查看: 2073|回复: 2
基于51单片机的温度测量 程序要怎么改才能实现控传感器制多个MLX90614
ID:553625 发表于 2020-3-26 23:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"reg52.h"
#include"intrins.h"
#define  uint  unsigned int
#define  uchar unsigned char
#define  Nack_counter  10
uchar flag1;
sbit  RS=P2^4;
sbit  RW=P2^5;
sbit  LCDE=P2^6;
//mlx90614
sbit  SCL=P1^6;
sbit  SDA=P1^7;
bdata uchar flag;
sbit bit_out=flag^7;
sbit bit_in=flag^0;
uchar DataH,DataL,Pecreg;
void   start_bit();
//MLX90614
void   stop_bit();
uchar  rx_byte(void);
void   send_bit(void);
void   tx_byte(uchar dat_byte);
void   receive_bit(void);
void   delay(uint N);
uint   memread(void);
void   init1602(void);
void   chk_busy_flg(void);
void   dis_cmd_wrt(uchar cmd);
void   dis_dat_wrt(uchar dat);
void   display(uint Tem);
uint Tem;  //????
SCL=1;
SDA=1;
_nop_();  _nop_();_nop_();_nop_();
SCL=0;
delay(1000);
SCL=1;
init1602();
Tem=memread();
display(Tem);
delay(20);
uint T,a,b;  T=Tem*2;
dis_cmd_wrt(0x01);
if(T>=27315)
T=T-27315;
a=T/100;
b=T-a*100;
if(a>=100)
dis_dat_wrt(0x30+a/100);
a=a%100;
dis_dat_wrt(0x30+a/10);
a=a%10;
dis_dat_wrt(0x30+a);
else if(a>=10)
a=a%10;
dis_dat_wrt(0x2e);
if(b>=10)
dis_dat_wrt(0x30+b/10);
b=b%10;
dis_dat_wrt(0x30+b);
dis_dat_wrt(0x30);
T=27315-T;
a=T/100;
b=T-a*100;
dis_dat_wrt(0x2d);
if(a>=10)
a=a%10;
dis_dat_wrt(0x2e);
if(b>=10)
b=b%10;
dis_dat_wrt(0x30);
void   start_bit(void)
SDA=1;
_nop_();_nop_();_nop_();_nop_();_nop_();
SCL=1;
SDA=0;
SCL=0;    _nop_();_nop_();_nop_();_nop_();_nop_();
void   stop_bit(void)
SCL=0;
SDA=0;
SCL=1;
SDA=1;
char i,n,dat;
n=Nack_counter;
TX_again:
dat=dat_byte;
for(i=0;i<8;i++)
if(dat&0x80)
bit_out=1;
bit_out=0;
send_bit();
dat=dat<<1;
receive_bit();
if(bit_in==1)
stop_bit();
if(n!=0)
{n--;goto Repeat;}
else      goto exit;
else     goto exit; Repeat:     start_bit();
goto TX_again; exit: ;
void  send_bit(void)
if(bit_out==0)
SDA=0;
SDA=1;
_nop_();
SCL=1;
SCL=0;
_nop_();_nop_();_nop_();_nop_(); }
uchar rx_byte(void)
uchar i,dat;
dat=0;
for(i=0;i<8;i++)
dat=dat<<1;
receive_bit();
if(bit_in==1)      dat=dat+1;
send_bit();   return dat;
SDA=1;
bit_in=1;
SCL=1;
bit_in=SDA;
_nop_();
SCL=0;
void   delay(uint N)
uint i;
for(i=0;i<N;i++)
_nop_();
uint memread(void)
{   start_bit();
tx_byte(0x00); //Send SlaveAddress
tx_byte(0x07);  //Send Command
start_bit();
tx_byte(0x01);
bit_out=0;
DataL=rx_byte();
bit_out=0;
DataH=rx_byte();
bit_out=1;
Pecreg=rx_byte();
stop_bit();
return(DataH*256+DataL);
void init1602(void)      //
dis_cmd_wrt(0x01);
dis_cmd_wrt(0x0c);
dis_cmd_wrt(0x06);
dis_cmd_wrt(0x38);
flag1=0x80;
while(flag1&0x80)
P0=0xff;
RS=0;
RW=1;
LCDE=1;
flag1=P0;
LCDE=0;
chk_busy_flg();
P0=cmd;
RS=0;
RW=0;
LCDE=1;
LCDE=0;
chk_busy_flg();
if(flag1==16)
P0=0XC0;
RS=0;
RW=0;
LCDE=1;
LCDE=0;
P0=dat;
RS=1;
RW=0;
LCDE=1;
LCDE=0;
ID:553625 发表于 2020-3-26 23:53 | 只看该作者
大家不用帮忙改 留下思路就好 谢谢大家了
ID:808655 发表于 2020-9-5 11:54 | 只看该作者
又是零注释,谁会想看零注释的程序啊
