查看: 4353|回复: 0
Arduino程序 16路模块PWM舵机驱动板控制器 机器人 IIC接口
  1. #include <Adafruit_PWMServoDriver.h>
  2. #include <Wire.h>
  3. #if defined(__AVR__)
  4. #define WIRE Wire
  5. #elif defined(CORE_TEENSY) // Teensy boards
  6. #define WIRE Wire
  7. #else // Arduino Due
  8. #define WIRE Wire1
  9. #endif
  10. // Set to true to print some debug messages, or false to disable them.
  11. #define ENABLE_DEBUG_OUTPUT true
  12. Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(uint8_t addr) {
  13.   _i2caddr = addr;
  14. }
  15. void Adafruit_PWMServoDriver::begin(void) {
  16. WIRE.begin();
  17. reset();
  18. }
  19. void Adafruit_PWMServoDriver::reset(void) {
  20. write8(PCA9685_MODE1, 0x0);
  21. }
  22. void Adafruit_PWMServoDriver::setPWMFreq(float freq) {
  23.   //Serial.print("Attempting to set freq ");
  24.   //Serial.println(freq);
  25.   freq *= 0.9;  // Correct for overshoot in the frequency setting (see issue #11).
  26.   float prescaleval = 25000000;
  27.   prescaleval /= 4096;
  28.   prescaleval /= freq;
  29.   prescaleval -= 1;
  30.   if (ENABLE_DEBUG_OUTPUT) {
  31.     Serial.print("Estimated pre-scale: "); Serial.println(prescaleval);
  32.   }
  33.   uint8_t prescale = floor(prescaleval + 0.5);
  34.   if (ENABLE_DEBUG_OUTPUT) {
  35.     Serial.print("Final pre-scale: "); Serial.println(prescale);
  36.   }
  37.
  38.   uint8_t oldmode = read8(PCA9685_MODE1);
  39.   uint8_t newmode = (oldmode&0x7F) | 0x10; // sleep
  40.   write8(PCA9685_MODE1, newmode); // go to sleep
  41.   write8(PCA9685_PRESCALE, prescale); // set the prescaler
  42.   write8(PCA9685_MODE1, oldmode);
  43.   delay(5);
  44.   write8(PCA9685_MODE1, oldmode | 0xa1);  //  This sets the MODE1 register to turn on auto increment.
  45.                                           // This is why the beginTransmission below was not working.
  46.   //  Serial.print("Mode now 0x"); Serial.println(read8(PCA9685_MODE1), HEX);
  47. }
  48. void Adafruit_PWMServoDriver::setPWM(uint8_t num, uint16_t on, uint16_t off) {
  49.   //Serial.print("Setting PWM "); Serial.print(num); Serial.print(": "); Serial.print(on); Serial.print("->"); Serial.println(off);
  50.   WIRE.beginTransmission(_i2caddr);
  51.   WIRE.write(LED0_ON_L+4*num);
  52.   WIRE.write(on);
  53.   WIRE.write(on>>8);
  54.   WIRE.write(off);
  55.   WIRE.write(off>>8);
  56.   WIRE.endTransmission();
  57. }
  58. // Sets pin without having to deal with on/off tick placement and properly handles
  59. // a zero value as completely off.  Optional invert parameter supports inverting
  60. // the pulse for sinking to ground.  Val should be a value from 0 to 4095 inclusive.
  61. void Adafruit_PWMServoDriver::setPin(uint8_t num, uint16_t val, bool invert)
  62. {
  63.   // Clamp value between 0 and 4095 inclusive.
  64.   val = min(val, 4095);
  65.   if (invert) {
  66.     if (val == 0) {
  67.       // Special value for signal fully on.
  68.       setPWM(num, 4096, 0);
  69.     }
  70.     else if (val == 4095) {
  71.       // Special value for signal fully off.
  72.       setPWM(num, 0, 4096);
  73.     }
  74.     else {
  75.       setPWM(num, 0, 4095-val);
  76.     }
  77.   }
  78.   else {
  79.     if (val == 4095) {
  80.       // Special value for signal fully on.
  81.       setPWM(num, 4096, 0);
  82.     }
  83.     else if (val == 0) {
  84.       // Special value for signal fully off.
  85.       setPWM(num, 0, 4096);
  86.     }
  87.     else {
  88.       setPWM(num, 0, val);
  89.     }
  90.   }
  91. }
  92. uint8_t Adafruit_PWMServoDriver::read8(uint8_t addr) {
  93.   WIRE.beginTransmission(_i2caddr);
  94.   WIRE.write(addr);
  95.   WIRE.endTransmission();
  96.   WIRE.requestFrom((uint8_t)_i2caddr, (uint8_t)1);
  97.   return WIRE.read();
  98. }
  99. void Adafruit_PWMServoDriver::write8(uint8_t addr, uint8_t d) {
  100.   WIRE.beginTransmission(_i2caddr);
  101.   WIRE.write(addr);
  102.   WIRE.write(d);
  103.   WIRE.endTransmission();
  104. }
16路模块 PWM舵机驱动板 控制器 机器人 IIC接口 .zip
1.82 MB, 下载次数: 19, 下载积分: 黑币 -5
收藏收藏3 分享淘帖 顶顶 踩踩
