                    SPK=1;}
  95.                 for(i=g;i>0;i--)
  96.                 {  delay_1();
  97.                    TR1=0;
  98.                    j++;
  99.                    }}}
  100. void delay_1()//1/4        节拍所需要用的时间,约187ms;
  101. {  uchar m,n,p;
  102.    for(m=100;m>0;m--)
  103.      for(n=20;n>0;n--)
  104.            for(p=15;p>0;p--);
  105. }
  106. void timer0() interrupt 3        //半个周期后,SPK处的脉冲反相,得到音阶;
  107. { TH1=yinjie[2*m];
  108.   TL1=yinjie[2*m+1];
  109.   SPK=!SPK;
  110.   }
  111. //核心处理模块
  112. void main()
  113. {
  114.    TMOD=0x01; //启动定时器,初值为50ms;
  115.    TH0=0x3C;
  116.    TL0=0xB0;
  117.    ET0=1;     //定义中断;
  118.    ET1=1;
  119.    EA=1;
  120.    TR0=0;          //时钟初始化;
  121.    miao_g=miao_d=fen_g=0;
  122.    fen_d=1;
  123.    ding=0;
  124.    while(1)
  125.    {
  126.       display(fen_g,fen_d,miao_g,miao_d);
  127.           if(K5!=0)
  128.           {
  129.           if(K1==0)                   //K1按键:在1分钟基础上递增,可自定义计时时间;
  130.            {  delayxiaodou(100);
  131.               if(K1==0)
  132.                   { miao_g=miao_d=0;
  133.                     fen_d++;
  134.                         if(fen_d==10)
  135.                         {  fen_d=0;
  136.                            fen_g++;
  137.                            if(fen_g==6)
  138.                            {fen_d=0;
  139.                            }}}}
  140.                            while(!K1);
  141.           if(K2==0)                        //K2按键:初值为5分钟;
  142.            {  delayxiaodou(100);
  143.                if(K2==0)
  144.                    {
  145.                       miao_g=miao_d=0;
  146.                       fen_d=5;
  147.                           fen_g=0;
  148.
  149.                           }
  150.                           }
  151.                           while(!K2);
  152.           if(K3==0)                        //K3按键:初值为15分钟;
  153.             {  delayxiaodou(100);
  154.                    if(K3==0)
  155.                    { miao_g=miao_d=0;
  156.                      fen_d=5;
  157.                          fen_g=1;
  158.
  159.                          }
  160.                          }
  161.                          while(!K3);
  162.                 if(K4==0)                 //K4按键:初值为20分钟;
  163.                 {  delayxiaodou(100);
  164.                    if(K4==0)
  165.                    {  miao_g=miao_d=0;
  166.                       fen_d=0;
  167.                           fen_g=2;
  168.
  169.                           }
  170.                           }
  171.                           while(!K4);
  172.                           }
  173.                 if(K5==0)                  //K5按键:初值设定好后,启动倒计时;
  174.                  {  delayxiaodou(1);
  175.                     if(K5==0)
  176.                         {  ding++;
  177.                            if(ding==2)
  178.                            { ding=5;}
  179.                            }}
  180.                            while(!K5);
  181.                    if(ding==5)
  182.                         TR0=1;
  183.                                  //倒计时结束;
  184.                         display(fen_g,fen_d,miao_g,miao_d);
  185.                         if(fen_g==0&&fen_d==0&&miao_g==0&&miao_d==0)
  186.                           music();
  187.         }
  188.         }
ID:636538 发表于 2020-6-24 11:48 | 只看该作者
当你说数码管一闪一闪,我的想法就是去找你的延时函数,发现你的延时时间太长,一般是2ms。你这里1s肯定是这个效果。其余懒得看程序,你把按键找个单独的IO先测试,先别复用,测试效果好,再复用IO引脚,
